I know you've said its far from finished but my 2c:
1) pretty great layout as is, and it's nice to see you have followed my advice (maybe even intentionally lol) if using nice angled/rounded bends in traces. Not right angles in sight!
2) I'd finish the layout and then beef up as much as possible every trace you possibly can. Not crtical but I've found on very rare occasions that OHSPark can give dud traces if they are too thin.
3) Label everything. Components, wire points etc.
Other than that its a pretty darn good first attempt!!
After I submit the zip folder to oshpark and it gives me the first front and back render and I hit continue, where it takes you to the approval page with a different view of every file layer, is there any way to get back to that view later? Or is there a way to view the individual gerber files layer at a time?
Still missing too many parts to fire it up, but it's partially assembled to give you an idea of how it looks with and without optics, and in and out of the host. Most of the work is going to be creating a spacer block on top of the old LED board to help them new emitter PCB sit tight against the lens. Not too difficult, but important for heat sinking purposes as well.
I bought a stack of em…about 1/2 as thick as a standard SRK aluminum star, not that thick but thicker than the microscopically thin copper pour that is on the PCB
Too late, just ordered it, thanks for the offer though :beer: . I just today ordered the light it is going in so the Oshpark order will probably be in earlier than the host, so there's no hurry :-)
Yeah, the BLF direct drive drivers have been updated, the C1 has been relocated between the B+ and GND in order to eliminate the accidental boost effect of the cap and the diode when the power starts fluctuating/pulsing when the FET is turned off and on by the MCU…these revisions should eliminate the issue with dodgy mode selection and have the buffer resistors removed completely, also added off time caps on star 4 pin. I tweaked them up and Mattaus has reviewed and reposted all of them, the OP hasn’t been updated yet (also reset the “version/revision” number because they were getting squiffy)
I'll send you the files tonight. For some reason the latest revisions are not in my dropbox folder. Warhawk can probably send the last revisions he did as they are exactly what I used. I made no functional changes; all I did was add labeling to make them all V1.0
Feel free to do whatever you want with them. 100% open source. I started them, the community can do what they please with them.
