I’ve got a third one I’ve not touched yet, but I’m thinking of the best way to go about de doming it
I think it’s possible if I can stop the phospher layer coming off somehow!
I don’t know if I’m being a bit dim, but I’ve just looked at the die (new dome on one) with welding goggles on, and only 2 dies light up? This is with it mounted on a XML Noctigon so 6v config
(Direct drive with 2 18650 cells)
I am surprised that you would say that, because i know you know well how many more options we have in builds by dedoming or not dedoming the various emitters we have available.
Are you not the least bit curious if for example like James postulated that maybe XPH’s when dedomed would have much less of a cross/donut artifact in the beam or if it loses lumens similar to the XM-L2 or like some here say less like the XP-L when domeless.
Anyway i look forward to the day when someone here succeed so some of these questions can be answered
EDIT
Another good reason to possibly want an dedomed XPH is now with the short supply in the beginning of production, if the XPH’s would show to dedome nicely as in stay true to the BBL and not get overly green or yellow or lose to much lumens, one could start with an CW of high flux bin and make an warmer version of it just like we do with the other emitters, but with the limited selections now it opens up a lot of options.
How strange……maybe your gasdedome didn’t fail but your mounting did? did you check that one with welding glasses before you gas dedomed it? maybe it was 2 dead from the start………
My comment referred to your question about efficiency. You will still lose efficiency without the dome.
The cross isn't going to disappear; you've still got four individual dies with space between them. The apparent distance will decrease dedomed, but it will still be there. This is why you can't compare the XPH series to the MT-G2.
the gas de dome failed because the phospher came off, the dies still lit up (2 of them) all 3 worked before de dome, mounting can’t have failed because there’s only 3 pads (thermal,positive,negative) it’s not like the sinkpad XHPs where the pos and neg are split in half
I don’t know, I’m stumped.
I checked all 3 before de dome but only the 1 after with welding goggles, but they all seemed of the same brightness to eye, which would mean they all had 2 dies only lighting up
I’m working on the third one now to see if I can do it!
Anyone any ideas on why only 2 dies lighting up at 6V?!
You might need to resort to the slice method. Best if you can find an appropriate shim to use as a guide for the blade to get an even smooth cut, lubricate the razor, and make the cut in one sliding motion rather than back and forth saw cuts.
The reason I compared the XPH dedome to the MTG2 was when people started to dedome those some found out that the quality of the light got even better after dedome that was unknown before that. Most of the other cree emitters gets worse with an apparent less CRI & often time less nice tint, i want to know how the XPH are going to appear.
And i understand that the 4 dies characteristic aren’t going to disappear, but what we don’t know is the practical implications of a smaller cross artifact, it could be that more reflectors & host will look nice enough with a dedome for example, if a simple dedome can be developed that is
ok, I’ve done it!
a little messy yes… but thats because i cant remove that white layer, the bond wires are underneath that, ill work on it and see if its possible to clean up and make it look tidier
No, I sliced the dome off the top so it was flat, then used gas to get rid of the rest the phospher didn’t come off this time, must be all about timing in the gas with this one
I’m guessing a bond wire broke when slicing(partly why I suggest lubrication, other part is cleaner cut). It’s also possible a pad on one side of the substrate didn’t wet to the Noctogon and you’re only getting current through half the die. Did you test it before dedoming?
Have this way ever been tested on the MTG2? first slice then a quick gas dedome for the rest…….if it works as good as on the XHP50’s maybe thats an safer way for them also.
