Thanks Djozz, very useful graph as always! Seems like 10A is a pretty decent spot to run these LEDs at.
Would it be possible to also measure the heatsink temperature in your usual test? As it seems to have such a large effect on the output it would be interesting to see how the heatsink temp ramps up in relation to the the current ramp.
When I first tested it the cells were at 3.95V, almost dead, after the lightbox run. I didn’t run it just tested it. The first reading I got was 12,523 lumens.
So of course I charged the little cells!
13,903.5 lumens out the front, even low does 1408.
I lined up the emitters such that the line between dies pointed towards the middle. This put them diagonal to each other. And the donut hole is there at low, but decreases as the brightness goes up. Turbo is a stupid amount of light!
These are the 6500K variant, the first ones out.
This Toshiba is a new release, it has a plate on top like the one on bottom that solders to the driver. This is supposed to help with heat. It’s rated at 150A, 30V.
Can’t help but wonder what a good set of top end 18650’s would do….
I have no idea if this performs any better than the SIR800 or PSMNO9R or anything else. I’ll be using the SIR800 mostly now but thought I’d try this out.
Thanks i found it, i guess i buy some of the various like the SIR800 & PSMNO9R because farnell don’t got it yet.
I hope one our spec gurus like wight, comfy or Rufusbduck will weigh in on if TPWR8503NLL1QCT-ND is a good option, i have a really hard time wrapping my head around the spec and the math comparisons on MOSFETs……
EDIT and here he comes…… thanks Rufusbduck
Would you say the SIR800 & PSMNO9R should still be the better options?
In a much higher application than ours it’s to be set up in contact with the housing or heat sink for maximum cooling. I know when we were working on the Knucklehead, there was a lot of conjecture about how to cool components so this looked like a great idea to me. I intended to make a small copper heat sink to solder to it, but realized even pushing 3 XHP70’s it’s way down on the bottom end of it’s intended use. Maybe 30A? In a component designed to do 150A? Yeah, not really an issue.
So the tab is connected to the gate? That’s really strange, I would have guessed/hoped it was connected to the source/gnd pin.
I was looking for a package like this a while ago and couldn’t find anything.
That would have been very handy for improved heatsinking when used in linear drivers (where heat dissipated would potentially be much higher than in a DD setup like this)
Edit: Just had a quick look and that DSOP Advance thermal pad does seem to be connected to the source pin. That’s awesome. I’m going to have to get a few of these things!
