Specification:
Product name: JAX X6 Hunter CREE XHP 50 LED Flashlight
Brand: JAX
Model: X6 Hunter
Emitter Brand CREE
Emitter Type: XHP 50
Light color: Cool white
Material: Aircraft-grade aluminum body
Mode: Group 1: 100–30(middle)–5%(low)-strobe-sos
Group 2: 100–30(middle)–5%(low)
Battery Configurations: 2 x 26650 battery (not included)
Switch Type: clicky
Switch Location: tail of the flashlight
Impact Resistant 1.5 meters
Power: 20w
Brightness: 2500lumens (max)
Range: 500meters(max)
Lens: Tough ultra-clear tempered glass
Carrying Strap: included
Waterproof: IPX-8 waterproof
Color: black
Weight: 650g without battery
Size: 240mm x 74mm x 35mm(length x head x tail diameter)
Features:
—High efficiency CREE XM-L2 U2 XHP 50 LED balances powerful output with long battery life
—Aircraft-grade aluminum body with anti-scratch type III hard anodizing and removable pocket clip
—Multi-function clicky tail switch with momentary activation and on/off
—Multi-function tail switch with 3 brightness levels 2groups, plus a strobe and sos mode
—Stainless steel head ring, can bear higher impaction;
Package included:
1 x JAX X6 Hunter CREE XHP 50 LED Flashlight
1 x lanyard
1 x o-rings
Totally agree.
It would make a killer host for the MT-G2, Big reflector, brass shouldered pill,one piece battery tube (finally) forward (momentary)click, looks to be really nice design and machining quality+!!! The price is too high for me! Unless I could sell the XHP50 to recover some $$$$ Or just buy it as a host?? But that will never happen……NOT JAX!
Admittedly I don’t know much about Jax, but I got the impression they’re actually pretty good at offering their lights as bare hosts.
The Z1 is available as a shell and even the lens is available separate which is quite amazing. The Mini C8 is also host only (although I have yet to get a shipping confirmation on mine).
But you don’t think this one will be coming out as a host option? That would be a shame…
I doubt it as of now, maybe down the road when the XHP50/70 frenzy dies down? Who knows? We can only HOPE! I for one would buy the (host) say if it was around $40.00 max, build it just to keep for myself? But its hard for me to justify the price, since I bought a K40M for $80.00 shipped in December, you know what I mean……Richard has the Supfire L3’s for $29.00. I’m going to try those next. But it is a very B.A. looking light!
What are the advantages of XML2-U2 XHP 50 or 70 over an XML2-U2? Clearly it is a bigger (5mx5m) led, pumps out a heap more lumens - double - with maybe shorter range like an MTG-2? Sounds just like an MTG-2 - how is it different?
Does it have a nice hotspot like an XML2-U2 can have in a bigger head - and would it transplant into a Maxtoch 2X with good results? Advantages/disadvantages? Runtimes compared with XML2-U2? At 2500 lumens would likely need new driver as well as led board? The data I can find:
Size 5 x 5 mm
Product Options 6 V and 12 V
High-CRI
Maximum Drive Current 3 A (6 V); 1.5 A (12 V)
Maximum Power 19 W
Light Output 2546 lm @ 19 W
Typical Forward Voltage 5.7 V White @ 1400 mA (6 V); 11.5 V White @ 700 mA (12 V)
Viewing Angle 120 °
Binning 85°C
ANSI (White)
2- 3- and 5-Step Easy White®
Thermal Resistance 1.2 °C/W
Reflow Solderable Yes - JEDEC J-STD-020C-compatible.
Jax Hunter looks interesting though very heavy at 650gms + 2 x 26650s = getting up towards 1kg mark.
Thanks Max didn’t see that, the price is good if I wanted a XHP50. How about a Host? I don’t want to strip the emitter and driver out of it, got a box full of gut’s laying in the closet.
