And yeah...the UCL 52mm lens fits too, if you want that. LOL! But DX has 52.8mm lens for 2.50.
8AA is cool for a baseball bat!
I was looking at the ucl lense but not sure if it will make a difference I can see
I've received tr-3t6 with 2 cells battery. However, when i compared with my Trustfire X8, the 3t6 beam not as bright as x8. Both units were using fresh fully charged panasonic 2900mah batteries.
I was wondering what is the real maximum current can be drawn by 3t6 driver? let say, if 3Amp currents is being drawn, does it mean that 3A will be split into 3 LED (so 1Amp per LED is received)?
Honestly, I was quite disappointing with this 3t6 output beam, it doesnt perform as what i expected. Anyone has compared with x8 before?
The TR-3T6 is a buck pluss bost so there should be more then 3
amps going to the LEDs wired in series.
The beam should be wider on the TR-3T6 it is a flood light it’s more spread out with small reflectors, more of a wall of light, the x8 is more of a thrower with a concertraited focused beam with a single deeper reflector.
Because of this you can really compare the beams, one will light up a wide area (wall of light) the other will light up a small area and has more throw and will seam brighter because of this.
I’ve tryed to mention a few times its a wall of light not thrower, a good way to test it with the x 8 is take them both bush walking (forest walking).
Harry25175- are you saying you're dissatisfied with the intensity/brightness of TR-3T6's beam? Or, with the difference in it's beam vs. the X8? I'm on the fence as to which of these triples to go with...TF-SR-DRY, etc.
I like the form of the 2 or 3 x 18650 vs. the DRY but am concerned with everyone's stating the Trustfire is visibly dimmer. I just wanted to ensure I understand your comment.
I´ll stick with Benckie. I have both X9 and TR-3T6 and for a walk in the bush the 3T6 is unbeatable (IMHO). A wall of light is a great definition.
Then a C8 Q5 would also be "visibly brighter" than the DRY triple XM-L direct-driven cold white even with UCL lens upgrade. :)
You must see what is the usage. In a walking-the-dog scenario, the DRY would trash a C8 XP-G in illumination that it won't even be funny. If you are trying to illuminate your fridge or something from 1m away, it might even be painful to look at it the DRY. But yes, the hotspot of the C8 Q5 is "visibly brighter" if you are doing a light meter reading, or illuminating something that is 200m away.
i just received a message from an owner of tr-3t6, he is planning to get sst-90 9A driver and install it on tr-3t6. would it be possible??
OMG, are you sure that's the plan?
Should work...
Anything is possible. Getting a 9A Driver in there shouldn't even be that difficult. Will it make the above mushroom cloud... probably....
hahaha.. so i can say that person is trying something useless???
Not really impossible...just a matter of balancing and there still be light though Vf is a bit lower than sst90. I am going to mod my faulty Sr 3800 as i hv many spare drivers. Will work as same form factor. Tf-3t6 driver is too tall unless you bend it. If i have time i will mod the tf-3t6.
Nothing wrong with the 3t6, 1300L OTF and 14-15k
Good heatsinking, no appreciable sag for 5 mins.
well, i am waiting for that person report on modifying with sst-90 driver. once i get the report, i will post it
Mushroom cloud shots! Err...beamshots!
:bigsmile:
Yes, I get that there are different beams due to reflector configuration, etc.
What I wanted to know is if Harry was dissatisfied with the output of the Trustfire TR-3T6. I'm trying to decide which of the triple xml's to get & read lots of different opinions. Several are happy with their Sky Ray 3800s's, others had failures, one guy keeps beating the Trustfire drum, one really likes his new Sky Ray 818, etc. Plus I now see a F.F. single mode triple on DX.
I know you & others are swapping drivers, going DD, etc. but I'm not there yet. I just want to make the best buying decision, & don't want to buy more than 2 different triples at most.
I'll likely get the new DRY 5A. Which one of the others would you get?
Anyone else & why?
Anyone else & why?
My take--
DRY: Too expensive, too ugly, but should be insanely bright and fairly reliable.
Sky Ray: Reliability problems, some complaints of lower brightness, 818 is the best looker of the bunch.
Trustfire: Too ugly, but should be bright and fairly reliable.
well put imo sb
thinking out loud if the TF-3T6 is 2.5 amp and the driver is buck plus bost and the new DRY is claimed 5 amp is that driver buck and i doubt its buck plus bost ? and if people get the full claimed 5 amp draw will it put out much more light to the human eye then the other tripple xm-l,s,or tripple xm-l,s with buck plus bost drivers ? just thinking out loud i have not followed the light or any of its threads as it is not my thing and i have a good reliable tripple so im just thinking out loud.
while thinking out loud, people ask me witch one to get torch or RC, i recomend what i know and what i think is good and what i think will last, in my younger days i would buy any thing and would push every thing to the limmet they stand back when it failed and scratch your head.
like realy cars these days i like a big lazy 6,s then a small high reving 4 bagger and the lazy 6 engine will do many more miles but it might not have the same top end as the 4 banger engine, also the more common lazy big 6 is the one has the most spare parts forsale and the best price thats the most common....
i like the trustfire brand i like the constant current drivers as they seam to last long and can be ran for longer if im the guy who keeps harping on about the trustfire,s as Sprivey puts it i will say this to him, please buy the fandy fire one mode thats a drop in and it will do poorly with heat and will not handle heat or long runs, well not with atlest modification imoh, or buy the fry ray and beat that drum how its a great torch if they are like the one ive seen personaly and the countless hours of threads ive read on them before making up my mind witch one to get.
i also like manafont, but you dont have to buy from there, you dont have to read or participate in my threads please feel free to report any of my threads or post to the mod,s as to me this is just a internet forum and if your not sure witch light to buy google is your friend, good thing about budget lights or none budget lights there is that many around to suit just about any one
[quote=benckie]
[/quote]
The new Driver is just a different arrangement of modes + medium, and it's direct drive @ 5A on Turbo. It will not put put the double from 2.5A. simply because the XM-l @ 2.5A outputs about 800L and @5A outputs 970L. And there's the batteries, are they capable of that, not all of them. And there's the heat.
Mentioning about human eye is useless in my opinion, because you could easily argue about this on all kind of output levels, on all kind of flashlights.
