The goal is to have long_press from ‘on’ go straight to ‘off’, not prev_mode
I put it where I thought it belonged, but I’m getting an error when I try to compile
This made me laugh out loud. I really have absolutely no clue what we were talking about, I’ve got to go back and look.
… OK, so that’s probably the wrong section to put that in. My mistake, I think. More like the “// Long press” section. And my suggested format for the conditional is probably wrong. It should probably be more like this: if mode_idx != 0 {mode_idx = 0;} else {prev_mode();}
if (press_duration == LONG_PRESS_DUR) {
// Long press
if (low_to_high) {
} else {
next_mode();
Note that this only functions with the mode order in one direction. That should be pretty obvious.
I’ve come to like off-time no-memory for most applications, and I think this should operate similarly while still allowing direct access to turbo from off. Moving backwards through the modes isn’t a priority.
I meant that it only works for the normal L -> H mode order. Fine for what you are trying to achieve.
If someone attempts to use my advice verbatim after reversing the mode order to H -> L they will not be happy with the result. I don’t see that as a very sensible thing to do, but I thought I’d mention it anyway.
In C, conditionals go in parenthesis. The general syntax is:
if (something is true) {
then do this;
} else {
do this instead;
In any case, I agree about off-time no-memory. I prefer my lights to be stateless, mostly. It should respond in a predictable manner from off, instead of doing something different depending on what the user did last time it was on. On clickies, I often don’t even store the last mode in eeprom any more, so it’s truly stateless after it has been off for at least half a second.
For e-switch lights, I think my favorites are UIs which give direct access to min, max, and the last-used mode.
It sounds like you might want to try “Baton” or “Ramping_UI_table”, which both use a short press to turn the light on or off, a long press to ramp while on (or to access moon from off), and a double press to access turbo. One ramps between a few fixed levels, the other ramps smoothly. They’re both under ToyKeeper/Ferrero_Rocher/ at the link in my sig.
Unfortunately, I don’t have anything like STAR-momentary but modified to allow direct shut-off from a middle mode. The closest I have is one which ramps down and shuts off while the button is being held. It’s called Ferrero_Rocher, if you’re curious.
Whereas a reverse-clicky can be hard to learn for a “muggle,” this should be easier because the momentary switch is just 1-position. Clicking always advances modes, and holding turns it off no matter how long or short you hold it.
having hard time blinking out some numbers (i.e. to blink out results of ADC or voltage or some state variables).
The blink out function works fine, but for some reason, invoking it in while(1) loop in main function causes big lag and sometimes unresponsiveness. I tried to put in inside WDT_off / WDT_on, but with similar unpredictable results.
Has anybody implemented this with success?
This is how I implemented the blinking function:
void blink_single_digit(uint8_t digit)
if (digit==0) digit=11;
uint8_t i=0;
PWM_LVL=0;
ALT_PWM_LVL=0;
do
ALT_PWM_LVL=0;
_delay_ms(400);
ALT_PWM_LVL=10;
_delay_ms(400);
i;
while (i<digit);
This is where and how I invoke it:
while(1)
// We will never leave this loop. The WDT will interrupt to check for switch presses and
// will change the mode if needed. If this loop detects that the mode has changed, run the
// logic for that mode while continuing to check for a mode change.
This really is very similar to the Baton interface (which already has lock-out implemented), except with long and short presses sort of reversed. Baton does the following:
From off:
Short press: go to last-used mode
Double press: go to turbo
Long press: go to moon mode
Longer press: soft lock-out
While on:
Short press: turn off
Double press: not yet implemented (turns off then on)
Long press: next mode (keep holding to keep cycling, skips moon mode and “off” mode)
While locked:
Press for 3 seconds to unlock
The default long press is 1/3rd second, but it’s easily tweakable in a #define along with several other options.
I haven’t found a place to put a battery check mode yet, but it does at least support realtime voltage indicator lights. I’m thinking perhaps the lockout mode could be used for battery check if the use sets a #define, and the double-press while on should probably go to another blinky mode like beacon or strobe.
What you’re trying to do is basically threading or other parallel programming. This is not going to be easy to do on such a minimal processor.
If it’s in the main loop, that entire loop will be blocked until the blinking readout is done. If you do it in an interrupt handler, you either have to disable interrupts until you’re done (and ignore events) or risk re-entering the handler while it’s already running.
You could do it with threads, but I doubt there’s a preemptive threading library for attiny (and if there is, it probably wouldn’t fit). So, your best option is probably to implement your own cooperative threading or to work both threads into a single logic stream in the main loop. Perhaps build a task queue which gets processed in the main loop but can be interrupted by other events, and the blink digit function would simply add tasks to the queue?
In any case, what I’m saying is it’s probably going to be a bit of a pain since the MCU is designed for only specific types of parallelism and I don’t thank that’s one of them.
I actually tried baton on my test rig, and it was close to what I wanted, but i thought it would be easier to use plain STAR as my stepping point.
The main things I didn’t like:
- I don’t like to use a double click as a commonly used function (just preference)
I wanted the cycle to always start at moon, not the last mode.
I do like how you’ve implemented the lockout, but I’d rather have the unlock function to be a double click (just because that’s less likely to happen in a pocket than a long press is)
Is it possible to have a long press from off to lockout, and a double click to unlock to moon?
The reason it works that way is simply because I was copying an existing interface. It doesn’t have to stay that way.
I think a double click could be used to unlock; I just haven’t ever tried it.
The memory could also be removed, which would simplify the interface. Or you could, you know, start with STAR-momentary as a base instead… which already works that way.
I probably won’t have time to mess with it for a while, but I wanted to make sure you were aware of it in case it might be useful.
I have the UI in post #913 working now, I’ll just have to play with the lockout function (probably start by copying from Baton) to get it to my liking.
