Apart the fact that making something women want I consider one of the difficultiest things in this world, thinking about this two thoughts pas through my mind:
Before this I believed making the ultimate thrower was difficult, but now I am glad and realize how easy it is compared to the above the work I do.
This
” What we are?——- Women
What we want?———We don’t know!
When we want it?———-NOW!!! ”
I wish you luck in this heroic project
Sounds great, Rufusbduck! :bigsmile: What I would like (if I was lucky enough to win) would be something along those lines.
I don’t have an emitter preference (in a small light run time is better I think) but did want clicky before I started buying twisties. I think one of those TP4056 boards could be modded to charge a 10180 but I’d worry it was too short to handle vs. 10440 (somehow that TU Nano makes up for it by being slim).
Like the squarish Xeno Cube light? I don’t know how it would feel in the hand, being heavier than a lipstick; maybe not as nice as circular lights.
There is a manual that will explain EXACTLY the flashlight they will like and that will have them eagerly allowing their significant others to spend as much money as they want on their hobbies while attaining the flashlight they so desire
This is the Manual for understanding women volume 1
Small and unobtrusive on the key ring, nice tint, easily operated with the hand holding the keys.
My wife is always multi-tasking, generally has her arms full of something or other as she zooms about her bizness. Having to operate a twisty she doesn’t much care for. (Doesn’t use the LD01 I gave her)
Hello Rufusbduck. My husband has nagged and nagged me to read the above and give you my thoughts. Firstly I'd like to thank you for thinking of all us poor wives and girlfriends that work extremely hard for you boys to play with your toys. I dont understand the batteries but needless to say we seem to have hundreds of aa and aaa batteries around the house seemingly not doing a lot. If the light turns on and of I'm happy with that. I do have a tiny light on my keyring which my hasbeen tells me is what you are very good at building modified ones. I dont understand what you all see in lights but thanks again for thinking of us better half's. What are you doing later?
Well, it’s a really good way to waste a lot of time and money without going anywhere. Being able to add a little pazzaz to an otherwise utilitarian piece of hardware is just a bonus. I prefer rechargeable lithium cells to alkalines because I don’t like disposable cells and lithiums are more potent.
Only the weekends to play and not all of them but I got a few things done. To thread the various parts together I found some small brass fittings that with a bit of persuasion can pass a 10xxx cell. Also had some nifty bits of knurled brass made by one of our own whiz kids.
Here is the chosen fitting.
Reamed for the cell.
Some threads borrowed and turned on the drill press. I have a metal hack saw blade screwed to a block of wood that is clamped to the table and with the brass mouted on threaded rod make vertical passes to get a true cylinder cut.
These will get brazed with an outer sleeve added.
The angle head starts with one of the caps turned down to fit in a knurled bit. There are 3 other pieces of brass tubing that were part of this braze to sleeve the ID down to where the brass pill would slip past the threads.
Here is a pile of parts. Some fins will be added and the head shortened a bit. After the fins it starts to get tricky again adding a threaded bezel.
Laid out and drilled a bunch of holes in a 3/4” strip of brass and marked it for cuts. I want to see how short a spacer ring I can cut from tubing with a consistent length. If I can’t get short enough I’ll fall back on .8mm brass wire for spacers. I also turned the middle step down one layer.
The tube on the far right is the pill. There’s a copper sheet brazed into it that the emitter will rest on. Above either face of the sheet the tube will be opened for access. On the one side for the optic and on the other for a solder pad to connect the switch which is pressed into the tube. The driver will be opposite the switch with the mcu side facing B+ for programming access.
I think you should offer these in kit form, unassembled like a box of puzzle pieces for the discerning flashaholic that has done it all and want’s to step it up a notch.
How you come up with all these pieces is beyond me. I get lost looking at it all and reading your descriptions, can’t begin to imagine how you conceive of all the necessary items and source em all out. Some kind of sorcery methinks. Black Duck Magic. Quack Fu.
