Actually from you BS's to my eyes the KD C8 beats it on throw I assume the KD C8 had a SMO reflector. If it only had an OP then a C8 with a SMO would certainly noticeably beat the Z1 on throw.
I will make this short ...
Its well made but not cheap ...
Im no fan of flood to throw , and this light helps re-enforce that feeling ..
Lets get straight to performance :
Rather than light box readings , as they were no accurate due to the flood to throw design , I have gone with a ceiling bounce comparison ...
Trustfire Z1
Flood = 47Lux
Throw = 16Lux [ Wow now that's a lot of loss ]
Solarforce L2 with 3 mode Manafont XM-L = 60Lux
Solarforce L2T with 3 mode low current XM-L = 35Lux
Now lets check out throw @ 1 meter ..
Trustfire Z1 = 12900Lux @ 1 meter
Solarforce L2 = 11000Lux @ 1 meter
Solarforce L2T = 7600Lux @ 1 meter
Wow , it does throw , but not nearly well enough to make a regular XM-L look bad , if anything it simply re affirmed my personal choice in lights .
What it seems to do is put out a nice spot , which is a little brighter at distance than a regular XM-L .. I have taken this light to the park ..
If you have to have one , fair enough , but it simply does not impress .
The flood mode is useful , and does a very nice job , but I just dont see the point ...
Bottom line ,
Flood is useful
Throws a little better than a regular XM-L [ P60 ]
Cheap ass pill , but emitter sits on a large base
2 x 18650 = A negative for me ..
Serious output loss in throw mode
Im not a fanboy of flood to throw , so I might be the wrong person to say yay or nay ! So I wont ...
If you like flood to throw ? [ My brother does - its his light ] you may wish to consider this one ,
Z1? Trustfire already has a Z1!
http://www.manafont.com/product_info.php/trustfire-z1-xper2-modes-flashlight-16340-p-7347?rp=041087
It's an XP-E based really tiny 16340 right-angle light something in the manner of Zebralights (but no head strap). I own that one. Totally different.
Is this a real Trustfire? If so, why would Trustfire release two very different models with the exact same name?
Yes it is strange. The one reviewed here is definitely labeled as, "Z1". But there is an identical one on ebay labeled as "Trustfire Z5". Enlarge the picture shown here. Either TF realised their mistake and corrected it on the second batch or one of the two is a fake.
Yes, the trustfire Z1 is the light on the right
I can't imagine they name two different lights the same...how bizarre is that?
Come to think of it TF may have done the same before. Their are two TF-R2's. One is a P60 host and one is a Dereelight DBS clone and AKAIK both are genuine.
Nice looking light. Trustfire seems to spits out a good design lately.
what is the actual output lumens on this torch??
of course x9 willbeat this z1
dont bother on the name.. what is more important is the ouput..
The number stated on the body is really misleading.. i guess, it will not reach beyond 800lumens
i see a cheaper one trustfire z5 ,everybody check and given advice to me,it at http://www.lights-box.com
it is the output that is important... not the name....
i wish i could erase the lumens numbering on its body
You can find it cheaper on ebay auctions. I won one from cyberport888 for under 40 bucks as a bike kit. Came with the light, a bike mount, two 18650 batteries, a charger, and a taillight shipped for under 40 bucks.
btw, it's a cool little light. Kind of a funky beam profile and the zoom adjustment is a little awkward sometimes but it's fairly bright especially in flood mode. It does lose a little output in spot/throw mode but as a jack of all trades type light I think it's pretty cool.
getting this zoomlight soon... i suppose it only produce around 500 lumens in zoom mode
i see a cheaper one trustfire z5 ,everybody check and given advice to me,it at http://www.spam-box.com
i find TrustFire Z5 Cree XM-L T6 1600 Lumen Zoom Led Flashlight White just $38.65,TrustFire TR-3T6 $54.50 have 3800lm,cool
Hi ...I have this flashlight.... If your want a flashlight for illuminates far don't buy this model. This model is good for close but for far no, even in full zoom mode. I'm not sure if is really 1600 Lumens....i'M not very happy of this flashlight.
If you want absolutely 1600 lumens with zoom go with this model http://www.ebay.ca/itm/1600lumen-CREE-MCE-LED-Zoom-flashlight-torch-/280721816439?pt=US_Flashlights&hash=item415c52fb77
The lens is better and it's a MCE led.
If the zoom is not very important for you go with this model http://www.ebay.ca/itm/1600-Lumen-Light-CREE-XM-L-XML-T6-LED-Flashlight-Torch-/150613836650?pt=AU_Sport_Camping_Hiking_Lamps_Torches&hash=item231148c36a
I suppose that MC-E won't give any more lumens than this XM-L.
The only "problem" with this torch (Z5) is that throw mode loses quite much light because of quite small lens diameter. Don't get me wrong, otherwise it's GOOD (quality, flood, battery life).
This torch has actually become my go-to flood light. I simply love the bright, wide, uniform flood it gives. And the runtime is good, as assumed.
And if I need a thrower, I can always pick a real thrower like my Fandyfire STL-V6 (Which is GREAT! ~48klux@1m, tailcap current 1.4A)
