yesterday I tore open a battery pack from an old laptop.
the battery pack said it was 10.8V and google said the model number was 4400 mAH.
I was told:
If that’s the case, they are 3.6V at 2200mAh each. 3 in series, 2 in parallel for a total of 6.
I threw these on a charger, my charger has a cut off at 4.2V with the protected 2600mAH 18650's I've been using.
I haven't had any of these batteries charge higher than 4.16V after several hours on the charger. I put one in my flashlight and it seems to be doing as good or better than my other (expensive) batteries I bought from monsterflashlights.com. (Which may be getting wore out I charge them and use them daily.)
question is, is there a difference between the 3.6 and 3.7v batteries? I assumed they all charged to 4.2?
and what, if anything at all, is written on each cell?
and did you read this?
P.S., no reason you should trust my opinoin, I’m just some stranger on the Internet.
This search may answer your question, if you pick and choose which result you pay attention to.
Most of them look right to me:
I would probably guess they are Sanyo red cells w/ the red ring on top, the 2600mAh have the blue
As long as the voltage of the individual cells were not too low below 3vdc then they will charge just fine at 4.2vdc, termination voltage is dependent on the CC/CV charge pattern
What expensive batteries did you get from monster?
OMG!!! I just looked at their prices…not no but HELL no…daggum!
First of all they are re-wraps, a 14500 for $8~ good grief!
A re-labelled C8 for $65~ cmon this dude is robbing people blind!
They say LG Chem on the + side too, but here's a pic of the battery itself. I am not good with colors, but I'd say it's a beige wrap? Looked yellow yesterday in low light conditions when I took them out.. Came from an old apple iBook.
http://i60.tinypic.com/11t3fxs.jpg
not sure how to attach a pic here yet this is a different post editor than any I'm used to.
There’s no difference between a claim of 3.6 and a claim of 3.7.
Old cells are likely not worth much effort.
You’ve been way overpaying for stuff buying from Monster.
Take a look at what’s offered at mtnelectronics.
What charger are you using?
You’re taking the standard precautions with where, and when, and how you charge, assuming you have a safe charger?
You know not to inhale if a cell vents?
Basic stuff. Worth spending some time reading.
Just another interested amateur here. You’ll get varied opinions.
haha 11 years old!!! These were brand new state of the art never need another when they were first sold.
I'll run a couple through a few cycles and see how they do. If I gotta pitch em it's not a big loss or anything, worth a try.
I have a cheap charger but it's been good to me, always cuts off at 4.2. I plug it into a surge protector in a metal building that stays warm even tho nobody's usually around, not much in there that would catch fire.
that control panel looks familiar…
btw we know not to expect much from really old batteries like those but have been surprised a few times.
as mentioned the monsterflashlights.com stuff is waaaay overpriced.
and the batts are in the “whateverfire” class.
yes old laptop pulls are often better.
welcome to blf!
another ohioan spotted
