I disagree about that, the higher the voltage the less current needed, less current less heat.
The 3 cell would be the best pick and I would be careful about eBay lights and be concerned about genuine products
Now THIS is an interesting find. Thanks to Jarosf for reporting it. Welcome to BLF by the way, nice contribution to start!
So how does this work with 4xAA? Do you just jam them in there, or do you use some sort of container? Sorry, I don't own this light (yet), and I'm seriously interested in it now.
@Fran: Why can the 4xAA configuration only be used with the 3-cell version?
What about 1x18650?
So, where to buy this at if I want the 4xAA option? CNQ or Manafont?
My guess is that the 4 AA's are in series, so the 3 cell would be needed for the length. I too am very interested in this light. Ebay also sells the 3-cell version with the extension, but it's $57.00.
Last time I checked, Watts = Heat, not Amps. Current * Volts = Watts.
10Volts at 1 Amp = 10 Watts
1Volts at 10 Amps = 10 Watts
With LED's of today, roughly 80-85% of that energy will be wasted as heat, so a 10 Watt LED will generate about 8 or 8.5 Watts of Heat. Volts and amps are irrelevant by themselves, it's the product of them that matters.
That example is just wrong. You probably mean for the same power transmitting across a system, a higher voltage means less current and loss within a given piece of wire with set resistance (and also less voltage drop across the wire itself), not the system as a whole. The temperature of the wire is still inherently a function of the power dissipated within it, same as the system.
in the real world some times things differ from whats is schooled. my example was from a hobby charger main power leads.
i have a good example about the diffrence from 12v to 24v 4wd,s lighting, but its just to much for me to type are a hard days work.
ive always thought and was tought the higher the voltage or the higher the voltage can be maintained the less current draw that is needed to maintain its given requirments.
im crap with words but i think you might be getting what i mean. voltage sag might be a better example.
The confusion here is between the system as a whole and the wire. The wire is only one component within the system. The wire is dropping 24v. It has a set resistance and its power dissipation is directly proportionate to the current across it. So for a system that maintains a given power usage (like our driver above, which is specifically designed to function in this way, not as a natural consequence of a trivial circuit), it does mean that slightly less power will be dissipated across the wire. However, the vast majority of the power will still be going to the emitter.
ive been using my TrustFire TR-3T6 heaps and it is still going strong, been using it every night just about and last night we took it on another long bush walk spotting kangaroo,s and rabbits with my daughter on high all of the time.
today i tryed it on 6 AA Duracell 2650 mAh rechargeables i had to use all the extention tubes from the TR-3T6 3 x 18650 and my TR-1200 the current draw was 2.81 amps the batteries where fully charged and where 9 volt combined.
next to the torch is a 30 cm or 12 inch ruler to show the extra lengh it still felt solid, i could not notice any lose of light with my eyes and the torch still worked well but is close to the lenght of a 4 or 5 D maglite ? and could be use as a base ball bat lolls
Perfect timing! My TR-3T6 I bought myself for my birthday came this morning, my birthday. :)
What an awesome light! The finish is great with no nicks or blemishes. Threads are perfect and smooth. All o-rings are the right size and seal nicely. The head is really heavy and takes a while to get warm compared to my other XM-L torches.
The one thing I'm disappointed in is a lack of o-ring for the lens. Does anyone know where I can get an o-ring (preferably GTID) the proper size for it? Did anyone else have that gasket on theirs?
Output, without a second TR-3T6 to compare directly too, seems to be the same with either 2 or 3 cells. For now I'm running it with only two but I can't wait for tonight when it gets dark! 8)
mine has a o-ring infront of the glass on the bezel and an alloy ring after the glass, then a o-ring on the head where the bezel screws onto the head and double o-rings every where else.
it is hard to see the o-ring infront of the glass as its tight but there is one there on mine, try looking hard between the bezel infront of the glass.
