I’m not so sure that the reflector won’t work (I’m not so sure that it will either). HIDs are not point light sources, but they are pretty small, like an LED. I would think that the beam would be much better than a lot of incan to LED conversions. (Am I wrong about that?) Plus, the reflector looks like MOP, how bad can the beam be? And comfy is totally right about chopping off the base of the reflector, that’s a great alternative to a pillar. The heatsink assembly still has to get high enough to put the LED into focus, but at least you don’t have to worry about how to thermally couple a pillar to a heatsink/pill combo without a lathe.
This looks like a fun host and I was really tempted to buy the thing myself! Plus, isn’t this size your jacket-pocket sweet spot?
I decided to have a go at the innards. Things do not bode well. I twisted away with pliers from the top, yanking out a few springs and wires. I finally drilled a hole through and through.
It's solid all the way through. I don't think I'll be able to clear it. I even took a thick heavy steel rod and tried sledging it from both ends...it didn't even phase it.
It seemed like a good idea when I purchased it, but I didn't know I was going to run into this immovable plug.
After drilling a hole clear through the thing, does the material at the top (around the bulb socket. Looks like it has machining marks.) seem to be the same material as the stuff that was poured in from the bottom?
What about doing something like the cheapy smd led bulb replacements all over eBay, only with Cree led's? I'm picturing a copper/aluminum rod sticking up into the reflector with a few stars mounted around the original focal point. Probably unfeasible, but it would be different.
I just hit the plastic/nylon part with a mini torch. It started bubbling and burning like a tire. I have it sitting on the cement, it’s still burning away all by itself. Like a tire fire. I’ll just let it burn and see what happens.
It’s still bubbling like a witches cauldron. It’s been at it for over ten minutes now.
I guess HID don’t need heat sinking, because even though the thing is on fire, the tube only feels warm.
It's been twentyfive minutes, and it's still boiling away. I realized I forgot to take the o-rings off. Surprisingly, the tube is only warm and the o-Rings come off okay with no damage.
After the fire died I poked and yanked out crusty things and components with a pliers. There seems to be an integral lip. I think the plasticy front plate was installed from the rear, and the epoxy poured in behind it. I’ve pretty well cleared it out now.
Now what’s left is the epoxy plug. It looks about an inch thick. It’s free and rattling back and forth. I started another small fire to clear the rest of the plastic (what is this stuff).
After the fire dies and I clean things up I’ll figure out how to get that loose plug of epoxy out.
Thanks comfy. Having a bonfire would have never occurred to me.
So is there a pressed in retaining ring behind where the epoxy was? What is keeping it retained so that it rattles around behind that lip at the front?
