The offtime-cap firmware can give you values for CAP_SHORT; just half-press the button for the amount of time you want to set as the threshold between short and long presses, take a few readings, get an average.
As for resistor values, I can’t really help. Battcheck doesn’t provide resistor values; it only provides ADC values to use after you’ve already gotten the resistors worked out. You need to divide the voltage in hardware to get it completely in the range of 0.1 to 1.1V though. Battcheck can at least tell you if you’re getting usable values though; try it with a full battery vs a low battery, and if the values are too close to each other (or if any readings are 255), then the resistors are wrong.
Am I understanding correctly that all the components for this board are the same as the single sided FETDD board with the exception of the 7135 chip? I just piggy pack the zener on the 10uf cap, and flash with the dual PWM firmware?
I may forget more than I remember . Haven't done a zener mod in a long time, though I know it's a combo of the resistor and firmware values read in. Would the 30-40K work for 3 cells as well, and just tweak the values in firmware also?
Depending on your required voltage cutoff, 36K will still work with 3S cells.
Recall the simple voltage divider formula (for these newer drivers without the diode voltage drop):
(Desired Voltage * R2 * 255) / ((R1 + R2)*1.1) = ADC Value
Where the 255 is the highest possible value (which is true, since we are using 8-bits worth of resolution) and 1.1 is the reference voltage.
So in your case, you'd get the following for a 9V LVP ADC value:
9*4700*255 = 10,786,500
(36000+4700)*1.1 = 44,770
10,786,500/44,770= 240.93--round to 241.
OK, now we know the math and understand what's going on. For those who don't like to slog through the math every time (like myself ) I created a Google sheet that you can just punch the values into.
P.S. As many here have noted, the voltage divider resistors can, and will, affect the off-time timing. You'll find that with the zener-mod setups the divider's effect is minimal (the circuit is different).
Ohhh - thanx again Richard! I know you posted this stuff before, but this time I'll really tag it/copy it some where I won't forget . Frustrating - just can't get to all the mods I want to... Limited time, and my mod sessions are much shorter now because of several things goin on - neck, back, access to my modding office, etc.
The voltagedivider consumes “standby” current so for electronic switch lights it might be recommended to use higher values like 100k and 22k as a standard…
Has anyone compared the so8 fets? Is the 0R9 one worth the dollar more?
What resistor Sizes are optimal for this driver 0805 or 0603?
I’m not sure what kinds of files Eagle uses, but the OSHpark page linked in the first post has a link to download a zip containing a bunch of design files. gtp, gts, txt, dri, gbl, gbo, gbp, gbs, gko, gpi, gtl, and gto. Not sure what each one is, but maybe something in there will be sufficient?
The .dri file says it was generated by “EAGLE CAM Processor 7.1.0”.
Unfortunately TK, the Gerber files can not be used to create Eagle files (At least as far as I know).
I was hoping wight might have shared the Eagle files with someone before he left. It would take someone like me a boat load of time to recreate them due to my limited experience with Eagle. It would be cool if we shared the Eagle files. That way others could tweak them for their purposes and report back. It would accelerate board development. I know there is a thread were some component libraries are shared.
If anyone has the Eagle files for this or any other BLF driver that is Attiny 13a, and DD or 7135 based, it would be cool if you made them publicly available.
EDIT: Corrected spelling of finges name. My apologies. May take me a bit to not include an "r".
