+1 and I have the two screws
ergotelis, do you have the Sky Ray? They may come from the same place (ie OEM branding), not clones of each others.
Just got my skyray version. I think the solarforce MPP-1 still throws a little better at long distances (300+ yards) but at the shorter distances the output of the Skyray blows away the MPP-1. I am happy with it, seems to be good quality for the money. Mine has the two screws.
Sorry, no, i don't have the skyray, but it looks like the same thing. They could have made it a bit better i think!
TO add something here, i carefully noticed that a M3X has slightly larger inner reflector diameter. 56mm vs 54 of the fandyfire. A tiny difference, but in this size it is enough to give some lux more.
THe height of the reflectors is the same.
The glass has worse quality on the fandyfire, not AR coating seems to be present.
Also, the pcb seems to be smaller.M3X has a bit bigger pcb.
Thanks for the update. good to know its still good. I dont know how much MF has sold, probably not that much with the cheaper fandy at dx. so they probably still have the first run available. just ordered some 18500s to make it a bit shorter. mine is still going with regular use. i find it too bright for some applications but its still amazing outside in full darkness.
I have bought a second one (Fandyfire version from DX).
The output is almost identical compared to the first one. (man I love this light!)
anyone has a link for a cheap AR coated lens??
I bought 2 x UCL for my DRY triple XM-Ls and 1 acrylic diffusion lens. Unfortunately they do not have 59mm size which the STL-V2 or Fandyfire STL-V6 needs.
Ordered, and now I'm running on walls and waiting impatiently :D
Did you order the Sky Ray or the Fannyfire? I have the Fannyfire and am pleased.
First ordered FannyFire but it was back ordered (DX site says ships 4-7 days), canceled that and ordered Sky Ray from Manafont.
EDIT: And Manafont is fast as usual... ordered yesterday, they dispatched today :)
Which Fannyfire?
STL-V6 of course :)
Now is good time to buy this from DD
With coupon code:THANKSGIVING
only $41.19 :O
Thanks for info! I just placed an order to them. $41.19+2.00 insurance+0.99 return postage.
Went for a walk and took some underexposed beamshots
F/2.7, 1/8 sec., ISO1600
Mouse out: UniqueFire UF-2100 - High (1/8 CTO tint mod)
Mouse over: Sky Ray STL-V2 - High
Hay bale about 35 meters away.
Hay bale about 35 meters and forest about 80 meters away.
Sky Ray STL-V2 - High - 5x Zoom (F/5.9, 1/8 sec., ISO1600)
First hay bale about 165 meters and second about 235 meters away.
Nice beamshots! Sky Ray STL-V2 is a good thrower
Now some serious distance beamshot :)
F/2.7, 1/4 sec. & ISO4000
And same with 5x Zoom
F/5.9, 1/4 sec. & ISO4000
Yes, I know latter is dimmer :(
Triangle traffic sign is about 375 meters (410 yards) away.
And just "one" more shorter distance shot.
Trees about 175 meters away.
