Yes we understand this to be the case. The thread with the debate between this being normative and not was read as well. It was in the VP2 giveaway thread recently from around May 2014.
Very good advice. I have also faced the same choice of choosing a charger and I purchased Opus BT-C3400 because it allows me to measure the remaining capacities of used batteries.
Only Opus BT-C does it, as Musicmagic wrote.
But I just bought the 3100 2.1 at 44.39 USD total cost ( free shipping )
when the above ref. is at 68 something total.
No real difference between the two if I’m correct…
Am I ?
But if someone sees the 3400 with free shipping…please post! :email:
Wait…
The OP says it’s not important that a charger has only 2 bays…then says it has to have 4 channels….that’s something i could not understsand then.
Also you forgot to mention the Liitokala Lii-260 and the unknown Lii-300 from which I’m eagerly waiting the HKJ review since he stated he’s reviewing it since 3 weeks ago.
I believe it could also take 26650 maybe with an adapter (i don’t remember)
Also it could take 72mm long cells
It has usb output (powerbank)
And It is a charger/analyzer, but despite the Opus it only has 1A max CC …so beware
Regarding charging curves it should be better than the OPUS if I recall it correctly
P.S: opus 3400 and 3100 v2.1 are the same thing….so if you find a deal on 3100v2.1 don’t mess seeking for a 3400 which is the same thing
I always wanted to ask you if instead of spending 25-30 euros in one of those analyzing charger would be much better a 30- 60 € for one of those 50-80-150W hobby charger (for under 60€ you could have a 300W discharge one) , considering one always have a spare PSU laying somewhere in the house. Maybe a laptop one or even a Desktop one (maybe a single 12V rail could not be enough thou).
Sure you lose the ability to analyze capacities of 2 cell at the same time if charging in parallel, also different chemistries at the same time. Also don’t know it is totally safe to charge let’s say a 2.8V cell with a 3.2V. Or cells with different form factors…
But Do the charging curves appear A LOT better?
Also is the Opus Pulse current a lot worse than the Liitokala charging current for a “everyweek recharge”? Or am i wrong?
Hobby chargers are more universal and has much better charge curves and more safety, you do also avoid heat from the charger.
BUT: They can only handle one cell at a time*, you need to do you own charge cradle and you often need to push considerable more buttons.
* Except with a balancing rig, and it can slow down the charging.
With 18650 I would not worry much about the pulse current, but with smaller cells I am not too happy about it. The LiitoKala do not use any pulses but a steady charge current.
Only two opinions on Amazon. This one was the first…coming from a 3400 seller…Never been substanciated.
But this not the correct thread…How to chose between three very good chargers…
- I’m probably going to buy the 300 . Powerbank function is really usefull when phone/tablet batteries are expensive/hard to change or when the device is meant to be disposed of when batteries are dead ( The case of many bluetooth loudspeakers )
-Support of LiFePo would be nice. I’ll write to the maker
I’m sure the OP has already chosen a charger, but in my experience so far, I trust my Xtar the most. Very consistent and precise. For simply charging li-ion it’s hard to beat.
I have found my Lii-300 to be useful, but not as well made as I had hoped. Discharge tests are always higher on one channel and the cells terminate charging at 4.26V. It’s been useful for weeding out bad cells from my laptop pulls, and really like the fact that USB out uses both slots, but other than that, I would not use it on a regular basis for charging.
And that’s a valuable opinion, since you have both.
Thanks for that. Sadly it mixes things up more. As seems there is not a valid charger that charges decently and also measures capacity. Maybe charging with vp2 and analyze with liitokala.
Or just go for Hobby chargers
For the common of mortals/beginners, LiitoKala Engineer Lii-300 could be the one and only charger to have.
Thank you for bringing that device into the thread.
