Perhaps a wide-beam laser instead of a narrow beam? Like, more focused than a SK-68 but not as much as a typical laser pointer? It’d be really cool to be able to trigger the effect from across a room.
Do different fabrics create different “songs”?
At a party, people could walk into the projected wide beam laser that is creating the disco ball effect and have their shirt/jacket/dress/chest hair/whatever sing their own specific pattern.
So let’s just say I do want to stack a zener. Can you extrapolate on the above? It’s my first time messing with a zener.
The Zener is really actually pretty easy. There’s a “limiting” or “load” resistor, that’s the 100 ohm or 200 ohm or whatever resistor that’s placed on D1’s normal location. So one end of that resistor is wired directly to the MCU’s Vcc. The Zener is also wired directly to the MCU’s Vcc as well as GND. The cathode (striped end) goes towards Vcc, the other end goes to GND.
The Zener will self destruct without a current limiting resistor. It behaves sort of like a low-resistance short to GND. That’s why we add the resistor between Vin (BAT+) and the Zener, it prevents things from getting out of control and allows the Zener to pull Vcc down to the desired voltage.
I’d either put mine diagonally across D1 and R2 (from Vcc to GND) or horizontally from D1 across to FET pins 1-3 (GND).
Post a picture with the Zener laying in place and I’ll verify whether it’s correct.
EDIT: please try and fix the strike-through in your quote of the OP. For whatever reason it’s not working and I’d rather not have anyone get confused. Stacking on C1 is not acceptable for this driver.
Which FET Pins are 1-3? the outboard pins? or from the inner pad of D1 to the outer pad of R2?
Look at the PCB. Zoom in on OSH Park images if you need to.
I couldn’t get a good picture of the real thing, so this will have to suffice.
Looks fine.
Wight, any chance you could stretch this out to 20mm?
Yes, I will stretch this soon.
noob question: If I have no modes, only on/off, what did I do wrong? I’m assuming I have a short somewhere, but what is the most common place to look?
LED- to ground. Reflector is the most common, but I would also look at the connection point on the back of the FET.
You can also double check that the black lead contact is clear on the star. I’ve seen that either touch the copper star or the side of the pill and give that result.
Check like Richard said that the lead on the mosfet isn’t touching the pill when it’s installed. The black lead from the driver, grounded out, bypasses the driver and goes direct drive.
Just ordered some of these to play! Thanks for putting this out there.
If the solder on the mcpcb sticks up you can carve it off with a knife or cover it with kapton tape(RMM sells thus stuff too).
Hmm, can i use that led - straight to the ground to get a stronger connection to my advantage if i want to do a DD build? So i connect the led - directly to bare aluminum in the pill/shelf instead of first down through the wire through the bare driver board like usual. Or would i get an even lower resistance circuit if i connect the led - to the copper DTP? If i use an conductive heatpaste like arctic silver.
Even better is if you solder the copper star to the brass pill and remove the dielectric layer under led- on the star. No modes, no low voltage protection, no brakes, really bright.
Yeah now we are really cooking :bigsmile: & the low volt protection is me finding the XP-L V6 to boring to use after it goes under 3.8v because then it starts to dim to much
Ok this light i am the process of modding today, the Zeusray doesn’t have a brass or copper pill & i don’t think it is possible to solder the star to the aluminum pill, at least i am not sure i could do it.
But i will do that if i want to do something
similar with a light that has soldereable pill.
But removing the dielectric layer i may be able to do, i have these on sinkpads 2 (i know this is a sinkpad 1 picture but i couldn’t find any of the second one in google)
So i think i would need to heat up the star to 185 degrees Celsius, remove the led, cool down the star & peel off the - side of the star & reflow the led back. Is it only the thin straight line i should remove or is it something i should do with the middle thicker copper square also?
Wouldn’t the led sit uneven if there is less height on the - side? or should i build up that side with a little extra solder paste?
You do realize, don’t you, that you CAN take it far enough that you fry emitters. Especially todays new breed of XM-L2 and XP-G2 (I think, check with RMM on the smaller one). They burn up much quicker than we’re used to, unable to do 6A much less 7A+.
Yes no worries i guess i could fry some
But i haven’t seen any reports of burned copper DTP mounted led’s, thats reasonable well heatsinked, and actually not even bad heatsinked like SS or titanium anywhere. You have had 6,89A in a XP-L (V6?) yourself and that is working fine.
What seems to be happening from reports here & elsewhere, is that when they gets too hot on the copper DTP they desolder themself or the wires.
The only burned emitter i often hear about is boost or buck driven ones.
If i would suddenly start to burn out my lights, then i would know where the limits are, i wasn’t kidding or exaggerating when i said before that i need to take thing to there limit, to know what that is and then step back to safer levels (to not burn the led that is) because burnt skin heal :bigsmile: and led’s don’t
EDIT i will just add that by “burnt skin” refers to very hot builds not exploding builds
Thats what makes this interesting & fun for me & makes me do it, i really like to optimize things. And flashlights in various form factors is really fun to optimize.
I have seen you push the limits here Dale, aren’t you curious how far it is possible to take a build when running it DD with no brakes at all?
I recently realized that when i want little light i use my small edc light & when i want more light i use an larger light, but almost always if i am outside in the dark i only use max or turbo.
