and they have optics to fit the spacing on those triples.
I’d guess the Sinkpad and Sinkpad 2 emitter positions are the same, but I don’t know for sure.
I know there are other spacings out there — the “Endor Star” triple Rebel from LEDSupply is different (LEDSupply sells the usual variety of optics to fit that, of course.
And there’s the whatever-the-heck in the DQG Tiny 26650 — different spacing yet again, and no idea who makes the different optic to fit that much bigger diameter.
The optic’s that fit the sP2 mounted triple rebels are the exact same carlco 105xx series as used with the XP Noctigon’s! Easy to get in about any beam you want and about about $2.25 a piece (tighter is always better for color/tint mixing, l’ll probably try the 10507 scuffed up or the 10511). The rebel emitters are positioned correctly so their domes are in the same position as cree xp domes in a Noctigon.
I may have a go at it some time then. A brute way to drive it is with individual ramping of the three (or four) channels, with memory. Without going through your many great driver posts again (my memory is like a sieve), wasn't that something you already had build by any chance??
I think that your way with two different white emitters is easier and works just as well. The three-led set-up that Philips suggests is probably a bit more efficient because less phosfor conversion is taking place and in the 'real world' that is pretty important, for a flashlight that is hardly interesting.
The link goes to the deep red XP-E, not to the an amber led. And still, however attractive, up to date and of latest bins your selection of leds is, 33 dollar shipping kills any small order attempt from outside Australia :-(
Is there a source somewhere for the PC Rebel on something small and round, like a 12, 14, or 16mm base?
(I know I can get them on a 10mm square (Luxeonstar) or 20mm star (LEDTech))
Or, what empty base do they fit on and where might I find it? I can warm up the heat gun
I have not seen anything other than 20mm and a 10x10mm square board for the Rebel. A 16mm base can probably be made by filing/sanding down a 20mm one.
Actually I have quite a stash of 20mm Rebel Sinkpads and I'm not at all going to use them all. If you are interested I can sell you some for what I paid for them (if I remember well 0.70 cents/piece) plus shipping (2.20 dollar to the US).
I have some 20mm boards also, i am lazy/reluctant to start filing on them, not sure how much I can remove without hitting a trace that I don’t want to file away.
I’m hoping someplace sells Rebels mounted. Or even any appropriate bases I can learn hot air work on, in 12-16mm intermediate sizes.
I tried a Luxeon Z a while ago, but making a copper board for them was a pain. I still have the little cyan luxeon z flashlight, gives a ton of light :-)
I just ordered a triple Luxeon deep red mounted on a direct thermal path SinkPad II. Deep Red Rebel
It says max current 700mA, but also states that “Higher drive currents may be possible, but will require careful design of a suitable cooling system.”
I plan to run this DTP triple in an S2+ with a copper heatsink, and was wondering how high in current I can take it.
I have one of these leds and did a quick output test on a Rebel Sinkpad before doing the mod at the time. I never documented it but I think I remember that just like most colour leds 1.5A is a sweetspot, over 2A the output already drops.
