Wait!! What if we don’t want to be cured?!
Isn’t that item and the others mutually exclusive? If I take the cure, what would I want all that flashlight stuff for?! If I take the flashlight prizes then I’m going to run from your “cure”!
One day it might save your marriage. :bigsmile:
Halo
(Halo...)
May 16, 2015, 5:44am
18
I actually exercise good self control with flashlight purchases, I need no cure.
What diameter tailcap board for a 3 cell soup can? Parallel 3 x 18650?
This would be something you’re in need of for one of your lights?
TheBo
(TheBo)
May 16, 2015, 5:47am
20
I’m in.
I ’d like to participate competing with your rules, but i m not very good yet in finding appropriate things for advanced modding… I usually end buying something useless…anyway. …is this appropriate to your terms?
https://m.fasttech.com/product/1414300-100mm-5-120-degrees-plano-convex-lens
Parallel 18650’s, I’m working on designing a light, so there are no specific requirements for diameter of the board, but it needs to be designed for high amps/low resistance. Good springs would be nice, but not a necessity as they will be bridged with 18ga wire.
I’m in.
I love the light to cure my problem, but I like the other items even better!
Great giveaway, and congrats on your 500 posts. I agree, this is a great community. Thanks.
I’m fairly sure the focal length is going to be longer than 100mm being only 19.5mm thick. I’ll give you credit for trying when I update the list.
im in
i have worked in an optical industry for a year and man these glass lenses are
hard to make. imagine polishing one of these.
AlexGT
(AlexGT)
May 16, 2015, 6:31am
29
I’m in
And to answer your request, here it is… Boom!!!
http://www.dx.com/p/99mm-replacement-glass-lens-for-flashlights-43043#.VVbiVqlIfpo
99mm x 80mm FL
$10.74 shipped
I also usually check for lenses in Anchor Optics, Melles Griot and Surplus shed
Surplus shed has a lens that is 126mm and a FL of 300mm
http://www.surplusshed.com/pages/item/pl1273.html
Anchor optics has a lens that is 100mm and a FL of 200mm
http://www.anchoroptics.com/catalog/product.cfm?id=417
This place has 75mm and 50mm FL
http://search.newport.com/i/1/nav/1/q1/Lenses/q2/Aspheric%2520Lenses/q3/Aspheric%2520Condenser%2520Lenses/q4/2.95%2520in.%2520(75.0%2520mm)/x1/section/x2/chapter/x3/family/x4/facetValue04
This place has 75mm x 60mm fl
https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=3835
This place has 80mm x 59mm fl
Saabluster used a very big glass Aspheric Lens for his very first DEFT that came from a Subaru SVX ’92 Hid Headlight lens - 79mm dia, bfl 54mm is F# 0.71
Or you can find hi quality optics in those old projection tv’s for free if you know where to look, they are also big.
HTH
AlexGT
southland
(southland)
May 16, 2015, 6:54am
31
I’m in, thanks KKW, nice giveaway.
one41
(one41)
May 16, 2015, 7:40am
34
