Are the threads on the tailcap side of the battery tube anodized?
Interesting!
Did you see any PWM ?
So the reflector screws over the top of the emitter? Is that a large flat base on the reflector that more or less smooshes the star down on the pill (and possibly shorts out the solder blobs on the wires?)
Can you get us some better pictures of how the reflector screws into the pill please
Triangular threads. Somewhat like Tangsfire C8.
PWM is present. :nerd_face:
Reflector is screwed to the inner edge of the pill.
Solder blobs on the wires have to be equally flat. Kapton tape the reflector base to ensure they are not shorted.
I am removing the LED now. Will take a photo of the pill surface later.
Compared with F13?
This looks decent too. K68.
Where to get red buttons? I got too many green one now. Haha.
I’ve seen pink & orange but for some reason not red replacement tailcaps.
Thats a picture of the UltraFire LZZ-F15 which comes with red stock.
Is the bezel stainless steel?
No memory, so does it start on high all the time or does it start in the next mode?
Thanks for the review!
Good question. My guess is aluminium or some sort of alloy, but it has been treated to look like stainless steel. Weight is slightly heavier than alu but lighter than stainless. Sorry, I am not expert in metal.
Too many stuffs happening today, I forgotten to check on the mode sequence. My apology. Maybe you can check with vendor if you are interested to purchase. I have already swapped out the driver.
Thanks anyway!
Thanks for the review. I too am curious as to how it compares with the Ultrafire F13. What is the diameter of the glass lens?
-Garry
Subscribed, will take a closer look at your review soon. Thanks for doing it!
F13 produces the most horrible thread noise I have ever heard. Heat goes straight to tail section rather fast at HIGH, despite having so much radiating fins. Probably due to thin body wall thickness. AAA battery carrier (WB version) works but not fitting. F13 comes with several cosmetic defects and anodizing is weak.
Ultrafire F13 is very cheap, but you will realize that it also feel cheap after using it for a while. I hate to tell myself “You get what you pay for”. I have lot of fun modifying my F13s, throw distance is very good and heat management issue can be improved but I am not happy with it. Sorry but I have say that it is definitely not a light that I feel grabbing with.
Roxane M6 has slightly slimmer body. It is on par with Convoy grade in my opinion, in term of finishing, design and material. Downside will be lack of new CREE and powerful driver. I like my new setup with XM-L2 T6-1B on Noctigon with Qlite (+3x350mA) on 4th star. It has a bigger hotspot and spill than F13 or C8 with stock reflector. About 26KCD when I measured. Will post some shots if you guys are interested.
41.7mm x 41.7mm x 1.7mm
Nice photos, what kind of camera?
It is the person behind the camera that matters. :bigsmile:
>> Canon EOS 600D Kit (Rebel T3i)… I have dumped my red rings.
People will never stop asking though. :-\
[quote=wight]
People will never stop asking though. :-\/quote]
I have read that famous ken rockwell piece and i disagree, an amateur with a poor camera will do poorly, and with a good camera will do slightly better. A professional with a poor camera will do well and far better with a good camera. A person does as well as their skill level, if they have poor equipment their skill can’t fully shine, if they have poor skills there is nothing to shine, if they have the knack the limiting factor becomes the equipment and with good equipment they can do amazing things.
I noticed the pictures are composed very well, but when i saw the picture of the driver i knew for sure you were using a good camera, there is no way in hell i can get such a clear photo from my point and shoot, no matter how i arrange the lighting or lighting source, no matter what aperture or shutter i use, the camera just cannot take such a sharp image with equivalent colour depth and sharpness
Checkout XINTD X3 group buy thread and you will see some discussions in it. I have 3 such switches in my flashlight collection now. All 3 work well, but one is feeling a bit “funky”. Wish there is a V2.0 version of it.
