Which thermal glue should I buy? I think I need a thermal glue that is not epoxy based, but more like silicon. So that I do not damage anything should I need to remove it. ( I will also use it in other applications) Are there any except for the Fujik? I do not orientate on the market well, ebay churns out too many results when I search for it… I dont need brand top end stuff, just something decent that will do the job without damaging circuit board during removal
It doesn’t really matter what thermal paste you use, just lap the pill and noctigon so you use as little thermal paste as possible. Most people prefer Arctic Alumina.
Since he’ll be wiring up three emitters, he really should use adhesive, not paste. Trying to line up and center three emitters with wires attached that are not already secured by adhesive can be an unnecessary nightmare.
Resetting it did not help. I have already contacted DX, hope it will get solved soon. I dont want to remove the protection, because all the other batteries are protected, so I would have to do the same on them too.
a new battery from DX has arrived.
I made a contact board for a new driver. It looks really ugly :D, but should do the job.
But I am still waiting for the XML-2 LEDs on noctigons. It is really annoying to be limited not by your already extremely limited free time, but by shipping…
still waiting for the XML 2 emitters on noctigons. The seller did not respond to a paypal dispute, so I have escalated the claim to the paypal. That should speed the things up a bit!
this seller http://www.intl-outdoor.com has been ignoring me and all he does is play a dead bug for over a month! All I want now is to unleash the PayPal on him, so that I can get my money from July 29th!!! In the meantime, where can I buy similar XML2 leds on copper stars? I have already given up the idea of getting them from the Outdoor Store!
BTW, will I see some improvement with an AR coated lens? My longterm plan is to unlock the true power of this flashlight. I want to buy a FET driver, unprotected cells or remove protection from these ones, and an AR coated lens when the current driver or batteries die just to reach its full potential.
There is a measure able difference but you would likely only notice it by switching back and forth quickly between them. The human eye sees increased output on a logarithmic scale so a few percent difference is hard to see.
Yes I know that, but small details negligible on their own, make a difference when upgraded and fixed at the same time. The FET driver will increase current from roughly 5A to ±6,2A per led. Adding the AR lens will add up to 10% of the total output on top of that, so the change SHOULD be visible. I asked a few people about the difference after the driver change, and they all said it is a visible difference. Almost all high end light have AR coated lenses, so it SHOULD have some effect worth the effort. I do not expect a huge increase in the power, but a noticeable improvement. A lens is not that expensive after all. But I am no expert, and since I do not plan on having multiple lights, I will most certainly buy one AR lens just to see how much it changes the output. I always like to use the full potential of toys I have. I just like doing things properly
Or is it really pointless? Any personal experience???
No, I don’t have it installed. I have a stock LCK driver, already potted and installed, thats why I say these changes will come no sooner that the current driver or batteries have died.
BTW, would anything get damaged if I tried to dissolve the fujik thermal glue in concentrated alcohol or gasoline? Electronics likes them right? If that was possible, I just might change my mind and mod this driver for a higher current output and remove the protection circuits from cells and get an AR lens at the same time before waiting for anything to die! I am stuck waiting for XML2 leds either way. Provided thaf it is possible to remove the fujik from the driver without damaging it…
U3 1A = Newest XM-L2 with cool white tint, this one is good if you like pure white light. You can see the temperature rating in the description of each product.
Don’t know about removing the fujik, but I’m not really a fan of stock drivers. There are lots of great custom drivers to choose from with excellent modes. Qlite, BLFDD and the new LD-1 are among my favorites right now.
You probably don’t need to remove the protection circuits just yet, unless absolutely necessary and make sure you can shrink wrap them again.
I have a question regarding dedoming. What are the risks of dedoming? Any long term effects on the led after the “dome” has been removed? I know that the process of dedoming itself can go wrong, but if it is performed successfully, is there any danger to the LED over the course of time ? I want to dedome my LEDs to increase the throw.
