Nope. Guess you're not getting much interest over at MTBR either? About an hour ago I passed up an opportunity to nab one for about $28 on an Ebay Auction (assuming the winning $27 bid didn't jump above mine). I decided to let it go (and I bought another cheap bike light to test/review :) ).
Not sure. I don't ride enough to say. I like the idea of it for trail riding though. I think I'd prefer it be "Low (wide flood)", Low & High (flood and throw), back to "Low", press-n-hold for off. Then press-n-hold from off to get to strobe. I don't see needing "High (throw only)" without having the "Low" flood on too.
I wonder if Gearbest would provide a "coupon code" for a discount just to get their name out there for MTBR users (I never see Gearbest listed at MTBR, so I don't think users over there are familiar with them).
I find High (throw only) very useful when biking at high speeds on the road (yes I think its suitable for commuters) especially when I need to travel for a longer time (long rides) and have to save my batteries. For MTB on trails, its Low (wide flood) most of the time.
Nightbird95, for MTB trails wide beam with this light is more suitable only for ascending parts. For descending (at least faster ones) I would use both wide and throw. But it also might be dependant on terrain and flora surrounding. My opinion, though.
I think I agree with you because the faster your speed is, the more you need to see what’s farther ahead of you.
Actually I haven’t tried doing high speeds on trails at night yet and I don’t think I have the skills to do it so I guess I’m stuck to wider beam in the meantime. :bigsmile:
I wonder if you could swap an SSX2 driver into this light and then get L-M-H modes with both LED's lit at the same time. The drivers seem to be the same exact shape. Or do you think the modes as is are better (being able to have flood only, throw only, or both)?
I didn't think of it. Good idea Garry. Will take a look if the dimensions fits. About using, both can be convinient. It depends on cycling style and personal preferences.
When you do MTB during ascending all you need on the bars is wide beam and you can see further away with narrow beam from your helmet light. When descending you have much more speed and you would like to have all the lights on full. Long beam only can be suitable for horizontal mid speed.
When commuting you mostly run at even speed. You can have both lights on all the time and only adjust brigtnes according to surrounding. High on rural and low/mid in urban where you already have some street lights. In case of commuting one light on the bar with two beams will cover the whole vision. Light on the helmet is not necessary.
I'm not telling those preferences are suitable for everybody, it's just my opinion.
EDIT: Measured the size of SSX2 driver back plate and it is same size like HD-016. So I think they can be interchanged w/o problems. Good to know if anyone would prefer different type of operating
Thanks ledoman! That's awesome, though now I'd have to buy a cheap SSX2 just for the driver. I do like the ability to run the HD016 on 4.2v though (per Lagman).
The last cheap SSX2 one I've got hands on few days ago had leds in paralell. The light was powered by usual 2S2P packet. So be aware what you might get.
Interesting light really. I don’t like the 18650 format too much though. I would prefer AA powered lights. One thing, for trailing, I think a neutral light is better.
Garry, no. I've said it is powered by 2S2P (ie. 8.4V) pack, but normaly in SS2X leds are connected in series The last one was not.
Selle was bonlighting2014 at ebay. Must say it si not good. I pulls only 0.9A from battery pack A had to add R500 sense resistor to improve output a bit.
Well, you can build your own AA 6S battery pack. I'm working a lot with Li-Ion 18650 and they are very good regarding energy density. They are also safe enough if you treat them right. AA is of course even safer.
As posted over at MTBR, I just ordered the "SecurityIng" version of this light from Amazon ($32.99). Then the next thing I knew my finger slipped and I also ordered an SSX2 (due to ledoman confirming that the SSX2 driver will mount in this HD-016). This would give both LED's on (wide & narrow) at the same time with Low-Med-High modes and a hidden strobe. Lagman's review confirmed that the original driver also runs on 4.2v input, which really appeals to me (to use unprotected cells in parallel), so I am torn between keeping the original driver or swapping the SSX2's driver. (I really just bought the X2 for the driver.) I will post back with my findings.
I really think this HD-016 will be the perfect light for me! I can finally stop accumulating all these lights! (Yeah right! ).
You might be able to run the X2 driver on 1S cells if you wire the LED's 2P.
I tried to run my X2 with 1S cells while is still had the stock 2S LED wiring. I didn't expect it run, but was curious if it might possibly had a booster circuit in it. It didn't run. It would flash once every time I hit the momentary switch though.
