The driver has a second ouput (but not marked in this) which has a good output, the main down side is a hollow pill, trying to get a mate to make me a middle for the pill
I just moved output over and swapped in a XP-L on noctigon (21mm) and it easily has more output and a smaller hotspot square than the Zuesray I would say at least 25-30% more lumens.
It also takes a 26650 battery and only costs £5.22
Yeah, he only uses protected 18650s from reputable vendors and charges them on his desk while he’s working so he can keep an eye on them. Never drains them to cut off.
Of large ones, I like the insides of the Uniquefire UF-T20 and the outside of the Yezl t9. The Uniquefire UF-T20 is well made with a nice short focal length glass lens, XM-L2, etc. but it is pug ugly. I like lights made by soldering together pieces of copper pipe, but I don’t like an NC machined shape to look like it was patched together from plumbing surplus. It feels bad in the hand too.
The Yezl is my most beautiful light, with a smooth elegant unusual shape and fine detail, but both the fancy drivers quit the first week, and the thin long focal lens is only good at extreme throw and extreme flood. With replaced drivers and lenses they are my best lights.
In a smaller size, it is the SK-58, though most others have their niches. The TrustFire Z8 has lovely stainless steel threads and enough aluminum for cooling. I like an UltraOK SK-68 for more than two amps, because of the cooling. The Coast HP1 and others of its type have high optical efficiency even in throw mode, unlike simple converging lens zoomies.
I agree about the Zeusray for intermediate size. But there are other good lights in its class, such as the SK-73.
The JAX Z1 looks good, except for price and what looks like a thin long focal length lens that will give an unnecessarily small spot with little improvement in throw.
The UniqueFire UF-1405 looks like it would work well, but is ugly and sharp cornered, like the UF T20.
Quite similar yes. Pop lite do a T34 which is 4AAA and has modes. Very P7 like. In fact I suspect they come from the same factory. The T33 is a tad smaller and single mode. But is really nice to use.
Another thing. Some of the high lux zoomies, I wonder how useful they always are. I’ve an XP-G2 with a Qlite 3.04A driver in a 26650 sized zoomy. It looks impressive. But the reality is the same Led and driver in a C8 throw further and is more useful general purpose. The beam is just too narrow on the zoomy. De-domed would make it smaller again. It is very good on flood however.
It’s possible to make a zoomie with a Wavien collar. Mount the LED on a pillar (like in an LED Lenser), and attach the collar to the sliding bezel. When the bezel is retracted in flood mode, the collar would slide below the LED out of the way. If done right you’d get a nice wide flood together with the maximum possible amount of throw, though the overall light might be a bit longer or wider than a typical zoomie.
To my knowledge, nobody’s ever built a light that does this though.
I see what you are talking about know. A TIR or reflector outer ring, like a Coast HP1 or a Fresnel lighthouse has. That allows better optics in a small space or a very short focal length. It also allows two elements that focus differently, as in the HP1.
It does not give more throw than is possible with single element optics. That is limited by the luminance and the aperture, and refractive lens zoomies approach that limit.
What no one has done yet is to carry it another step and use more than two zones. There are “Fresnel lens” flashlights that use multi-zoned lenses but none with multiple refractive and multiple reflective zones or elements, like the optics that Fresnel actually made.
I just recently got a JAX Z1, up till now I’ve hated zoomies, I built a UF-1405 for a friend and liked it but it was way to large to be practical so when a chance to pick up a Z1 cheap came along I jumped on it and I couldnt be happier. It’s replaced so many light’s it’s pretty unbelievable how useful of a light it is. I’ve only owne SK68’s (and some other 1AA’s) and an SK98 and a TF 26650 zoomie, never a T20 so I cant comment there but the Z1 is really a nice light. Mine does 238kcd for nearly an hour on a KK at 4.8A (maxes out at about 5.2A from a 25R and heat’s up instantly so you know its sinking well.
All in all no I dont regret not getting a zoomie sooner but had I waited longer to get this Z1 I would have regretted that. It’s such a useful light. Especially for city use where you don’t want light to go where you don’t want.
The tail threads on my Zeusray are on the loose side. This sort of thing might be caused by thermal expansion during rapid NC machining. I junked one $3 SK-68 for loose and short tail threads.
