Gearbest Daily Deal Updated: March 16th 2021/ Baseus LED Flashlight $21.99 with the code: GBREAKER
Perfect, will wait for your experience and evaluation :slight_smile:
A D cell is about as wide as the outer diameter of the tailcap threads on the X3. The length of the carrier that came with the IOS version is close though, so you might be able to use it in a D/32650 light like the Lumintop SD10 or Maglites. I'm assuming the GB carrier is exactly the same, and now I have one ordered too.
Thanks Gearbest for sourcing the battery carrier, much needed and a good price too! :slight_smile:
I was thinking the same thing. W/O looking up the dimensions of this carrier ur post basically confirmed my suspicions that it will run nicely as a 3aa D-sized serial cell carrier.
Thanks!
EDIT - Oops! should have read further down the thread. Apparently this carrier will be closer to C celled size.
That depends if you trust the specs. Remember that until yesterday it was listed as a parallel battery holder. More than likely it's exactly the same as the battery holder that comes with the X3 from IOS. That battery holder is 30mm in diameter, and the body is a little over 61mm long, and roughly 67mm long if the (used) spring is counted.
Ok, now I’m really confused! :~
I have build one of these and you need 31-32mm inner diameter to fit it.
They might be made a little differently, could be 1 or 2 mm wider/narrower...
it sounds like its the same as the ones shipped with the X3 at IOS.
so if someone has one of those.. he could tell us the timensions?
I have one of IOS X3.
D:30.0mm L:61.4 (w/o spring)/~67.3mm (w/spring)
Thanks!
Was trying to order a couple more of the Cofly 2AA lights—but looks like they are out of stock ( button is greyed out, not orange)
Any one interested in this Tank007 ES12 Super Mini Torch
Coupon: Tank007
price: $19.99
Hi travis,
Thanks for your support :wink:
Yes, the Cofly 2AA lights is out of stock and out of production now, there is no supply for this lights any more :frowning:
Looks to be a nice light. I just recently bought an Olight i3s Eos for my wife to carry. I like the style of this Tank007 ES12 as well, and the size really is great for carrying in a pocket (or purse). This light also has a higher lumens rating than the Olight. But the Olight comes with both a belt clip (or hat clip, since it’s reversible) and a key chain with a nice clip on the end. And both lights work with 10400 cells for better performance!
Now the Cofly KX-D010 2 x AAa light is showing on your site as “in stock”??
( button is orange)
Did you find more of this “out-of-production” light, or is this a mistake?
Well, another cute and small lights for gifts Santa : KLARUS MiX6
coupon: GBKLARUS
price: $40.99
HI travis, PM replied :wink:
Great price for a nice little AAA light - if I didn’t already have the Au version of this, I’d pick this one up (I’d prefer the Ti to Au anyday).
Roche M170 with CW and NW
price: $64.99
coupon: M170
Any response? 0:)
Thanks for your kind reply though :wink:
