Nice. I wonder what process they use.
Very interesting! Some competition for the modders!!!
Agreed, if they are coming from Cree dedomed i would be very interested in someone comparing it to a gasoline dedome, to see if the solvent is reducing output or damaging the LED phosphor somehow.
Interersting. Maybe they are getting these XM-L2s from Cree without the domes ? ( as Bort mentioned the phosphor would be clean and un-damaged by gasoline.
From my information Olight did some research into the dedome process and do it themselves.
This is what baidu says about it, google translate
M2X Javelot Ultra Thrower, OLIGHT for paranoia to build long-range portable LED flashlight, the flashlight range up to 800 m level. M2X-UT use节2 CR123A or one 18650 battery, through the transformation CREE XM-L2 LED, with the large-diameter optical glass with high transmittance lens coating, so that the light close to the ideal output effect. M2X inherited OLIGHT M series flashlight tactical operation interface to achieve on and off, or short-lit and quickly achieve the highest degree or strobe preset mode, the tail button by rotating the head. Possession of a frightened mind, having left another try again, imitation eagle pecking seeking regeneration broken, bent just to explore the distance. M2X-UT is a long-range paranoia in the hands of the killer. M2X-UT has a wealth of tactical accessories such as gun clip, filters, remote control switches, etc., suitable for hunting, law enforcement, rescue hand, outdoor, etc.
a) XM-L2 core flat light neutral white (5000K ~ 6000K) (M2X- UT)
b) 1020 lumens / 1 hour, 250 stream / 3 hours, 20 lumens / 30 hours, 10 Hz strobe (M2X-UT)
c) use a 18650 (must be with a protective plate) or Section 2 CR123A batteries
d ) wide voltage design, install the battery to extend the tube, you can use two 18650
e) pre-boot brightness rotating head, tail switches enable switch and dimming operation.
f) diameter 57 mm large-diameter aluminum smooth reflector cup
g) hardened tempered glass, double-sided antireflective film coating, light transmission rate of 99%
h) active thermal control based on running time, limit 5 and a half钟高亮subsequent gently down to within one minute of the initial luminance of 60%
i) the battery polarity anti-anti-
j) can be inverted to place
k) IP-X8 grade waterproof
material 6061-T6 aluminum body structure,
surface III hard anodizing treatment volume
length 162/230 mm,
diameter 63.00 mm
Weight (without battery) 235 g
Color Black
emitting diode Cree XM-L2 Core Battery 2 x CR123A or 1x18650 (with protection board)
output brightness level of 1020 lumens and dynamic line time / 1 hour 250 lm / 3 hours 20 lumens / 30 hours strobe 10HZ 1020 lumens / 2 hours central light intensity of 164,000 candela correlated color temperature of 5000K ~ 6000K
maximum range of 810 meters waterproof IPX8 impact one meter below the lake Hohai images from a flashlight we talk about people we talk flashlight
Reviews link 三支极致远射手电夜射——首次玩了一支抢鲜版M2X! - LED手电(LED Flashlights) - 手电大家谈-手电筒爱好者之家 - Powered by Discuz!
Someone in the shoudian forum says its a 3-4C tint
They also comment on a 5 minute to step down to 60% brightness
M2X UT (This light) on the left, Fenix TK61 on the right
I’ll bet they read Tom E’s thread :bigsmile:
So what your saying is: it’s a jacob A60 with a higher build quality and driver?
Me Like! And from Olight no less! Oh Saaaaaaannnnntttaaaaaaaaa………
A factory dedome was bound to happen sooner or later. Too bad I couldnt get Acebeam to attempt it a few months ago.
“Possession of a frightened mind, having left another try again, imitation eagle pecking seeking regeneration broken, bent just to explore the distance.”
Thanks AlexGT. That has got to take the prize for the chinglish translation funnies…
Wow. Strange world this is where a popular manufacturer is designing a light out of spec by using a dedomed LED. Damit Alex. I really want a Jacob now… :heart_eyes:
That’s almost exactly what I was thinking when I saw AlexGT’s pic in post #11. Looks kind of like an A60?
Nice that reminds me of a refined & improved Jacobs A60.
More photos:
this light will be out about next Wednesday or Thursday.
if some one are interested in making a review, pls contack me, we can get one or two sample tomorrow.
Neal
Thanks for the information Calvin, at last more choice for dome / dedome version of led.
I’ve only got a handful of reviews under my belt but I have a new blog im trying to get more stuff posted on and on top of that, this particular format (1x18650 thrower) is my personal favorite, I have many conpariable lights in the class to put it up against. Please consider me for a review.
