i think it will around $3ish to ship but that's if u want tracking that will add more so about the same really ?
Any “everything you need” packages except the EE X6, for triple or quad?
Which is for the triple or quad?
I want 1 in aluminum but need to know which…what is the small plate for vs the full size one?
Just ordered the quad board w/ optic…need the full size aluminum one
one $12 aluminum, for sure.
Post #35 and #37 should explain https://budgetlightforum.com/t/-/30722#node-36279
and the small plate (triple heatsink) is for the copper 32mm board with this optic (C10754_CUTE-3-SS)
http://intl-outdoor.com/noctigon-xp32-advanced-direct-thermal-path-copper-mcpcb-2pcs-p-808.html
and the larger heatsink is for the quad for the copper board kit that's sold here >> http://www.mtnelectronics.com/index.php?route=product/product&path=68_69&product_id=416
Not sure what u mean but im trying to get it all as a kit MINUS the SE X6 host
So im going to be stocking the heatsiks on post 1 and OPTICS posted ^^^^ for the guys that's out of the united states so shipping for them is cheap
I’m in for a copper sink for the triple for $12.50+ship.
Hello.
I would take a copper for the triple, $12,50 + shipping to Germany.
Regards
i’ll take 1 copper triple.
may you suggest which lens would be good?
I would take 2 trippe sets: the metal pad plus the bindle PCB + optics- still havent desided Cu or Alu…
Nitro, would you be so kind to point out the weight of the Cu and Alu tripple and quad heatsinks
Excuse my ignorance but whats the difference between C10754_CUTE-3-SS and Carlo optics?
Thanks for your efforts and support m8
The Sample is off to Dale, the 2 optics that i posted is for the 2 different heatsinks,one for the 32mm copper board and the other is for the 20mm copper board.....if u have another optic that i did not see can u post a link ?
I will take one of the $12.50 copper triple versions. I think postage to AUS will be $6.55? Can you confirm if that is correct?
Do you sell the xp32 triple mcpcb along with the ledil cute optic as an addon?
The OP didn’t seem exactly clear about what optics you offer.
Post #13 explains the optics im buying unless u guys want something else if so please post a link ?
Mitko, the CUTE-3 optics are from Ledil, not Carclo, and are 35mm to fit the X6. Each TIR within the optic is about 20mm in diameter and some 14mm in depth. The Carclo optics are 24mm in diameter for the Quad and fit the 20mm Quad board. Each optic is about 10mm in diameter and 6mm in depth.
Beam profiles are really nice from the bigger TIR in the CUTE-3. It has a honeycomb pattern on the surface for diffusion, and sanding it smooth then polishing it allows the internal build to show clearly but otherwise doesn’t add as much to the output or beam profile as I would have thought.
As you see here, the heat sink has a narrower opening for the 24mm Carclo optics, one of the primary reasons I made the sink like this in the first place. Also because the optics are so short.
Here you can see the honeycomb surface pattern on the larger CUTE-3 optics
Compared to sanded and polished
Here’s a look at the polished version (wish they made them this way) in the X6
Compared to the stock lens
And here’s a look at how the Noctigon sits in the X6, on top of the heat sink/spacer…
The Noctigon has to be filed or sanded slightly to fit into the head of the light. I lay the file on the table and make strokes on the edge while turning it slightly, rotating it in my fingers a bit for each stroke. This keeps it round and it only takes a few minutes.
Here’s what the aluminum sink looks like sitting on the emitter shelf, Noctigon waiting to go in…
See how vastly different the two builds are? Each according to the needs established by the optics and mcpcb.
Hope this helps.
I am interested with:
2x Triple setup:
- copper spacer
- copper mcpcb (if available)
- optics (medium)
+ international shipping.
My Zip Code is 43452 everyone can check the postage here http://postcalc.usps.com/
Let me no how u did it like priority box or padded envelope if u order 1 copper it will not be over a pound
Yes ill be offering them as a package but it will be extra from the prices of the heatsinks, The xp32 triple mcpcbare $10 for 2 pieces so if u want 1 it will be $5 extra plus the cost of the optic witch i think its $2 ? so it will be the cost of the heatsink +$7+S/H
Hi.
A padded letter for one triple copper should be okay, right?
To Germany it will be $12,60 ?!
Regards
a padded envelope is fine i just do not no how to check everyone's shipping charges
So my best bet if u guys can check it here and my zip is 43452
Just posting that ill be gone for a few days to a week (leaving now to a funeral) but ill post here and there since ill be down in the woods with no internet................ BYE FORUM
