I use a Metcal MX500UF Solder/Rework station at work with the desolder unit as well. Very nice unit. Heats up super fast and instantly cranks up the amps when the tip is “heatsinked”.
I use a Hakko fx-888 (analog one) and am very pleased with it. I haven’t replaced the original tip yet but haven’t done a ton of soldering with it and I keep it tinned. It’s done all of my soldering since late 2012 though.
you know when you are soldering and you solder something with a large heat capacity and it sucks the heat out of the tip? sometimes even sticks it for a moment. it kind of acts like a heatsink on the soldering pen.
I got a used Hakko 936 15 years ago and it still works like new. If I ever replace it I’ll probably look at another Hakko. If you really use a soldering iron that much why not consider dropping some real money and get something REALLY good.
We use Hakko irons at work, they are used daily, 5 days a week, sometimes 10 hours a day.
Rarely would one fail, as long as the tips were tinned, we had no problems. The finest point tips tended to “oxidize” from being set too high, but 1.2 mm and larger would usually last for months before they needed to be replaced. I use a 12+ year-old Weller at home, it was a “throw-away”
when we converted to Hakko. I believe the Hakko is the model #936.
I have an 85 watt Hakko 921 iron. It is preset for 700 degrees F. Must have had it 15 years now, and have done thousands of operations with it, including leaving it on overnight more than a couple times. It heats up super fast (85 watts), but still regulates at 700 degrees. That 85 watts is good to have if you need to heat up something with some bulk—like a Noctigon.
I also had a full-on Weller soldering/desoldering station—the kind with the vacuum pump. I only had this $500+ station because it was a gift from Cooper Industries (Cooper Tools) when they bought a company of ours. I used it (the iron part) a lot, and it never missed a beat. I gave it away because of its bulk—I hardly ever desolder, and the Hakko took up way less space on my bench.
You got me goggling the term and found out that some people put some sort of thermal grease on the base of the soldering tips to maximize heat transfer from the heating element to the tip. haven’t heard of this before, and haven’t read much if it would be OK for the tip or the heating element in the long run…
This is the thermal compound some were suggesting, it is rated at up to 1000 Celsius.
At a guess, Id say its primary purpose is to keep the bits free and removable without too much hassle, a bit like exhaust bolts on a car. The heat transfer is no different to heat transfer here re: LEDs and thats been overly discussed already. Better than nothing, maybe, and less is more, sure, but in the end its best use is to keep stuff that heats and cools reasonably easy to remove.
Well, I can only report on what I've actually used. I started with one of the cheap HobbyKing Hakko 936 and I am still using it today despite heavy use. I also have an FX-888D. The genuine Hakko has a better (more comfortable) iron and iron holder, but besides that it really isn't very much more powerful.
I use genuine Hakko tips with both irons and am satisfied with both of them. To me, the tips are more important than the iron.
I never expected the $21 iron to last for thousands of hours, but it has. The Hakko is a little more comfortable to use, but it was $70 more.
I think that the Hakko will serve you well, but many others probably would as well.
I have the Second one you linked. I thought the wand would break right away but it still works fine. It was delivered with a cold joint in one of the connections to the heating element (kept displaying E5) but after fixing that it’s held up well. Two minor complaints; the tip holder comes loose and the wand base needed a loop of Romex to hold the pen up. I use tip #1 for most things but like #3 for making flat joints on mcpcb’s.
I used to work for Metcal aka OK industries we though our were the best built. we were catering to PCB production rework but the machines were still for individual stations.
I have a Aouye Int3210 soldering station. -> http://www.aoyue.com/en/product/default.asp?id=39
Not the cheapest one (85€ in germany), but I have it now for ~5 Years and never had a problem with it.
very flexible cable, fast heating, digital display, shuts itself down if you forget it - and the tip is still the first one.
This is one of several. I made the enclosure as I had a 36’ Pexto shear and a 24” Pexto box and pan brake at the time. The tube that holds the iron is electrical conduit pipe. Metal this time. Inside, connected to the switch is a simple diode that allows me to switch to half power. The other side has another switch so that I can run 2 irons at a time. 1 on full and the other on half. The panel lights are old school Neon. I made this 45 years ago.
The handle is an Ungar and the heating element I got years ago at Radio Shack, back when they sold QUALITY. The RS part number is Archer 64-2082, 33 1/2 watts, really an Ungar part though. The tip is an Ungar “iron clad”. I remember the copper ones didn’t last long, but these iron clad ones seemingly last forever. They can be found on EBay
I also have a Weller soldering gun, several large irons and a Black and Decker iron and station. The B+D station is JUNK.
EDIT: The lettering was rubbed on one letter at a time from sheets that you could buy, I think in art supply stores. I have forgotten what it was called. I used it for everything, from labeling cassettes to electronic equipment. Life was hard in those days!
I just remembered, it was Letraset lettering.
Here is a bit of an update. I have been looking over all of the options suggested and greatly appreciate all of the help guys. Thank you.
2 of the main ones I have been looking at are the genuine Hakko, and the Weller.
Right now I am leaning toward the WES51. It has the type of tip holder I like and keep seeing it come up good in reviews. I would sort of like to have one that is more than 50 watt, but as best I can tell to bump up to the next level you get to pay 3x times the price.. $300+ range.
This is what I was thinking in the 50 watt
http://www.ebay.com/itm/Weller-WES51-Analog-Soldering-Station-with-Chisel-Screwdriver-Tip-Bundle-/381005859772?pt=LH_DefaultDomain_0&hash=item58b5b80bbc
My preferred tip is ETU for tiny work. It's length is short (compared to the ETS), so the path from heater to tip is short. I think its the same length as the ETA,B,C and D - just pointier.
Also look into getting a little tin of soldering tip tinner. I like the tin I have, but the label has been off for years so I don't know what to recommend! (I don't like MG Chemicals Tin/Silver FWIW) Just be sure to wipe off the residue left from the tinner (it is corrosive), you don't want that stuff left on your board. I fear that what I have pre-dates the No-Lead era and that's why it works so well.
i love my weller ws40 its not that pricy and it does very wel have light to medium soldering (you maybe could do some havy soldering, but i dont think is has enough power to do that)
