I forgot to tell that my current bike i working out is KLX140 with only have led projector as low beam (no high beam)
I put this scooter bike high beam as reference, my goal at least my KLX140 highbeam near this scooter (bixenon) HID highbeam
Both would be best, but the MT-G2 is really tricky to dedome and you can easily damage the phosphor layer.
If you break the LED you can put another one in there. The new cree XHP50 would be a good candidate and would give you more throw at same output, but it’s not available yet…
Just tried it with 5mA current and 1amp still running no problem
What purpose those tiny wire inside emitter ??? :~
But turn to violet color to my eye :8)
I would probably try to dedome the LED from the light (let it get really hot and then gently try to pull the dome off) and if that doesn’t work, buy a dedomed one…
Those three resistors (R270, R270, R33?) are most likely your voltage sense resistors. You can solder another one to the side of the small one (so it's easier to remove) and see what happens to current. There are formulas if you know the voltage drop across the bank, but I would just try adding one R3ish (.3 ohms) resistor at a time and remeasure current to the emitter.
A good way to rig the driver so you can add resistors and measure without reassembling the light is to solder wires to connect to your cells and then connect one of the LED leads to a DMM and then the DMM to the emitter. Here is an example. It's a little confusing because there is another driver piggy-backed in it. The fat Red and Black wires going straight up and out of the picture are going the cells. The L- wire is going down the DMM and then the DMM is feeding the emitter. Shorter wires reduce resistance losses.
Thanks for suggestion
Those R270 + R270 + R330 in parallel
according to parallel resistor calculator its about 0R095
I have measure current with clamp meter at high is about 2.1A
anyway how to make this driver have only one mode (high only) ?
No prob. Your calculation sounds right to me (little less than 1/3 of .3 ohms).
One mode is real easy if you can identify the MCU pin that is Vcc (+ input) and the pin for PWM out. You then just then add a jumper between the pins. You will no longer have LVP or thermal protection, if your driver even has those. You pull the MCU if you wished as it will be consuming a tiny bit of power, but controlling nothing.
This one use PIC12F629
If i remove that MCU it will always on to high mode?
I thought those IC that “drive” mosfet for buck regulation (sorry i’m new about MCU thing)
I had try remove all three resistor and replace it by 0R047 (since this only low value that i had), change SS54 to V8P10 diode, and change those 33uH inductor with a “bigger” one
Now, it draw 4,2A to Load, awesome :cowboy_hat_face:
