Thanks Don! Is your F23 10440 high brighter than your Hugsby P31/P32 NIMH? Mine looks the same.
Aren't you suppose to be at work?
With an element of reluctance as I've got a completely pointless all-day meeting to go to. 40 agenda items, some of them referring to stuff from a year ago.
Nice work Don thank's, i would very much appreciate it if you could fit an ROP low into your testing schedule.
ROP Low in a 6D Mag. Stock Mag plastic reflector and 6 5,000mAh NiCd cells. 1365 lux - 303 lumens which seems on the low side.
Edit: This is close to the output of the showerhead Mag dropin on 3 D cells. Given what a pair of short-livedROP bulbs cost, the ROP low no longer makes any sense really. The showerhead dropin on 6 D's (Or 6AAs in a 2D with two of the 3AA-D KD adapters) is way brighter.
Edit2: Topped off the NiCd cells. Meter now saying 1401 lux / 311 lumens. Still seems a bit on the low side
F23 10440 high 850 lux / 189 lumens
P32 High NiMH 675 lux on an Eneloop charged two days ago. But the runtime is a bit better. / 150lumens - close enough
Here's a beamshot at about 60cm from the ceiling. F23 on the left, Hugsby on the right. Both on high, Trustfire with a 10440 freshly charged and the P32 on high with a freshly charged Eneloop.
It is hard to compare the beams - the Trustfire has the nicer beam colour - I'd call it vanilla which is my favourite tint. The path length for the Trustfire is a bit longer as it is standing drunkenly inside a 24mm socket that I just happened to have lying around. The Hugsby tailstands very nicely on top of the door.
Light | Battery | Lightbox H | Lightbox M | Lightbox L | Estimated lumens on high |
Piritlight SG-L8 MC-E | 18650 | 1735 | 665 | 237 | 386 |
Ultrafire WF-501B M bin MC-E | 18650 | 3220 | 1237 | 165 | 716 |
Ultrafire WF-503B DX MC-E | 18650 | 1636 | 675 | 364 | |
Ultrafire Wf-504B KD MC-E | 18650 | 2310 | 1575 | 61 | 513 |
Solarforce L2M DX P7 | 18650 | 1956 | 199 | 435 | |
Uniquefire R5 5 mode XP-G R5 | 18650 | 1565 | 164 | 84 | 348 |
Ultrafire WF-502B R2 single mode | 18650 | 940 | 209 | ||
Ultrafire WF-504B with the 5 mode R2 | 18650 | 1102 | 449 | 168 | 245 |
Solarforce L2R Solarforce low voltage R2 | 2xNiMH | 779 | 173 | ||
MX Power ML-310 | 14500 | 857 | 220 | 190 | |
Trustfire R5-A3 | 14500 | 1600 | 576 | 356 | |
a first batch Aurora SH-034 | RCR123 | 1016 | 304 | 39 | 226 |
Ultra-budget C3 clone | 2xNiMH | 163 | 36 | ||
Trustfire F22 | 14500 | 1210 | 535 | 115 | 269 |
Powerlight | NiMH | 94 | 21 | ||
BLF DeLight | NiMH | 85 | 19 | ||
MDXL "3W" | NiMH | 77 | 17 | ||
Aurora SH-035 | NiMH | 644 | 201 | 26 | 143 |
Uniquefire S10 | NiMH | 575 | 128 | ||
Ultrafire RL-118 | RCR123 | 1260 | 145 | 280 | |
Aurora SH0031 | Alk. AAA | 142 | 32 | ||
Aurora SH-033 | RCR2 | 744 | 221 | 33 | 165 |
ROP High | 2x32600 | 3250 | 722 | ||
Golston "7W" | 2xRCR123 | 390 | 87 | ||
Fenix E01 | AAA | 37 | 8 | ||
Varapower prototype | 4C NiMH | 8290 | 1842 | ||
ROP Low | 6D NiCd | 1401 | 311 | ||
Trustfire XP-E F23 | AAA NiMH | 396 | 33 | 88 | |
Trustfire XP-E F23 | 10440 | 850 | 82 | 189 | |
Trustfire Z1 | RCR123 | 889 | 82 | 198 | |
TiKey | 3xLR44 | 81 | 18 | ||
Romisen RC-C6 | RCR123 | 618 | 166 | 137 | |
Hugsby P32 | NiMH | 650 | 189 | 144 |
Hugsby P32 | NiMH | 650 | 189 | 144 | |
I think it would be better to just update the OP with the new information. Keeps it more clean so we don't have to scroll down to get the information. Thanks for your hard work Don.
Please note the various qualifications and caveats in the first post. There are likely errors in the method and measurement, not to mention calibration but the lux numbers for comparison are reliable for comparison with other lights measured on the same lightbox as the method is consistent.
Akoray K-106 | NiMH | 222 | 49 | ||
Smallsun ZY-C85 full zoom | 14500 | 456 | 101 | ||
Trustfire F22 | NiMH | 586 | 249 | 55 | 130 |
Trustfire R5-A3 | NiMH | 650 | 360 | 144 | |
Smallsun ZY-C85 | 14500 | 654 | 145 | ||
Uniquefire AA-S1 | NiMH | 665 | 148 | ||
Ultrafire C3 SS Q5 | NiMH | 718 | 249 | 49 | 160 |
Aurora SH-035 | 14500 | 785 | 250 | 36 | 174 |
Akoray K-106 | 14500 | 1077 | 239 | ||
Uniquefire S10 | 14500 | 1112 | 247 | ||
Trustfire F22 | 14500 | 1254 | 563 | 122 | 279 |
Ultrafire C3 SS Q5 | 14500 | 1391 | 620 | 128 | 309 |
Uniquefire AA-S1 | 14500 | 1445 | 321 | ||
Edit: By calculation, the R5-A3 should be no more than 280 lumens which is what I think it should be. From the DX spec it is driving the LED at 1300mA. The R5 bin is 463-493 lumens at 1500mA. So, by calculation 13/15 x 493 = 427 lumens though it'll be less than that as the output is not linear with current. The conventional reckoning is that 70% of the LED's output makes it out the front so at best the output is 280-299 lumens rather than the 356 lumens my lightbox/meter/calculations come up with.
Makes sense. I'll see if anyone wants any more measurements - if I've got it I'm happy to measure it - the measuring just takes a few seconds to do.
Once that's done I'll tidy up the first post, add comments and qualifications and put in the best data I can get. I've had to work every day for the last month or so, but a colleague has kindly offered to cover this weekend for me so if it works out, I get my first weekend off since June. Then I'll do the tidying. If not it'll get done shortly.
Thanks for all of your hard work Don. I don't care what everyone around here says about you because you're alright in my book.
Thanks for the vote of confidence :) ;)
Hey Don what about the bargain of the century the MRV lunapower.. also i don't suppose you have any runtimes on said light do you?
I will get to it at the weekend if the wonderful Pam is working for me. If not, I'll get it done ASAP.
Thanks Don your a STAR !!!
Very nice Don! This is an excellent resource. It's on the frontpage and sticky'd.
Quick suggestion: If you select all the cells in the table and click on cell properties you can set the border color to #000000. It would look like this:
Ultrafire WF-501B M bin MC-E | 18650 | 3220 | 1237 | 165 | 7162 |
Thanks for all the hard work Don!
I'll certainly clean it up - at the moment it is just copied and pasted from a spreadsheet - I hope I can make a much better looking table once I've got all the data together.
The biggie for me is the errors - I got bitten hard by that once in a lab job. If my results had been correct, someone was going to jail - it turned out my results depended only on how long the spectrophotometer had been switched on... :(
I plan to go through the light collection and get numbers for most of them. Since I'm doing instantaneous peak readings they only take a few seconds each - it takes longer to make sure I'm using fully charged cells in everything than it does to take the measurements.
Don't you think it would be more useful to take the reading after at least 30 seconds or so - not going for the highest output, but real-life performance?
IMO it makes the comparison more practical...
Can do. It might be interesting to have both. This suit? The numbers are on the whole lower as I just grabbed cells that were lying around.
Light | Battery | Lightbox Immediate | Lightbox 30 seconds | Lightbox 2 Minutes |
Fenix E01 | AAA | 37 | 33 | 32 |
Powerlight 1 | NiMH | 64 | 64 | 62 |
MDXL "3W" | NiMH | 69 | 72 | 73 |
TiKey | 3xLR44 | 81 | 71 | 64 |
BLF DeLight 1 | NiMH | 135 | 144 | 128 |
Aurora SH0031 | Alk. AAA | 142 | 99 | 100 |
Ultra-budget C3 clone | 2xNiMH | 144 | 111 | 83 |
Uniquefire AA-S1 | NiMH | 565 | 557 | 531 |
Akoray K-106 | 14500 | 1055 | 1019 | 1004 |
Uniquefire S10 | 14500 | 1112 | 1017 | 962 |
Trustfire F22 | 14500 | 1254 | 1128 | 1030 |
Uniquefire AA-S1 | 14500 | 1255 | 1183 | 1162 |
Ultrafire C3 SS Q5 | 14500 | 1391 | 1259 | 1122 |
Trustfire R5-A3 | 14500 | 1630 | 1482 | 1416 |
ROP High | 2x32600 | 3760 | 3600 | 3080 |
Varapower prototype | 4C NiMH | 8650 | 8330 | 6260 |
