cajampa,
I measured the depth of the driver side of the head, from the rearmost edge, it was 8.21mm
Still no progress getting the head apart though, so if anyone does figure that out, please post!!
Thanks,
Jim.
cajampa,
Thanks,
Jim.
Thanks Jim, 8,12mm should be plenty to get one of wights small 12mm fet drivers in there, and i already like the tint of the stock hugsby so i think i will try to upgrade one when i got everything i need to build them.
It is weird we can’t figure out how to disassemble it.
When the lens is out of the head is it possible remove the reflector then? if so could you measure how deep & wide it is? i like the reflector in the Hugsby so i thought maybe i could use it to upgrade the reflector in the Jexree Mini.
Have you seen this AA/14500 Hugsby it got modes and is lithium ready, i will probably get one sooner or later…….
Hi,
With the lens gone/cracked/removed, “no”, I cannot remove the reflector. That part of the head is one piece, i.e., there is no ’bezel ring” to remove, so basically, the reflector (and the emitter+star) are stuck inside the head, unless I can figure out how to take the head apart.
I’m getting close to putting a hacksaw on this darn head, just to see what’s inside, if nothing else.
Re. the 14500, no I haven’t before, but I want to get this AAA/10440 modded first.
Before you saw it in half, could you try to fix it in a vice with something to protect the anodizing between and try to wrench it on the threads or maybe the other way around fix it by the threads, that is one other way had thought to try to open it when i get some new hugsbys for the sacrifice, because i am not sure even if it could work if it is even possible to do non destructively.
If that is not working maybe try heating it up before, if it is epoxied in there.
If that don’t work, then i am totally out of ideas how to get this head open, well maybe if it don’t work and you take a hacksaw to it finally, we can draw some conclusion then on how they have put this head together.
Good Luck & remember to take some pictures so we hopefully can get some leads on how to disassemble it.
Well, I was able to get the brass ring out, just grabbed it with a small pair of needle nose and pulled, and it popped out.
But, the head? No luck. I’ve tried heat, and also some BGA epoxy remover, but it just won’t come apart. At this point, I’m still not 100% sure where the head comes apart, but looking at it, it HAS to be at the driver end of the knurled area. But even knowing that, I can’t get it open, so it must have some super, super glue or something :(!!
EDIT: This shows where I think (guess) the joint is:
Ok, good to know that the brass ring isn’t glued.
On you picture i see that your bottom o ring above the threads is still on, that is where i think the joint is, if you take off the o ring you will see uneven material where the bare aluminum & anodized aluminum meet, that is where i suspect the seam with glue are.
4,7mm to 5mm down from the lower part of the knurling.
Of course I don’t actually have one of these in hand, but it’s pretty common for the anodized portion to be larger than the bare portion on a solid object. The whole light was anodized and then machining operations were done to it (eg it was turned on a lathe). This applies anywhere that you see bare aluminum.
Looks like a good guess to me. What tools have you tried so far? Strap wrenches? Wrapped vice grips? etc?
Are you willing to destroy this one “for science” since it’s taken a fair amount of damage already?
Ok, it’s done, and the joint is where I surmised. I tried to cut it to make a cross-section, but it came apart before I was done. Pics below.
I don’t think it was glued, but just really darn tight? I also don’t think it was reverse threaded, though I’m not 100% of that now.
You can see the tiny emitter board:
Hopefully these pics will help someone come up with a way to open this head up without destroying it… and if so, please post (incl pics)?
^ Wow, talk about taking one for the team. Thank you Ohaya. Anodized threads that appear well cut, nice. They do appear to be normal right-handed (clockwise) threads. There appears to be some type of substance stuck to parts of the threads in the second to last picture. Doesn't appear to be any of the typical thread lock colors though. The below table is from here.
Typical properties of thread-locking fluids [4]Type | Typical color-code | Torque to break free | Torque to continue turning | Temperature range | |
Low strength | Purple | 62 in-lb (7 N-m) | 27 in-lb (3 N-m) | −54 to 149 °C | |
Medium strength | Blue | 115 in-lb (12 N-m) | 53 in-lb (6 N-m) | −54 to 149 °C | |
Medium strength surface insensitive | Blue | 180 in-lb (20 N-m) | 62 in-lb (7 N-m) | −54 to 149 °C | |
High strength | Red | 230 in-lb (25 N-m) | 225 in-lb (25 N-m) | −54 to 149 °C | |
High temperature | Red | 180 in-lb (20 N-m) | 270 in-lb (30 N-m) | −54 to 232 °C | |
Penetrating | Green | 90 in-lb (10 N-m) | 310 in-lb (35 N-m) | −54 to 149 °C |
Hah! Good work.
Now that we can see how the head is designed, I guess that we (anyone) has to figure out how to open it without damaging it?
So far, I’ve had no success with the others I have (I just got 2 of the XP-1s in).
Jim
On jerm03’s original thread, there was some mention that there seemed to be some difference between the stock XP-1 driver (which doesn’t work with 1x10440) vs. the stock XP-2 driver (which works with 1x10440)).
I now have several XP-1s and the one working XP-2, and looking at the driver externally, there is a visible difference, so, although I haven’t taken the driver out of the XP-1, I’m pretty sure that they have different drivers.
Here’s a pic of 2 of the XP-2 drivers (on the left) and 2 of the XP-1 drivers (on the right):
As you can see, the driver boards do look different.
You didn’t answer my questions in post #26! What have you actually tried?
I’ve tried with the head in a vise and using pliers and strap wrenches (the head is tiny). I have some vise grips, but I haven’t been able to find them so no, I haven’t tried those.
As I mentioned in that same post, I’ve tried heat (boiling the head in a bag, heatgun, etc.) and using BGA epoxy remover.
Yes, done that :)… Maybe someone ELSE could contribute to the effort (don’t mean to destroy one, but to try stuff).?
Don’t look at me! 0:) I’m more of an 18650 person for now. All I can contribute is suggestions / strawbossing.
Wrapping the two parts in leather or rubber and then gripping with large tools may be good. Channel locks or even two large pairs of slip-joint pliers maybe?
A thick wrapping of tape can also work of course, but that seems a bit wasteful if the leather or rubber will work.
EDIT: also I see that you didn’t mention freezing the head. That’s another thing to try, some types of glue will free up / whatever when frozen.
Thanks ohaya, now we know where the joint are, i can’t wait to get my other Hugsby’s so i can wrench the hell out of them :evil:
It should be possible with the right tools, that part is a lot more sturdier than where i thought the joint was at the top of the threads.
Hi,
So i finally got my extra XP-1’s & XP-2, so the first thing i did was to take the XP-2’s head and stuck it on my XP-1’s body with a Efest 10440 inside……and it didn’t work i thought did i break it? but no it only needed a button top to work, so i stuck a little 5x1mm magnet on the top and it worked GREAT very nice and of course much brighter.
I used the XP-1 head on the XP-2 body and that got it much brighter also very nice, I gave that one to my father, i like the shorter XP-1 size more.
And while i fiddled with all the heads screwing and unscrewing i suddenly hear a different noise from my original XP-1 head, and i looked down and SUCCESS :bigsmile: i had got it open just by chance :).
Now there is something more to this when i got the XP-1 initially i wanted to take out the driver, so i tried to solder and use a solder braid on the bumps on the driver board, luckily i failed so i heated up the head maybe 3-5 times maybe more, this obviously broke the thread sealant and suddenly the head just came apart in my hand much later.
This is my original XP-1 head with the partially removed solder bumps
Hugsby XP-1 dissasembled
Including the lens and top o ring.
LED without the protector
Head with the plastic protector
The mcpcb is 8x7mm and sits on a tiny shelf……that could be plastic i don’t know (the bottom looks whitish) i will probably order some upgrade LED for this and test in the future.
Does anyone know if it is even possible to cut down a noctigon or sinkpad xp mcpcb to 8x7mm?
Good work, ohaya will be thrilled to see your progress!
I think it’s no big deal to cut down either a SinkPad or a Noctigon to 8mm diameter, although I’ve only had a reason to go down to 12mm or so myself.
Today the Hugsby P31 was in the mail, ordered it from http://www.ebay.de/itm/311216985989?\_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Since it has the older XR-E Emitter it would possibly benefit from an upgrade. But the problem is the same here - the two parts of the head stick very hard together and are probably glued. The part on the driver side is only ~5mm wide so it will be difficult to grip it without damage.
i got my xp1 last week. and i was also able to unscrew the head…………. by luck…… i guess.
when i examined the light, i noticed that the head wasn’t straight, turns out mine was cross thread @ the head. so even with the thread lock i can still unscrew the head.
mine is an xpe2, nice tint too. i was thinking about changing the LED to one with a neutral white tint, i guess i don’t need to after all.
