If anyone was going to come up with something new and
totally out of the box for a Mag light.
Great Job….O-L
Looks Great !
Great Job….O-L
Looks Great !
I sound like everyone else, but really: thanks for sharing. I know you weren’t totally thrilled by the outcome, but it looks pretty damned awesome from where I sit.
If this one goes up for sale, I’m gonna be sorely tempted.
It's hard to photograph, but you can see a little of the white spots showing through. In person, they are there in many of the low spots in the knurl.
One word……Awesome!
OL, I know you were not supper inspired by the finish, but I want to be along with the many here.
Dam good job. I have a few things I have been considering getting Dipped recently (stocks for firearms). This just added a few more things to the list.
Do you think there is any good way to remove the anodizing with out killing the light? I am ok with out having HAIII, I can always have it Cerakoted if I need a durable finish.
You can remove the anodizing. I do it with greased lightning, from lowes or home depot. Others use drain cleaner. The problem with removing anodizing is that bare aluminum forms a film on it the second it’s exposed to air, so it’s hard to prime it fast enough to work. I think sanding the anodizing worked well enough.
That is most awesome OL! The flame skin is wicked cool!
I said I would update with photos of the finished light. I have two of them to show. Here they are.
I am not able to dip the tail caps. They need to be dipped the same time as the light and in the same orientation, but then there's no way to hold the light, so the tail caps don't have pattern on them. On the flames light, I left the bezel and tail polished. Also the top of the head, where the grooved ring is. The dip won't cover that right. For dipping, parts need to be smooth. Roughness causes the ink to not get in the low spots. Both lights are done the best I can. I think the Camo actually looks better than the flames.
I am going to do 2-4 of the 3rd Gen Maglites. The heads are smooth, so they might be better to dip.
Buddy of mine owns a company that does professional hydro-dipping and cerekoting. I have had him do a few things for me in the past. Had him dip a computer case for a Modding competition last year.
Nice work! i really like the camo MT-G2 Mag above.
The camo is more subdued. But the way you build Maglites, I think the flames are pretty darn appropriate. :party:
Not the powder coating resins they make at the chemical factory where I work sometimes.
It is made to stick via static electricity to the barest, cleanest of metals, where it lies gently and softly until it can be baked on forever.
I would LOVE to know how to make decorative patterns like this in powder coat!!! (I mean, with my piss-poor “artistic” “”skills”“)
Dim
I don’t know if you could do patterns like that, but some patterns you could probably do. I know they mask parts for powder coat, so it would be mask, coat, oven, mask that, coat, oven… I imagine somewhere it’s being done for some kind of parts.
Interesting stuff OL!
EDIT: Also they look good. Forgot to mention that. I don’t have many camo items myself, but between those two lights I do like the camo best.
Both of them look great O-L….
But I just saw some testing on your Mag Lights… and they were pushing just over 3000lms
of pure flood and throw.
Great Job
OL, you should try dipping yourself… should make for some wicked body art…
Sweet. You need to work out now how to hold the light so the tailcap can be done. Maybe a piece of wooden dowel pressed gently into the bezel opening?
I had a similar thought, but since he’s got to roll it lengthwise I don’t think it’s very practical. You’ve gotta hold the thing reasonably level and roll it >180° while keeping it reasonably level. OL doesn’t have space for two hands worth of dowel rod sticking out of the head of a 2D Maglite in his tank. I can’t speak for OL, but for myself I think I’d have trouble steadily rolling the thing while holding it that way.
OL, I hadn’t had a chance to watch the video before now. That’s a nice budget tank setup you’ve got!
@ wight
Yes, that tank was a good buy and it works great. Nothing sticks to it. I drain it and wipe it out with a paper towel with paint thinner on it and the tank is clean again.
Since the light has to be rolled, it has to be held at both ends and it has to be level, to get the seam right. That's the reason that I haven't tried a tail cap. I would have to do the tail cap separate. I did the bezel on the light, by using a knob attached to the plastic lens, but the top of the bezel didn't look right. It looked smeared. The bezel and tail cap would both have to be dipped by the angle dip method and they would not match pattern to the light itself. I have seen someone dip a flashlight via the angle dip method, but the pattern looked kind of funky, like it was stretched in places and not in others. When you roll, the ends look strange, like they have been twirled like a top, which is what going to happen, so I have just left the tail cap and bezel out of the picture for now. I may try angle dipping myself, just to see, but I don't think it will come out good.
The biggest reason for giving up on it is the fumes from the activator. It needs to be done in a shop, where the fumes are carried off, just like a paint shop. Can't do that at home and don't want to invest tons of money for a garage modded to do that, where I shouldn't even be doing it in the first place. The fumes need to be captured and the water needs to be captured and recycled too. Just not good for a DIY home thing. I can imagine the trouble if the city knew what went into the drain.
Makes sense to me. I’ve looked into the subject several times but always found enough problems to stop me from seriously considering building my own setup. Thanks for posting your results and thoughts on it.
