I’ve got 24 boards on the way and a few left on hand. I, uh, seem to go through drivers a lot lately. hahaha
Again, let’s not jump the gun. The datasheets clearly show the current FET in a good light, and as far as we know “better” alternatives are all more expensive. IMO the thing to do here is test with what we’ve got vs what we’re trying to meet/beat: the Vishay 70N02. An extra dollar or so per driver really is quite a lot. I’m not saying not to test the more expensive FETs at all, but step one is to see what we’ve got now!
I had bought 3 Convoy M1’s for comparing components before. I can use one of these to put an A17DD-S08 in and compare side by side to the 70N03 version driver. Shall I do so?
Edit: More or less they’re already set up that way. One has the prototype of this driver, one has Richards Moon Qlite, and one has C_K’s Ver 3.1 driver. All I have to do to compare the A17DD-S08 to the 70N03 driver is swap emitters in the proto model. (It’s got an XP-G2 where the 70N03 has an XM-L2 U3 1A)
Sounds worthwhile to me!
Ok then, tomorrow I will build a fresh new A17DD-S08 driver and a fresh new BLF17DD Ver 3.1 driver and put the same UI in each. I will then put the same XM-L2 U3 1A emitters in each M1 (from same batch and purchased together) and use the same cell for testing. In this way the test bed will be as level as I can make it. I won’t even put any of my well squeezed amperage rocks in either light.
Sounds nice if i ever get to the point where i have all of this figured out so i can start flashing firmwares myself, i will look forward to try it out if its ready then, Good luck
Checking the Vf of the emitters will verify the levelness of the test. Maybe also compare output at lower cell voltages.
I agree wight about not jumping the gun, just making an offer to our mega mod members who might want to eliminate this as possibility.
I built up some drivers last night, not done - not much time lately. I'll do a direct swap in the same X6 of drivers, then see (hoping this eve). I'm testing with an old XM-L2 U2 1A now to eliminate the de-domed XP-G2, so hopefully that's a better test case than the de-domed XP-G2.
Really could all be the Vf of the specific LED/MCPCB I'm seeing - dunno, but would be nice to get an understanding. In my other builds there are lots of variables - some with e-switch, some with the LED+ wire bypass of the driver (not always the best), different LED bin's/tint, etc. The only obvious thing in comparing the 3 driver designs is the original BLF v1.0 seems to have the thickest ground ring, but that's probably not exactly true - the others could have a thicker one, but not all exposed.
Are you referring to the original, or the latest? This is exactly why I didn’t want Mattaus to reset the version numbering in the way he did. You say “original” but in the same breath say “v1.0” which is the designation for the latest version which Mattaus has released.
I can build the original and compare it to the A17DD-S08 if that would be more prudent than the Ver 3.1?
By original , I mean the one with no ground contacts on the spring side, the original , aka, first board.
I don’t really have an opinion on that.
Ok, I’m about to build 2 lights…one with an A17DD-S08 and the other with a BLF17DD Ver 3.1. I will use AVRGCC44 with the A17DD-S08 for the 22,000 R1 to work at 3.0V and 2.8V and the AVRGCC45 with the BLF17DD Ver 3.1 for the 19,100 R1 to work at 3.0V and 2.8V. All other settings are the same.
This has 7 mode levels at 0, 3, 9, 27, 73, 140, and 255.
I’ll be back!
What is a BLF17DD v3.1? Am I missing something here?
The way to go is to use different drivers in the same light, with the same emitter and the same LED wires. That way there is only 1 variable changed. Using different emitters is a bad idea when you're trying to test for 0.2A difference.
Done! I have 2 identical M1’s but different driver styles. Before assembling the emitter/star into the pill (I reflowed them both) I checked Vf on a Sanyo FJ and each had 3.61Vf at 5 seconds on direct drive. These are XM-L2 U3 1A on the new 20mm Noctigon that has temperature sensor pads and the contact pads are closer to the edge (wider stance)
Both have the large bronze phosphor spring from Intl-Outdoor, upside down, and a copper disc soldered to the wide end for ease of use with various cells (flat tops or button tops) No spring bypass due to the spring type and no spring bypass in the tail cap of either light.
So, what kind of tests do we want? Vf on the same cell fresh off the charger each time?
Amperage on the same cell, freshly charged each time?
Amperage in the lower modes simultaneous to the Turbo reading? Or separate from that reading?
Lumens in each level, again on the same cell and freshly charged for each light?
What am I missing?
The BLF17DD Ver 3.1 is the last variation on the 70N03 FET driver, rearranged by Cereal_Killer for an easy Zener modification with Zener pads on the board. The difference between 3.1 and 3.0 is that the Voltage Monitor set-up is taking it’s reading straight off the batt + pad for the spring, before the diode and or Zener. Dan didn’t change the silk screening so it still reads Ver 3.0, but the trace can be seen coming off the resistor bank for the Voltage Monitor.
I am not organized enough, engineer enough, patient enough or willing enough to use the same emitter on different drivers and do all that testing. I have 2 emitters out of the same tape, side by side, that both test at the same Vf on the same cell. That will have to do or I’m done here and will just use the 2 lights and call it even.
So I have 2 Convoy M1’s that make just under 5 lumens in moon, 1405/1455 in Turbo. Worth the doing at any rate. 4.59A from one, 4.50A from the other. Head to head each holds it’s own.
Looking good. 0.09A is nothing. All of the lights I've built with the small LFPAK have all seen very similar performance to what I usually get out of the big FETs.
While the A17DD-S08 did indeed pull .09A less than the BLF17DD Ver 3.1, the A17DD-S08 is the one that logged 1455.9 lumens!
Not enough difference to be statistically significant.
OT: how do you like the through hole wire vias on the 3.1 driver? I personally would rather have a flat pad to solder to, but I'm wondering what everyone else's opinion is.
The through hole via’s are nice at 22ga, a PITA at 20ga. Forget about 18ga. (Actually, I’ve split the end of 18ga and run each half through a via, works ok, still a PITA. Not pulling any pads off though.)
I like the extra ground via beside the FET ground leg on the A17 board and the big pad is good for soldering the LED - lead to. The middle of the board positive LED lead is a bit on the tricky side though. Not horribly bad but fairly easy to mess up if you jitter instead of jigger. Shimmy instead of shake? You know what I mean….
The microscopic switch+ via on the Ver 3.0/3.1 board is nuts! And the location is tricky as well.
Single sided makes up for a lot of things though, love that aspect! Really makes it easy in a lot of lights, piggybacking too.
Edit: Point being on the comparison…the smaller FET meets or exceeds the performance level of the large 70N03.
