At one point there was a lot of backing for 18500. Is that what is meant by “Convoy S2+ (with 18650 ext tube)”
As it is custom built (either with a choice of tubes, head and tail are the same and X number of “bodies” are availible) or as (18500 and we can get an extender)?
djozz: Define 'better'... In principle a deeper reflector has slightly more throw, but probably not with OP. It does have slightly less flux output (lm) due to the higher fraction of reflected light and reflection losses. Thr biggest difference is the smaller spill angle which I personally am not happy with in an EDC.
See #112 https://budgetlightforum.com/t/-/11947?page=3#comment-715462
Sorry, I agree that 'better' is not appropriate in this case, I should have said: 'different' and more to my liking. I prefer the narrower spill area and wider hotspot (of ~equal brightness) that the deeper reflector provides compared to the shallow one.
The thing to remember is, this was muted as a host only — which means each of us will need to source the rest of the components to complete it.
The AA form factor is just so limiting in terms of drivers, stars, optics, reflectors and switches. That it no longer is a self assemble DIY host, but a custom build that will require you to compromise or spend loads or both.
Having a host that supports 16mm stars and 17mm drivers is in my opinion essential. This physical size means widely available reflectors, optics and switches are also easy to buy.
So my view still stands, make this an AA light, but make it big enough to support the above points/specs. Which means it would be an 18500 light.
An 18500 size would allow:
-AA to fit (maybe with an easy to make plastic insert to prevent rattling. Springs at driver/switch may solve this anyhow.
–14500 support
–18350 support (small spacer, easy/cheap to make)
–16340 support
–18500 support
So it would be an AA light, but so much more.
No other batter format will offer this versatility.
I think Rey is going to use the Convoy for the machinist to measure all sizes and internals. The looks on the outside are by no means necessarily going to be Convoy style.
