Thanks ImA4Wheelr!
Yes I’ll try checking the thermal sag as suggested. The light indeed easily gets hot at high.
I’m also planning to convert its MCPCP into a direct thermal path using copper wire inserts to make the X6 handle heat much better.
Thanks ImA4Wheelr!
Cool project! 40 watts of light! Wow! Are you intending this for a bike light or what?
-Garry
Hi. Where did you get the light from? (link please)
I want to show it off as a bike light but I’m not sure I need to do that. My X2 and SF90 combination already makes me the brightest bike at night in my town. Besides, I’m still looking for an appropriate power source for this as the common 2S2P battery packs won’t work. :~
Maybe this would make a good flood/search light for my car?
That would be from this link.
I actually won it, complete with the DX driver, from ledoman’s giveaway thread hence named it the Ledoman X6. :bigsmile:
Excellent write-up. The right man certainly won this giveaway!
One question… how is the driver being secured in the housing?
Great job! I'm very happy for you and that you make it to work with the new driver. I hope you'll examine it's all settings - selecting from 10 intensity levels. Documenting currents/watage on all levels would be nice too. They should be somewhat linear except at the high end.
Mine driver does flickering at lover levels when powered by 3S2P pack. It might be different with 3S1S because of higher voltage drop. Have to try this to see the difference.
Need one small detail. How/where actualy did you trim those white center rings? What effect that has in a beam or brigtness?
Edit: figured out what you probably trim off.
I love your mod and what a fantastic read. Thanks for sharing. The machinist doesn't look to happy in the second picture and he must use that four jaw chuck on his lathe for everything he does. I'd hate to have to lift it of manually. Excellent effort.
Thanks NightSpy!
Just like the old driver, the new DX driver was press fit into the housing. That’s why we had to ensure during the lathe work that the inner diameter of the newly fabricated housing opening is exactly the same as the outer diameter of the DX driver.
Also the driver is not a perfect circle. There is a portion in the PCB where it was supposed to be connected to another PCB during manufacturing so you shouldn’t file/smoothen that up. You’ll need that to ensure that the driver will fit snugly to the housing.
Thank you ledoman!
I’ll add the gathered data on the current/wattage readings of all levels in this review. I haven’t tried it yet since I spend most of my time last night setting up then resetting up my equipment at flashlights outside because of the on-and-off shower. That’s why a car was included in the pictures because it was used to secure/hide everything in case rain would suddenly fall. :~
For the centering rings, I simply used a nail file taken from my wife’s manicure set and it did the trick. It can be seen in the foreground in one of the pictures. Actually I also took a nail clipper from that set to nip the DX switch. :bigsmile:
Thanks MRsDNF!
Yes your observations are correct. He’s used to working on large and heavy flanges and the smallest he’s worked on, before working on this light, was 10 inches in diameter and weighing 5 kilograms. This is actually the smallest thing - and the most delicate - he’s worked on so far so he had to make a lot of fine adjustments before starting the Lathe Machine.
Actually he told me afterwards that if it was somebody else who asked him to do this lathe work then he probably won’t. I guess its a good thing to have good friends wherever you go.
Nightbird95, no need to hurryy now. Take your time to discover it's features. Also note when something unusual happens ie. falling back to "safe" mode cause of temperature rise or voltage drop.
Last night I've put together mine 6x light and fix the driver into its final position. Flickering with 3S2P pack has almost gone. Trying before with 3S1P while driver was still hanging out still showed flickering. So it looks its good position of outer ring in the light is curing that.
It is obvious that it takes much more power from the batteries when powered with 3S2P pack comparing to 2S2P (or 2S3P). I'm wondering how long it can actualy run under so much power. I'm bit sceptical.
Tonight it is going on a ride with some other lights. Will try to take some pictures.
ledoman, got the data already!
Having used the battery case a lot during last night’s beam shots, its remaining voltage is only 11.97 volts.
Level 1 draws 100 mA from the battery pack. That’s equal to 1.2 watts
Level 2 draws 130 mA or equal to 1.6 watts
Level 3 draws 320 mA or 3.8 watts
Level 4 draws 580 mA or 6.9 watts
Level 5 draws 890 mA or 10.6 watts
Level 6 draws 1240 mA or 14.8 watts
Level 7 draws 1610 mA or 19.3 watts
Level 8 draws 2030 mA or 24.3 watts
Level 9 draws 2530 mA or 30.3 watts
And finally Level 10 draws 3380 mA or 40.5 watts
For my use, I set mode 1 to level 10, mode 2 to level 5, and mode 3 to level 1.
Have you done watage calculation based on starting voltage? If so I find it wrong as when the current rise the voltage is dropping. You should read the voltage and current at the same moment. Then you'll get some lower power readings than those you published. If I'm wrong, take my apology.
We should put results in the table and/or graph for easy reading, but take it easy .
I see.
The volt meter/amp meter from eBay that you recommended just arrived this afternoon. The problem is that I cant make it work. :~
This gadget should make it easier to get the actual voltage readings while the light is in use.
Where the heck is 40 watts of light throwing heat gonna go on that small head?
Better be riding pretty darn fast
Either way, wicked cool mod, great job!
Wonderful job, bro! Deserving winner of that light.
Ok. I assume you don't know exactly how to wire it, right? Here we go:
If you want to check charging batteries you just reverse the connectors (assuming you are using tipical 5.5x2.1mm connectors). That way you can check how Li-Ion 8.4V chargers are working. Found one which doesn't stop charging at all. It came with some red letters on the label. Probably sign of red flag ;-)
PS. Voltage reading could be little lower than without it because of voltage drop over this gadget. I've experienced 0.1V difference but this is also the smallest increment when showing figures above 10V, so the exact difference is unknow, but should be below 0.1V. This would result in a error of +/- 0.4W reading at max. No big deal.
Thanks WarHawk!
Yeah, you’re right. That’s why I’ve programmed mode 2 (mid) to level 5 which is only about 10.7 watts and I’ll be using this most of the time when riding my bike. The high mode (40 watts) will be only used when necessary.
Now it will be necessary to use high when its time to brag my bike light to my friends. That’s one of the perks of being a member of BLF, right? :bigsmile:
