Very good advice. I have also faced the same choice of choosing a charger and I purchased Opus BT-C3400 because it allows me to measure the remaining capacities of used batteries.
Only Opus BT-C does it, as Musicmagic wrote.
But I just bought the 3100 2.1 at 44.39 USD total cost ( free shipping )
when the above ref. is at 68 something total.
No real difference between the two if Iām correctā¦
Am I ?
But if someone sees the 3400 with free shippingā¦please post! :email:
Waitā¦
The OP says itās not important that a charger has only 2 baysā¦then says it has to have 4 channelsā¦.thatās something i could not understsand then.
Also you forgot to mention the Liitokala Lii-260 and the unknown Lii-300 from which Iām eagerly waiting the HKJ review since he stated heās reviewing it since 3 weeks ago.
I believe it could also take 26650 maybe with an adapter (i donāt remember)
Also it could take 72mm long cells
It has usb output (powerbank)
And It is a charger/analyzer, but despite the Opus it only has 1A max CC ā¦so beware
Regarding charging curves it should be better than the OPUS if I recall it correctly
P.S: opus 3400 and 3100 v2.1 are the same thingā¦.so if you find a deal on 3100v2.1 donāt mess seeking for a 3400 which is the same thing
I always wanted to ask you if instead of spending 25-30 euros in one of those analyzing charger would be much better a 30- 60 ā¬ for one of those 50-80-150W hobby charger (for under 60ā¬ you could have a 300W discharge one) , considering one always have a spare PSU laying somewhere in the house. Maybe a laptop one or even a Desktop one (maybe a single 12V rail could not be enough thou).
Sure you lose the ability to analyze capacities of 2 cell at the same time if charging in parallel, also different chemistries at the same time. Also donāt know it is totally safe to charge letās say a 2.8V cell with a 3.2V. Or cells with different form factorsā¦
But Do the charging curves appear A LOT better?
Also is the Opus Pulse current a lot worse than the Liitokala charging current for a āeveryweek rechargeā? Or am i wrong?
Hobby chargers are more universal and has much better charge curves and more safety, you do also avoid heat from the charger.
BUT: They can only handle one cell at a time*, you need to do you own charge cradle and you often need to push considerable more buttons.
* Except with a balancing rig, and it can slow down the charging.
With 18650 I would not worry much about the pulse current, but with smaller cells I am not too happy about it. The LiitoKala do not use any pulses but a steady charge current.
Only two opinions on Amazon. This one was the firstā¦coming from a 3400 sellerā¦Never been substanciated.
But this not the correct threadā¦How to chose between three very good chargersā¦
- Iām probably going to buy the 300 . Powerbank function is really usefull when phone/tablet batteries are expensive/hard to change or when the device is meant to be disposed of when batteries are dead ( The case of many bluetooth loudspeakers )
-Support of LiFePo would be nice. Iāll write to the maker
Iām sure the OP has already chosen a charger, but in my experience so far, I trust my Xtar the most. Very consistent and precise. For simply charging li-ion itās hard to beat.
I have found my Lii-300 to be useful, but not as well made as I had hoped. Discharge tests are always higher on one channel and the cells terminate charging at 4.26V. Itās been useful for weeding out bad cells from my laptop pulls, and really like the fact that USB out uses both slots, but other than that, I would not use it on a regular basis for charging.
And thatās a valuable opinion, since you have both.
Thanks for that. Sadly it mixes things up more. As seems there is not a valid charger that charges decently and also measures capacity. Maybe charging with vp2 and analyze with liitokala.
Or just go for Hobby chargers
For the common of mortals/beginners, LiitoKala Engineer Lii-300 could be the one and only charger to have.
Thank you for bringing that device into the thread.
If you plan on charging low voltage (<2.8V) Li-Ion batteries such as those pulled from laptop battery packs or Li-Ion batteries drained down by your flashlight because they do not have overdischarge protection, Opus BT-C3400 would be able to restore the battery to higher capacity (and prolong your battery life) than LiitoKala Engineer Lii-300 just because the first charge after such a rundown is critically important.
I have lots of laptop battery packs which I have disassembled. I discovered by experience that BT-C3400 would recover significantly more capacity of a 1.5V battery if the first charge is 200mA than a 2.5V battery if the first charge is 500mA. For example, a Panasonic 1,800mAh cell drained down to 2.5V would restore to about 1,500 mAh when the first charge was 500mA and a 1.5V battery would restore to 1,700mAh if the first charge was 200mA. Now, my first charge of any battery discharged below 2.8V is always 200mA. If I missed charging a battery at 200mA at first and charged it at 500mA and it restored to 1,500mAh, then discharging and recharging it at 200mA would not increase the capacity to 1,700mA. So, If the first opportunity is missed, it is missed forever.
Unfortunately, Lii-300 can only charge at 500mA at minimum. It also overcharges batteries to 4.23-4.26V while my BT-C3400 has never gone even to 4.21V. It cuts off exactly at 4.20V. I read a lot of charger reviews when shopping for a new charger a month ago, and since I planned to use the charger mostly for 18650 laptop pulls, I decided that Opus would serve my purpose better.
I believe HKJ once said that if you know the shortcomings of your charger and how to work around them, many chargers would be acceptable. I just did not want to insert a resistor between the battery and LiitoKala to reduce the charging current, nor to stand over the charger all the time while it would be charging my batteries so that I could pull the plug when the display showed 4.21V. If you are are prepared to do these, LiitoKala may be the best charger for your needs.
