Great to hear that the voltage drop over the FET is only 25mV@5A, that is nothing to worry about: the average steel spring has a voltage drop of 250mV at 5A!
I had not thought about that possibility. You can keep the 7135 'around the corner' for that, but you will have to cut the trace to the MCU and air wire it to a different pin I guess (I have not looked into the pin-layout of Toykeeper's dual firmware for the EE A6 group buy driver)
Back in 2012 I posted This thread about an alternative way to use attiny 13A/7135 drivers with higher voltage series cells for series LEDs. At that time a few others were doing Zener mods and none of the Oshpark boards had been done yet.
In 2013 I asked Mattaus to design a 10mm driver using the Attiny13A and one 7135. He had created other boards by then and so had others so the Oshpark projects thread was born.
A bit later Brian(WarhawkAVG) asked me to collaborate with Mattaus and Comfychair on another board that combined the Attiny13A with an FET and the BLF DD family of drivers was born. I hadn’t really contributed much in the design of them but I did suggest using the LFPAK56 for its small size and high current capability. We ended up going with the larger FET because Comfychair who was doing the lions share of the testing had a lot of them to work with.
With the concept proven wight began developing designs that took advantage of the smaller FET size to make single sided drivers and that has now progressed to multi-channel drivers.
All throughout this time a bunch of truly inspired people(literally a who’s who of BLF) have been developing and tweaking the code for the 13A mcu to take better advantage of the new board designs.
We now have a member who (RMM, Mtnelectronics) who has set up shop and along with much of what one needs for modding sells many of these designs as well as coming up with new boards on his own.
DrJones, TomE, ToyKeeper, I can’t keep track of all the people writing and developing code and there are a slew of people now with more joining in adding their 2 cents. I didn’t start this but it sure has been fun to be a part of.
Edit- this post is not about claiming any credit, that all goes to Matt, CC, Alex, Brian, and all the others that pushed to get where we are now. It is just how I came to be involved and my perspective on the process.
very nice ,espacially when it does not need programming ,to make it even cheaper ,will it work with the 3 leg FET ? (salvaged old vgas and motherboards have lot of them)
FET-specs are beyond my understanding, but I'd just try some out, as long as you can make them fit. Those 3-leg FETs have long leads, they canbe bended to anywhere I suppose.
Oh, and thanks Rufusbduck for the short history of the BLF direct driver builds :-) . I had the pleasure of watching it all a bit from the sideline, these developments I think are among the absolute highlights in the (short) history of BLF (at least in the period that I have been a member).
So I was looking at NXP’s (the FET manufacturer) videos on YouTube and when they said they are at Manchester I laughed, that’s like 30 miles from here! And I’m buying their transistors from China which is thousands away, crazy world.
I used to wonder why we can buy CREE LEDs from China at relatively low prices considering it is American company, then I came to realize that CREE has manufacturing plant in China.
Another similar story is that Samsung does operate a battery manufacturing plant in my country (known as SDI) and the plant is only 30km (18.75 miles) away from my home. But since they only produce for exportation purpose we don’t get to buy them any cheaper or any more conveniently. We still have to buy these Samsung batteries from China and waiting for month(s) to get here.
DX drivers arrived quite quickly around 11 days, here’s how I modded mine.
DX 1A 2/3/5 mode Drivers, and PH4030 FETs.
Diode delete for increased gate drive, and wires soldered for bench testing. I like the 10% 100% mode group best so far.
Output current is a percentage of high mode. So if high is 4.5A, low mode (first star) will be 450mA.
Group of modes:
1st Star : Low (10) - High (100)
2nd Star: Low (5) - Medium (30) - High (100%)
3rd Star : Low (5) - High (100) - Strobe
4th Star : Low (5) - Medium (30) - High (100%) - Strobe – SOS
Thank you to all the great brains out there who figure these things out.
Good stuff going on in here. Nice budget finds and testing of the new FET option (that Rufusbduck originally identified). Heart of BLF type stuff. For the folks actually using the new FET, does it get hot on high or does it stay cool like the 70N02? I'm assuming it has low resistance and therefore low heat generation, but we all know what assumptions can lead to.
As far as i understand it, a FET shouldn’t get warm at all in this kind of DD with PWM for levels application, thats only when you use it for linear regulation like led4power’s LD-1.
yes, with a drop of 25mV at 5A the FET produces 0.125W power. To see that in perspective, every 7135chip in a lineair driver on a freshly charged battery and an XM-L2 may burn as much as 0.350W (depending on total drive current and voltage sag of the battery).
