$15 seems suspiciously low for a a genuine Akoray K-106 3-mode programmable light. And they never used to have a GITD switch. And mine doesn't have www.akoray.com labelled on the barrel as these do in the picture. However, the color is darker than the cheaper 5-mode Akoray K-106, and appears to be the color of the original. What do you think?
The colour is probably just a different batch of dye. That ebay listing has to be a machine translation. Never heard strobe described as "Explosive" before. And dinodirect use the same term. Odd.
It could just be a high/low/strobe driver. But it might not be. I really could't hazard a guess either way.
(02:17:23)Robin F: I have got the answer the answer from our product department.
(02:17:40)sb56637: ah good
(02:17:47)sb56637: what do they say?
(02:19:19)Robin F: They said that there are something wrong with the desctiption. There is not three modes for this item
(02:20:11)sb56637: how many modes does it have?
(02:21:12)Robin F: you can press the switch to choose the light. the light will go dim when you continue pressing. If you stop here,the light will stop changing.
(02:21:30)sb56637: how many modes does it have?
(02:21:53)Robin F: no modes
(02:22:04)sb56637: how can i make the light go dim?
(02:22:40)Robin F: just press the switch at the end of the item.
(02:23:22)sb56637: and how many different dim lights does it have?
(02:23:25)Robin F: the light will be dim gradually. If you stop, it will stop changing.
(02:24:33)sb56637: could you make a video of light mode?
(02:26:16)Robin F: You want us to make a video for this item?
(02:26:35)sb56637: yes please
(02:26:57)sb56637: a video of how many times you press to make it go dim
(02:16:54)Robin F: Hello
(02:30:15)Robin F: Ok would you please wait for seconds and i will help you to contact our manager.
(02:31:05)sb56637: ok thanks
(02:31:46)Robin F: OK If continually press it without pause, the light will become dimmer and dimmer.
(02:32:55)Robin F: So we can not distinguish how much times.
(02:33:22)sb56637: ok
(02:33:49)Robin F: Is there anything else i can do for you?
(02:34:00)sb56637: i would like to see a video please, i think other people might want to see how to make the light go dim
(02:34:58)Robin F: Our product department do not have the video sorry for that.
(02:35:25)sb56637: could they make a video and put it on the site for everyone to see tomorrow maybe?
(02:35:29)Robin F: That is very easy for you to make it dim
(02:35:57)Robin F: There is not site for uploading the video
(02:36:03)sb56637: http://youtube.com
(02:36:45)sb56637: http://www.dinodirect.com/UploadVideo/ProductID-227482.html
Doesn't make much sense to me. It sounds like a wonderful infinite dimming system, but it's definitely not the same system that the traditional K-106 3-mode uses.
Sounds very similar to the system on the Solarforce Skyline. For general use this may be a better system. It actually makes the light more interesting to me.
