I have a derwichtel triple XML that is driven at 2.8 amps per emitter to compare it with. I wanted to do a bunch of beamshots of lights thatI have, both modded and stock, but between work, all the rain we have had, and trying to prepare for the hurricane coming, I have not had time. I will be building a triple XML for a friend, and will take shots of that also. If all goes well I will be able to take at least some shots the end of next week and will post them asap. I can tell you that it looks much brighter than my triple xml, much more of a difference than I thought it would be.
Cool! Doesn't have to be copper. My monthly gets deposited on the 2nd Wed. of each month so that's when to hit me up. I definitely want one. I'm gonna power it with 4 Shiningbeam drivers and use neutral stars.
When I get time ill make one up out of aluminum. I need to repost the beamshots of this light, as I fully charged the batteries and was surprised how much brighter it is with them topped off. You really have to see this light in person, as the beamshots just do not do it justice.
The batteries are from batteryspace. Here is a link to the ones I am using http://www.batteryspace.com/lifepo426650cell32v3300mah16.5arate10whunapproved.aspx Tried the light with one IMR 26650 and 2 of the lifepo4 batts. Pulls 5.4 amps at the tail or 1.35 amps per emitter. This should be over 5000 lumens.
You can mix this two types of batteries? I wonder, I have a 2D mag laying around what I will like to give some power... What can you recomend me? This mag can hold three batteries of another model? I think that will great put in there 3 triple XP-G...
Fixed the link! You can use them together, but I am sure to not draw them down to much. They are both high drain cells, but I would not make a habit of doing it. I just wanted to get voltage up and this was a way to do it, but not go to far.
