I have those strap… not really good for mounting heavy light and that won’t fit K40M
I was thinking of a Jetbeam rrt3 holder but idk if it’ll fit the K40M :~
Guys, it was a joke…
There is no bike holder for lights like K40M, you have to make one …
Look for something like this: 404 | Topeak. There are cheaper versions out there.
Attach that to your bike, and lay the K40M across the bike handle bars and the BarXtender.
Use to secure it to the bars.
Make sure the Velcro is long enough to around the body tube and/or head.
Still might be a bit to jiggly but it should work.
Tried it with a TK35 once.
Hope that helps
I can’t be the only one who wants to see this bike (all loaded up with lights). This thread is useless without pics!!
Hahaha sure but first I gotta need the funds first. I can currently mount about 4 lights on it heh
These are what I wanna mount on ze bike hehe Those are slopes what I currently have. Its my whole collection : )
I do have a Jetbeam WL-S4 on the way weeeee
Hmm thanks for the link! I found this ” http://www.banggood.com/Bike-Bicycle-Cycling-Handlebar-Extender-Support-Holder-For-Stopwatch-p-974233.html ”
BTW was wondering if this will work? I’ll juz have to reinforce the clamp with tape ” http://www.gearbest.com/bicycling-gear/pp_69864.html ”
OR
I could pay someone who is kind enough to help machine for me a custom tripod mount for the light? Just an outer casing to hold the light in and a screw hole for a tripod? That way i can use it anywhere! ;p
Hope I don’t offend you but why bring an elephant gun to a knife fight?
Isn’t it easier/cheaper/lighter/cleaner looking to use 1x18650 lights? You could carry spare batteries if needed. Of course you can carry the K40M in your backpack or seat bag if you wanted to bring it along. I sometime will bring my modded Jacob A60 w/ XM-L2 in the backpack, it also doubles as a spare battery carrier.
I should not talk… I have 4000 lumens on the bar, 3000 on the helmet. Elephant indeed. But I haven’t always used those lights. I also plan to try the A6 and the S2+ on the helmet when I get them.
Hehe nah no offence inflicted. It’s juz that I do have 3 1 16 50 lights mounted on the bike alr heh
you need to install a stronger bolt to send you the original that you then may initiate tighter.
Also you have to remove the rubber inside the clamp then your k 40 between them.
I do have that exact same clamp but it cannot fit my K40M
you must be remove the rubber inside /a little vail out the clamp
greets
Its at the maximum width and im scared it might fall coz its really clamping the light at the edge,near the circumference of the body :~
omg how do i resize???
It’s a decent lite and easy on the wallet. Real good value for a bar mounted bicycle light.
It is decent light worth the price.
I think I might reinforce it with tape. Okai light mounts for now is solved. Will look for more to mount the jet beam and sunwayman
