Mine are nearly two years old. I'm glad I posted about this.
The results though. Ouch. I hope this is my worst 26650 by far.
The King Kong is certainly a fine battery. But I feel like, if you are going to go with a 26650, the Keeppower 5200 is THE way to go. You actually get a decent amount of capacity along with that bigger cell.
KP 5200's do have the high capacity, but no match for the KK's for higher amps, as Richards say on his website.
My TrustFire 5000 tested at 4026 mAh on the Opus dream charger. Pretty sure this is typical.
Well I received the two Trustfire 26650 batteries that were recommended by leaftye above. Pretty quick shipping. However (and I was warned above), not all 18650/3xAAA lights take the 26650. This turned out to be the case with the two that I have that are 18650/3xAAA.
So this now means I need to buy another flashlight :bigsmile:
So I’ll take recommendations if anyone would like to toss out a link. Thinks to keep in mind, I like the Sipki ‘style’ lights, though it could be different. And I’m chea….er, frugal.
Thanks!
(feel like I bought a brand new door knob and now I need a house to go with it)
Always give us product links . Someone could probably help you out before ordering parts/cells, etc. I just got in a cheap 26650 zoomie, if that's what you are itnerested in. Another nice, cheap light was the F13 clone that we just had a group buy on (https://budgetlightforum.com/t/-/26433).
I appreciate the link. That may be the way I go. I didn’t read the entire thread, I’m assuming the folks here that bought one were happy with the light?
As a means of comparison, how does this look as an option; TrustFire A8 CREE XML XM-L T6 LED Flashlight 5-Modes 1600LM Torch Light 26650 US
Better/worse/same as the F13 clone linked in the quote?
Also, I’m I correct that an XML T6 is 1000 lumen max so the 1600 is just advertising hype?
Also, if anyone knows, what is the approx. run time on a light like linked above (F13 or A8) assuming a TF 5000mah 26650 (that may actually be more like 4000mah). Rough estimate to put me in the ballpark is fine as I’m just curious. And thank you.
The TF A8 is a nice light - I got one too. We had a group buy at that a while back, called the BLF A8. I prefer the F13 style though - little smaller, better output, though the A8 is maybe a little better quality, but who knows now - quality tends to drop from production batch to batch, and I've seen some low quality A8 clones.
No - the XML T6 does not max out at 1,000 lumens. 1,600 or so may actually be theoretical max, but no way, no how in budget lights will you get that output. 1,600 lumens is "chinese lumens" -- a total joke. I'g guess on the A8, you will get 450-600 lumens or so.
Runtime will be based on the amps drawn from the cell. So, if it draws 2A steady on hi mode, roughly it will last 2 hours at 4000 mAh. I'm thinking the A8 might be in the 2A range, maybe 1.6A, maybe 2.5A at most. So again on hi mode, you should see 1.5 hrs to 3 hrs at most. Much longer on lower modes of course. because of drawing lower amt of amps.
Another question, I see TF A8’s in the $20 range +/- and also in the $50 range. Is there a difference in the actual product?
$50 range? Maybe includes a charger and 1-2 batteries?
Ok Here for $55: ebay-Trustfire-TF-A8-Rechargeable-Flashlight-Set, the key thing is "set". Read carefully and it says charger, holster, protected battery.
Just got my 3rd F13 in today from the group buy - love these things. A8 disappoints because of a small SMO reflector and the SS bezel interferes with light output.
I think the numbers really supported the nicer KK cells over the KP5200’s. KP5200’s sagged a little worse IIRC.
FWIW on the topic of the Trustfire 26650’s… toysareforboys recently had a bad experience w/ his TF cells (#17). Couple that with leaftye’s discharge graph of a two year old cell and they look like an “avoid” cell to me…
HKJ tested the Keeppowers and they scored over 5000mAh at 5A. That’s more than enough in a stock flashlight. There’s also IMR version that keeps higher voltage but at 5A and more.
I wouldn't look at my discharge graph that way. Look at it more like an example of what might happened if you store them fully charged the entire time. I'll do more tests when I get a chance.
The KK 26700 is 5000 mAh labeled, tested at 5300 mAh on my Opus charger, and fits in F13's and the Yezl Y3. Seems to have the same power and low resistance of a KK 4000 in tests I did in real DD lights.
Sorry, I must have been thinking of another cell. The KP cell does look OK to me, although not really much superior to the KK if at all. Lower voltage under load and slightly more mAh at the (generally unregulated) tail end. YMMV I suppose, depending on the goal the KP seems like a fine option.
Okay, I’m learning quite a bit in this thread, many thanks.
I’m liking the looks of the F13 and A8 linked above. Hard to know what separates a good (inexpensive) light from a cheap (garbage) light. For example, surfing Ebay this morning and saw this;
2000lm CREE XM-L T6 LED 18650/26650 Flashlight Focus Torch Light Aluminium alloy
Okay, I understand the 2K lumen thing is advertisement. But is this an inexpensive light or a cheap light? Or is there really anyway to tell? I understand the clones are a dime-a-dozen. How would it compare with either the F13 or A8 linked above. Is the F13 twice as good (since it’s twice the price at a whopping $14 and/ore is the A8 three times as good since it’s like $4 more than the F13)? Does anyone have one of these Ebay lights and if so, how is it?
Your thoughts?
And how does this look?
CREE XM-L T6 2000 lumens LED lanterns Support Zoom Function Flashlight 26650 x2 / 18650x2
With using 2x26650 or 2x18650, what would you expect the lumens to really be?
Thanks for your input
I have an A8 clone from eBay. I was totally underwhelmed with the overall quality, fit and finish, etc. Besides fit and finish issues, I had contact issues with the tail switch assembly that were a pain to fix. I replaced the driver and maybe put the LED on a Noctigon, I don’t remember - the result wasn’t impressive.
The F13 from GB isn’t a bad light, but out of the box it’s not very impressive either. I replaced the driver and installed an XM-L2 on a Noctigon and used a thin centering ring. I ended up with a huge spot, I think I may warm up to it. Other people seem to like it.
I don’t have one, but for superior fit/finish/build-quality, maybe consider the Supfire L6? Supfire L6 Update Version LED Cree XM-L2 1100 Lumens 1*26650 or 1*18650 Battery from DHgate Farfar_ledtorch
I’d stay away from those eBay lights if you’re looking for quality or a sure thing. Stick with a trusted or semi-trusted dealer and a model that’s known to deliver consistent results. There’s little to nothing you’ll be able to key off of in an eBay listing to “detect” quality.
After putting some thought into it and looking at all the links and such, I decided to get my feet wet on the 26650 with a Trustfire A8. Coming from California. $18.03 with free shipping.
Trustfire A8 arrived today. Initial impression is that I’m very impressed. Seems like a well made light. I’ll try it out tonight.
