I’ll put that on my list comfy. Do you think I should torch the top end? As a last resort I’ll bring it into the maintenance shop at work.
Burn’em outta there! Just kidding. Heat sounds good, or freezing it. Or Freezing it and then applying heat to the outside maybe.
Or sitting it under the drillpress and pressing it out?
I would probably attack it with one of these: http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=9901
Cut two slots front-to-back so you can break it into two pieces.
I just hit the plastic/nylon part with a mini torch. It started bubbling and burning like a tire. I have it sitting on the cement, it’s still burning away all by itself. Like a tire fire. I’ll just let it burn and see what happens.
Things are starting to heat up now.
It's still burning!
It’s still bubbling like a witches cauldron. It’s been at it for over ten minutes now.
I guess HID don’t need heat sinking, because even though the thing is on fire, the tube only feels warm.
Video or it didn’t happen!
Video would take too long to upload to youtube.
It's been twentyfive minutes, and it's still boiling away. I realized I forgot to take the o-rings off. Surprisingly, the tube is only warm and the o-Rings come off okay with no damage.
Still bubbling. I wonder how toxic this is.
After the fire died I poked and yanked out crusty things and components with a pliers. There seems to be an integral lip. I think the plasticy front plate was installed from the rear, and the epoxy poured in behind it. I’ve pretty well cleared it out now.
Now what’s left is the epoxy plug. It looks about an inch thick. It’s free and rattling back and forth. I started another small fire to clear the rest of the plastic (what is this stuff).
After the fire dies and I clean things up I’ll figure out how to get that loose plug of epoxy out.
Thanks comfy. Having a bonfire would have never occurred to me.
So is there a pressed in retaining ring behind where the epoxy was? What is keeping it retained so that it rattles around behind that lip at the front?
It's free and clear. Once the charred remains of the plastic and components were cleared, the epoxy plug came out the front. There are two low profile lips in the front that I assume retained the plastic. The epoxy must have bonded it there. There is another wider shelf at the bottom where the contact plate threads in.
A BLF first?
Nice job! :)
I'll make you a drill-press-pill if you give me dimensions (and it's under 2" OD).
Talk about PERSISTENCE… but I guess a lot of us have “been there”. Good job, ouchy!
Nice result! This gives me hope for all my unfinished stuff. :bigsmile:
Thanks comfy. I’ll have to check what kind of measurements this thing has. I also have to ponder on how I’m going to approach this thing. From here, it’s all logistics.
Clear the trace right up next to the emitter, then cut the remaining trace so the pads are not connected. Wire it inside the hole in the reflector, in other words, the wires will show in the reflector. I did this with an SBT-70 in a HD2010.
The MT-G2 might work better in that HID reflector, remember that it's a lot of little dies, not a point source at all. Parabolic reflectors are very floody with the MT-G2 so this one might actually let it have a hot spot and some throw.
That’s what I’ve been thinking about. I can’t decide whether to grind down the Noctigon, or widen the hole in the reflector. I’m a kitchen table modder, so I don’t have much in the way of tools. I figure that if I botch the reflector…I’m done. If I botch a Noctigon…I’ve got lots more.
In my mind, I was thinking on stacking one or two sanded down Noctigons to give it height. The reflector focuses, so if it’s a bit too high I can lower the emitter by twisting the head. Everything will have to be measured and mounted perfectly so the reflector can spin around the mounted Noctigons without rubbing.
This is not going to be a rush job. Most of it will be squinting and scrutinizing.
