I’m interested
I would take several pairs also.
I didn't order these before because I didn't know what to use it in. Now I know, and it's not available. :(
Now that I’ve calmed down some (tho still not found a suitable alternative to be able to continue the use of my heatsink’s) I really can not see how these get dropped but those stupid 4 XB / MT-G2 center boards are a higher priority than these, dump those things… There are no optic’s that thing fit’s and nothing that the quad pad’s are really good for, these boards are useful for TONS of stuff.
Should have ordered when I had the chance, I also was thinking in getting one for a TN-31 to try a XP-L led, but now that you found other uses for it, would like to get a couple too.
Anyone have one to spare?
im in
interested!
If not just to get another run done…one or two in the flashlight toolkit is always a good thing
In for 4.
Please update my interest to 40 boards (20 set’s), no reason to buy fewer than I have heatsink’s for and risk this happening again.
I have just been informed that a second run will be put in for within the week, takes about a month to get em.
Glad it’s working out. I’m in for at least one if your selling, otherwise it’s a build for me. I’ve got 3 already lined up in the group buy so gutting 1 or 2 sounds about right. Now if only in a 26650 form.
Hi Dale, is spacer required for Eagle Eye X6, Ledil CUTE-3 35mm optics and Noctigon 35mm combo? Any other mod required?
Ledil Cute-3 is 15mm tall, X6 reflector is 24mm, LED shelf recess on the X6 is ~2mm, so about 10-11mm on the spacer…
you will need a spacer.
Yes.
Search for 35MM TRIPLE OPTIC. Shipping is usually carried by a courier.
I bought the optic on ebay, it appeared to be a dutch seller so I had it the next day
I have not used it yet...
Thanks Ledoman and Hikelite.I found the same wide optic c10756 at Farnell and e-bay seller top-quality-tools .I’ll probably go with the e-bay seller as the postage is known and reasonable.
Regarding Farnell in general.
They use 48H delivery UPS courier for which they charge 5EUR no matter how much you buy. So Farnell is fast and cheap in terms of European costs.
Good to know
