I need to get some 1912 resistors to swap out on my current drivers so I can test it, but from what I’ve seen so far the 22K resistor is a downgrade. Both allow LVP to fall into the useful measuring range, but 22K seems to mess up the OTC.
With a 1912 resistor, useful OTC values (0.5s and 1.5s, room temperature) are about 200 and 100, and after being left in a freezer the medium press takes 2s instead of 1s.
With a 22K resistor, useful OTC values (~0.75s and 1.5s, room temperature) are about 250 and 190, and after being left in a freezer the medium press takes 10s instead of 1s. In both cases, the value stays at 255 for a while before dropping at all, so shorter lengths of time cannot be measured.
I tried using the memory decay trick to measure shorter times, but it doesn’t work when the OTC is enabled. If the OTC has power, it will keep the attiny powered up enough to keep memory from decaying, so the shortest amount of time I could measure was like 4s with that approach.
I dont think there is a download for guppydrv at nerd camp. As far as I know the only open source codes DrJones has are the ones found in ToyKeepers repository.
The OTC shouldn’t power the MCU because it’s not on the VCC. As far as I know, the MCU cannot be powered by any other pin than the VCC. The input capacitor would keep the MCU alive, but I can’t see the OTC doing it. On the other hand I’ve had to deal with some OTC weirdness myself, so I wouldn’t bet my savings on it…
In any case, if you want to shorten the measurable time of an OTC, put a so called bleed resistor on top of it. I’ve used values of about 360K for mine. I’ve had to deal with bleed resistors enough to incorporate a dedicated resistor spot for them on my driver boards. You just put them in parallel to the OTC, which basically means on top of it if there isn’t a dedicated spot.
It shouldn’t power the MCU, but it appears to do so anyway. The mem decay time goes from ~0.5s to ~4.0s depending on whether the OTC was charged when the light shut off.
Weirdness… And even more weirdness as that I have a 13A based driver where the memory decay time is about 10 seconds, and it doesn’t even have an OTC on it. It’s all this weirdness that has me back on OTCs but with bleed resistors. I use the memory decay trick for storage between short clicks, but no longer base on/off time checks on it.
The reason he went to the 22K instead of the 19.1K was simply because if you were using an attiny that you had pulled off of a 105C, the LVP values were close enough without having to reprogram. Unfortunately, it does seem to affect the OTC timing in weird ways...an unintended side effect. You'll find that on the zener mod drivers the LVP resistors affect the OTC timing very little, but on the 1S drivers (the newer ones with the cap on the battery side of the diode) it does make a big difference.
In short: if you can program your own MCUs, or are buying pre-programmed, just use a 19.1K instead of the 22K. If you are using a pulled MCU from another 105C driver, then you aren't using off-time memory and the 22K doesn't mess up anything.
I bought a pack of resistors from fasttech that includes 18K, 20K, 22K, no 19.1k. Since 22k can mess up the OTC which is a good alternative, 18k or 20k?
Each driver build seems to behave a little differently, especially if you change the components used to build it. However, the firmware should work if you do a little calibration on it. Or it might work without any changes.
I generally calibrate firmware for a few things on each light:
OTC values for ~0.5s and ~1.5s button presses.
Voltage detection hardcoded values for 4.2V, 4.0V, 3.8V, 3.5V, 3.0V, 2.8V, and 2.7V. Makes LVP and battcheck work.
Lowest usable PWM level, for moon mode.
Other PWM levels, if needed.
For the OTC, I flash offtime-cap.hex and measure a few button presses, then plug those values into my target firmware.
For voltage, I flash battcheck.hex and hook the light up to a variable power supply plus DMM, then adjust it to each desired level. It blinks out values I can plug into other firmwares.
For moon mode, I put my best guess into the target firmware, measure it, then adjust up or down and reflash until it’s how I want it.
For other PWM levels, I can usually just plug in some lumen estimates into level_calc.py and it’ll give me the numbers I need.
Stock store-bought drivers will probably “just work” with the default values, but custom-built drivers tend to vary more and need more calibration.
