Ordered one - great deal if you like this format (2 26650's, not so big head).
… now I don’t have to wonder …
Ah, sorry I missed this deal.
I was fairly enamored with rovert’s Convy L2 + Magic fire 3x18650 build over here: Convoy L2 Mod
I figured this light would work well as a replacement for the L2. Bah, I need to finish building other stuff anyway.
I got mine in yesterday - nice quality light, perfect condition, excellent anodizing. It's a C8 reflector, long version. Heavy brass pill, nice retaining ring for the driver. The reflector would have to be drilled/filed out to fit a MT-G2. Driver is classic 5 modes, but good memory, 1.09A at the tail on high, simply buck driver, two R200 resistors - looks simple to boost amps, or attempt it anyway.
Well worth $13 for sure.
^ Got mine too. Surprisingly bright for a stock budget light. Finish sees pretty decent on casual observation (didn't try to test it though). The emitter isolator ring seems a tad tall based on the beam profile. Definitely a good deal.
Thank you for the alert flashination :)
I got one a few days ago. I am not able to remove the battery tube nor the pill. Did you use any special tool? I almost bent my circlip plier and the pill will not move/rotate.
^ I haven't tried yet. Guessing thread lock. You could try putting the head in a baggie in boiling water for a couple minutes than use leather gloves to unscrew the head. I can move the head a little over an eighth of an inch. Appears to be normal thread direction. Couldn't budge the pill left or right. It have a nice heavy brass pill. You may need to leave in boiling water (in a plastic bag) for a few minutes to heat all the way through.
Important::
Dang should have mentioned this... You must take the pill out first from the head -- it's CW to unscrew, not normal CCW !! Then, the body tube (top half) comes apart easy. I almost messed it up too .
This is the same type as the old IOS sold 1-2 cell light, think a host?? Can't recall model # (it's unmarked), but Hank sold these - with SS bezel, smaller head size, 1-2 18650's, not 26650. It was sold by others too.
^ Thank you Tom E. I doubt I would have figured that out. Probably would have ruined my light torquing on it. Thanks again :)
Check this out before messing with your reflector.
https://budgetlightforum.com/t/-/30860?page=11#comment-708806
No ides what post # that is - its a big thread... Please post the post#.
Trying to do it with a tape measure got me this. Reflector is 40mm wide by 36mm deep. The depth is by eyeballing it but it should be close.
EDIT:
After looking at the dimensions of the XHP50 Iris (38 mm x 28.5 mm) and XHP70 Iris (38mm x 28.1mm) , I might have to shim the MCPCB with some copper. But that wouldn’t be a bad thing.EDIT 2:
Hmmm… should I go for the flood or throw?
^ Thank you Tom E and ImA4Wheelr. No wonder the pill will not open. I will try to open it again. I would like to make the light a little brighter, please let me know what to change or add to do that.
EDIT:
I tried to remove the pill again by rotating CW as suggested by Tom E, no luck. Boiled the light in a plastic bag, still no luck. I wonder why they have to tighten the pill that tight |( .
Weird, mine came loose, even after mistakenly trying to go the other direction. Can you leverage a good amt of force? I'll use cheap rubber textured gloves, and got a great pair of needlenose.
How I got mine apart:
1) Slightly enlarge the holes on the pill with a drill.
2) Use a large needle nosed pliers that fits the holes.
3) Twist hard. If you cant gain leverage, put a large adjustable wrench over the pivot point of the pliers to add leverage and twist. It took around 40 lbs of torque to break it loose, which is probably a good deal more than most people can apply without adding leverage for a mechanical advantage.
4) I often wrap my lights in a piece of rubber or inner tube removed from an old bicycle tire before placing it in a vice. This gains traction so it wont slip in the vice and also protects the aluminum.
Finally, I got pill out. Thanks FlashPilot.
I drilled the holes on the pill slightly larger so I can get my large needle nosed plier in there, a Channel Lock plier with rubbery material around the head of the flashlight, got my wife to hold it, and I turned the needle nosed plier — success :party: .
Now I can add/replace the sense resistor to get the light a little brighter. I think Tom E mentioned about 2 R200s. Maybe I can add another R200. Where is a good place to get it? Mouser.com?
Congrats on the opening! If only I could get my wife to hold it, and open up...
I got mine at DigiKey, but I got a pretty large collection - dunno, S&H might be steep for a small order.
Sorry, couldn't resist
Congrats cnrffl4! Love you determination and attitude. Sorry for leading you astray on the boiling water. That would have only been helpful if the light had thread lock.
The best prices on resistors would probably be Fasttech. You want the 1206 sized resistors. In the mean time, you could search the pcb's of any old electronic equipment you have. If you find any, the best way to get a resistor off a pcb is to use a solder blob on your soldering iron that touches both sides of the resistor and then just swipe the resistor off the board.
If you decide to really soup up your light, you want to put the emitter on a copper base with a direct thermal path.
You probably know all the above already, but I said it just in case.
Youre welcome. Im glad you got it cracked open.
I have some 20mm noctigons coming from IOS. I will move the LED to that.
Not a problem, ImA4Wheelr. I didn’t have any idea to get it open so I tried. I almost use WD-40 on it :exmark: . Thanks again to all. Now I need to order some resistors and wait.
