āXM-L L2ā and āpillowā
Those are typographical errors/ mistakes translating back and forth.
Thereās no such LED and no actual pillow in any flashlight.
It's an XM-L2 LED, probably T6 and ~1A tint.
LJ - Yes, definitely Direct Drive, high powered, very much like an East-092 driver. Does pretty good stock but the springs, LED wires, switch will hold it back. I don't undersantd - you don't have one?
Wellā¦ itās kind of like a pillow. Thereās often a recessed area in the pillā¦ow that the star sinks into. The star rests upon it for both support and heatsinking.
> freezer overnight.
Well, itās aluminum in aluminum, but heck, Iāll try freezing it.
Did they put glue on the pill threads, anyone know?
Iām assuming it was just cranked in with a machine and is jammed but can come out somehow.
I guess penetrating oil is the other possibility.
Or redrill the little holes bigger and deeper and use a bigger set of pliers to twist it.
All of the above?
I've done the over-drilling and it worked for me in the past. I haven't found any evidence of glue on my two.
This thing is BRIGHT
A good SK98 looks like a 3w āPoliceā light against this thing.
Tint is a little blue when zoomed, donāt know if that is the LED tint or artifacts from the lens assembly though.
Looks good out wide, regardless, this thing is great as is.
Unbelievable heat sinking for a zoomie, it just doesnāt drop off much at all.
More than happy, should have ordered more than 2.
Someone asked if they ship from the ā California Warehouseā, ehhhhhhhhh, No, straight from Hong Kong.
Thanks,
Keith
It is really amazing for the price - best deal around. Mine is doin bout 1,100 lumens now in full flood on a good 2500 mAh LG HE2 cell, modded out, but still pretty incredible for a cheap zoomie. I was able to fit a better quality Omten switch to replace the stock switch - much better. The stock switch itself seems to have loss's at higher amps.
Yes I had the original t6 version which I gave away and as soon as the xml2 resin was available I ordered two on one I mounted a 10 chipped 105 Nanjing 380 Mah not knowing g it was a direct drive so I switched it back to the oem one and to be honest i couldnāt tell the difference.
Good Day Dealmetic.com,
You have PM...
Thank You very Much,
George
It could be paired up with a good quality battery and single bay charger and sold as a complete package? I have 2 of these and everybody I show it to wants one, they really like the flood the most, and I have to say I like it too, but there not Savvy about batteries and chargers, but in a complete kit, people just getting into this would buy it? Itās that impressive!
> everybody I show it to wants one, they really like the flood the mostā¦.
That would be people who donāt know how to safely use lithium-ion cells.
Would a 3v lithium primary drive this light, if it were given a shorter battery tube?f
(actually that would be good with the cheap hollow-pill version, since it would run cooler)
That would be ideal for giving as a gift to people who you wouldnāt trust with li-ions.
There all professional people, you know Doctorās, Lawyerās Engineers,Cops, Firefighterās real dummies, too stupid to figure it out, probably Blow them selfās up?
Donāt have any high drain battery on me now, but will it get āboilingā on HIGH using those ? I was thinking put some artic silver between the sliding surfaces to increase heat transfer, but it probably nasty (white, and will āslideā out). (is there any black thermal compound? XD)
However, I donāt have my unit. I have been robbed by my friendā¦ā¦ I have no more zeusray in my handā¦ damn itā¦
Hi Dealmeticā¦can I know when is the stock going to be replenished? Its on back-order nowā¦
Will the 2nd batch be made to the same standard by the same manufacturer?
Ooops, mine is modded with a current limiting Nanjg driver so I don't have to worry. But, in stock form the light has a lot of resistance and with a higher Vf of the XM-L2, probably will be constrained - maybe not more than 4-4.5A or so with absolute fresh best cells.
Waiting to grab my second batch. Hopefully Dealmetric is giving us a surprise upgrade. NW tint? New switch?
Tom E., care to recommend a driver that fits and works?
I put in a PC Rebel Amber emitter; itās overdriven by the stock driver at the high level (the blue emission comes through the phosphor on the spectrogram).
Looking at the stock driver in the pill, I see a little wedge of what might be springy metal in the gap between the board and the pill; wondering how easy it is to swap a driver into this particular light.
(Iām still new at this, done half a dozen driver swaps on SK68-ish lights, with some struggles getting good connection to the pills)
hank - too many threads on this - thought I posted mod details - maybe not everything:
This is what I did/used. Nanjg at 3.85, custom programmed modes. I took a metal chisel and notched the edges - working well so far. I've done this a few times. Another method is using copper sheet metal shims in the gap, press fit the driver in, then solder the copper shims to the driver edge - also works. Lots of variations of this theme have been done. This is always a problem/issue for these all-alum pills... I like leaving a notch on the top edge, shown on right in the pic above to allow you to easily pry up the driver later. If not there, drill/dremel one out.
If you use the copper shim/tab method, be sure not to create any shorts by having loose ends get onto the driver electronics.
Best solution I've seen for the driver mount issue is the 2014 model of the Convoy M2 - thin brass retaining ring that clears the 7135's !! Wish they all were like that - first time I've seen it, but of course the Convoy's are designed for Nanjg style drivers.
got mine in 8 days!
will play with it on weekendā¦
ā¦. Nice name, ZeusRay. Was Zeus a greek God?
Yeah, A god using thunder bolt, I guess that is the ray. so I guess we all steal portion of his thunder
orā¦ā¦ zeus is behind the production ? well for me it is still not quite a thunderbolt, unless v2 is going to be pocket rocket with narrow focus. (the focused beam still quite wide in long distant)
