very intressting! i might get a X6 and one of these!
The second design is the one for the 32mm noctigon and cute optics, correct?
If so, put me down for one copper at $12.50
Thanks
For me…
3 Copper Quad at $18 ea. = $54
2 Aluminum Quad at $12 ea. = $24
4 Copper Triples at $12.50 ea. = $50
$128 + Shipping.
accepting order outside of U.S?
yes and i can fit alot in a priority box that ill be using, so shipping for US buyers will be $5.25 unless u like me to ship it in a bubble mailer
OUTSIDE of the US my ZIP CODE is 43452 if u like to look it up your self ?
Correct
I’ll take (1) copper quad @ $18ea
and (1) aluminum quad @ $12
Would bubble mailer be cheaper for 1 piece? I’m not worried about a chunk of metal getting damaged
i think it will around $3ish to ship but that's if u want tracking that will add more so about the same really ?
Any “everything you need” packages except the EE X6, for triple or quad?
Which is for the triple or quad?
I want 1 in aluminum but need to know which…what is the small plate for vs the full size one?
Just ordered the quad board w/ optic…need the full size aluminum one
one $12 aluminum, for sure.
Post #35 and #37 should explain https://budgetlightforum.com/t/-/30722#node-36279
and the small plate (triple heatsink) is for the copper 32mm board with this optic (C10754_CUTE-3-SS)
http://intl-outdoor.com/noctigon-xp32-advanced-direct-thermal-path-copper-mcpcb-2pcs-p-808.html
and the larger heatsink is for the quad for the copper board kit that's sold here >> http://www.mtnelectronics.com/index.php?route=product/product&path=68_69&product_id=416
Not sure what u mean but im trying to get it all as a kit MINUS the SE X6 host
So im going to be stocking the heatsiks on post 1 and OPTICS posted ^^^^ for the guys that's out of the united states so shipping for them is cheap
I’m in for a copper sink for the triple for $12.50+ship.
Hello.
I would take a copper for the triple, $12,50 + shipping to Germany.
Regards
i’ll take 1 copper triple.
may you suggest which lens would be good?
I would take 2 trippe sets: the metal pad plus the bindle PCB + optics- still havent desided Cu or Alu…
Nitro, would you be so kind to point out the weight of the Cu and Alu tripple and quad heatsinks
Excuse my ignorance but whats the difference between C10754_CUTE-3-SS and Carlo optics?
Thanks for your efforts and support m8
The Sample is off to Dale, the 2 optics that i posted is for the 2 different heatsinks,one for the 32mm copper board and the other is for the 20mm copper board.....if u have another optic that i did not see can u post a link ?
I will take one of the $12.50 copper triple versions. I think postage to AUS will be $6.55? Can you confirm if that is correct?
Do you sell the xp32 triple mcpcb along with the ledil cute optic as an addon?
The OP didn’t seem exactly clear about what optics you offer.
