new time temp amp data up
Scotty, I built a triple XP-G2 R5 2B for a Solarforce L2M shorty. I used a 7/8” diameter copper pill 1 1/16” long (made from bar stock) to fit in the L2M, Efest Purple 18350 and it draws 8.4A with the BLF17DD driver. Start output is 2084, 1766 at 30 seconds. Still doing 1500 at 4 minutes with a head temperature of 144º.
I’m not Scotty,
But you say the lumens will droop and the head temp will stabilize long into 4 minutes?
I don’t think I’ve got the balls to run this thing that long, considering how hot it gets so quickly
I left the timer at 120 secs on my Roche F6 triples, seems fine to me. (as long as you don't change hands with it after that amount of time, the normal-temp hand gets quite a shock :O )
wd, that’s with XP-G2’s on a big chunk of solid copper. Scotty asked about hard driven XP-G2’s output in comparison to yours. Look how much copper is under this, and even with XP-G2’s it heats up pretty good…
Comfy, so what you’re saying is keep the fried hand on the light and it’s ok? lol
I’ve used thermal paste on the head threads of my last 2 Solar Force triples—Seems to pull the heat to the head more and slows it to the lower tube a bit—Has anyone else tried this
Thermal pastes only work where the layer is very thin, like microscopically thin. In thicker layers it acts as an insulator not much better than air. To get the thin layers required usually means very flat highly-finished surfaces and high clamp loads, things that are usually not possible in most flashlight parts other than like between MCPCB & pill top, pill flange to head surfaces, or rather tight press-fit pills.
So when you tighten up threads till something binds (head to body) therefore making the threads pretty snug against each other—that’s not a tight fit
In a narrow contact area like the spiral lands on the threads you likely have enough surface contact that the paste wouldn't help. And it definitely won't help between the other parts of the threads that aren't physically touching.
You got me wondering now if putting a thin copper foil like Teflon tape on the threads would increase head to body contact
If you got a tight enough contact you wouldn't be able to unscrew it.
I tried to put solder paste on the threads, figuring to reflow it together. I couldn’t get it to thread or screw in with the paste on there. Probably would have been a PITA to keep all the wires in place. It took a long time to clean out with an old tooth brush and paper towels.
Is it worth running a triple xpl on a sensible current that would allow you to run it constantly without heat issues in an Convoy S host? How much current would that be and what output would we be expecting? I like the setup but always prefer to have safe runtime on a high mode and then all-out turbo with stepdown.
aoeu, it might be worth looking into as the Cree datasheet shows a more efficient 350mA to be an ideal. So if 1A or a little more were provided to the 3 XP-L’s then the triple should be in an ideal working range. This could, of course, be configured into the UI at the second or third level to offer a choice of efficiency, while maintaining a more robust high and 100% turbo. (can’t give up the all out blast of awesomeness!)
I would think output would be in the 500-600 lumen range at those levels.
Thankyou I checked it out. Seems you do get a ~20% advantage from driving same current through 3 XP-L than that current through one XML. I suppose that would mean the triple would produce less heat with the same current and lumens?
Okay, wait. You’re saying that thermal paste, something that is supposedly made for helping to conduct heat between two surfaces, is just barely better at conducting heat than air? That is hard for me to understand. According to Engineering Toolbox, even Styrofoam (made to NOT conduct heat) conducts heat better than air. Plain ole Epoxy has a thermal conductivity that is almost 15 times that of air. Insulating brick (didn’t know that existed) conducts heat at a rate 6.25 times that of air. Yes, these are still relatively tiny amounts, because the only thing that air conducts heat better than is a vacuum. But, we’re talking about thermal paste. It should be pretty good, I’d think, at doing what it was made for - especially compared to leaving the air void that would be there if the paste wasn’t!
edit: to clarify, there are several gases on the list that are less heat conductive than the air we breathe, but I call them all ‘air’ for the purpose of these comparisons.
David, for me it’s a moot point…2 bare pieces of metal in contact with each other will conduct heat between each other. period. Are there microscopic gaps that hold air at the junction? Most assuredly. It becomes a matter of quantity I would think. Microscopic air gaps between surface contact leave how much percentage of contact at a loss? Can’t be much, if the gaps are microscopic in nature, right?
It’s really a question of efficiency, and the effort to increase efficiency might be more than the net gain in these applications. We struggle to max out the emitter performance, while the cell sags and loses power…effectively killing all of our efforts in the first half minute anyway. Vicious circles.
The bigger point is that if the thermal paste is not applied as it was intended then it could be more detrimental than beneficial. The idea is to fill the air gaps and leave the metal to metal contact. By using too much, you separate the metal to metal and only have paste…losing more than you gain.
I saw someone recommend applying the paste to each surface and then scraping the surface clean of paste with a razor blade. The two surfaces would then mate with the best possible contact.
Almost all of these considerations are extreme examples of taking things to the Nth degree. Something we’re getting pretty good at in our search for flashlight Nirvana.
I keep saying we need ray-gun-type cooling fins.
I just found the ideal hardware to mod with the latest, hottest emitter:
Uh, yeah, it needs some work:
Yes, that's exactly what I'm saying. Your ideal insulator, styrofoam, could very well be a very good conductor at a thickness of 1-3 microns.
edit: And this is why these reference charts are misleading at best. You have to know how to interpret the data as it applies to a specific situation, and if you don't know how to do that, you'll think you understand something you really don't.
