A 1/2 inch copper pipe tube cap fitting works, not a tight fit, but a bit of grinding/sanding to decrease the height, couple holes in the top and it does well enough for an AAA light.
I use 1/2 inch copper pipe, and sometimes bend smaller pipe to solder inside to make it closer to solid, or solder discs to the end. For the SS-5039s I have a piece of pipe I straightened and filed to fit, and I cut pills off the end. That is easier than filing after cutting to length. It also works to cut a slot in the pipe and bend it to size, as the slot does not interfere much with heat transfer.
For lower power, it is enough to file a thick star to a close fit in the head.
I have filed pills from # 3 three mode zoomies to fit AA size heads, without taking the LED and driver out.
I may use a pill from a Black Cat.
XTAR WK50, I’ve been winning auctions on these from xtarshop on ebay for $8-10. Great 4-mode driver, no disco, handles 14500’s, op reflector, pop a Nichia in it… perfect.
Who knows, I don’t even understand counterfeiting a cheap component but they clone everything. Maybe its just a super low bin and/or maybe a reject from Cree.
The Windyfire fit fine, but not any of my NiMH batterys fit not even close.
I actually tested 2 Windyfire in it………it got VERY bright for 15 second but then it went dim i was going to mod it anyway
For an maybe 1W LED or less i was surprised it did light up at all & it actually looked great before it burnt out. I remember i had time to think if it keeps working i may leave one stock before it went poof.
To bad i haven’t received the XHP50 to fix it up yet.
Duracell NIMH (Japanese Eneloops ?)did fit my torch,it was tight.I replaced the led with XML2 and new reflector.I also soldered new boost driver to the aluminum pill.The light output is nice,but this torch is quite heavy with some heatsinking,so it feels like a good host for more output.
5-Mode 800mA From FT (SKU: 1127407).The reflector is a leftover from Convoy s2+ project.It’s only 21mm wide (12mm dep) ,fits Ok against the lens.Very nice flood but the reflector opening still blocks some light and the beam is almost square.
I am in need of something cheap to sit and stare at for a few minutes test out and maybe giveaway to friend or two. How bout something $10 and under? Something that hasn’t already been listed.
