Unfortunately his site has now been inaccessible for the past 3 or 4 weeks, instead redirecting to a Chinese message that the hosting service has expired.
I hope that George returns very soon as his DQG’s are seen by many of us as the ever-evolving holy-grail of small flashlight design & engineering.
[EDIT: DQG site is back online 11/07/2015 and George has comments below. Please keep feedback polite as he is new here. George is a very small independent designer, working mostly out of passion, not a huge manufacturer.)
I have to admit that the DQG lights are my favorite lights of all time with the new clicky version of the Tiny 18650 and the Tiny 26650 lights being my favorites. However, sometimes they can be hit or miss with issues like sharp surfaces, quirky UI’s and contact problems. The twisty V2 Tiny 18650 I bought is a mess.
Something is going on, BangGood said they were “never carrying” the 18650 Tiny III again when I emailed them about its availability…. I do hope George is good and still working on things…
Okay I had a charming reply by email from George. He assures us that everything is alright and work loads simply led to the hosting service expiring without him being aware.
I invited him to share any clues about future design projects, including the hinted 26650 revision. I also asked about the statement from Banggood "never carrying the 18650 again", who he recognises as official distributers, and which stores are likely to get newest batches of his latest versions first.
Glad to hear that George is doing well, his designs are great. I am very interested in the headlamp, the new version of the 26650 is also intriguing.
My DQG Tiny III 18650 is my current favorite carry light, one of the things that makes it this is the fact I have NO desire to mod it. The levels are great, the UI works for me and the thing lives up to its name (TINY).
I had a Fairy, it was a jewel of a light, but I had no role for it, so I sold it. Still such a WOW factor light to turn it on and watch people go “OK”. Then crank it to the next level, and they go “WOW, that much light from something that small?”
yes,DQG seems to be a real unique project/brand…i self LOVE his 18650 teenee…:)absolutly.
his new 3000 lumens project will be sure a revolutionaire…
can wait to see his headlamp,but iam afraid,it will be all expensive…but,sure i will buy it…hahaha
I tried looking back at the original comment that started the issue, and at ToyKeeper's fix above, both here and in the original thread. But I still couldn't identify the missing tag either by inspecting the page HTML source in the browser, or by quoting the comments and looking at the HTML in the WYSIWYG forum editor.
So I was just trying code I knew to close possible offending tags: </span></strong></span></h2>, etc. Regardless of what I added into the forums own comment editor (HTML or Text), it just removed/corrected the code removing my added tags.
ToyKeeper replied with his closing thought that "it really should be fixed in the forum software, not on a post-by-post basis", and I agree. Perhaps we can escalate this to the forum admin...
Many thanks for fixing the issue; please do share the steps you took to do so for the record.
I removed the bold formatting by typing: (angle bracket) /strong (angle bracket) in the simple text editor. I think the advanced text editor simply displays exactly what we type.
Ha, whatever you wrote originally in this reply was similarly not showing (obviously because it was seen as a tag) - thanks for editing so fast!
Yeah, that's the exact closing tag I tried first, but whenever I added it into the Forum's comment editor it automatically removed it. I'm using the Rich-text editor where you can press the 'HTML' button to see/edit the comment in HTML. I also tried in the standard editor. Always removed the closing tag when I pressed save...
Did you do anything special to insert it into the post?
Whoops, I meant that the advanced text editor doesn’t do anything with HTML tags, it just makes them disappear. On the other hand, the simple editor seems to remove them and apply the text styling.
If you click on the quote button on the 10th post, you can see exactly what I typed because the text is preserved.
You're right, it just doesn't show that in the Advanced editor, or using the HTML code view - if the users prefs are set to use the 'Advanced editor' for comments.
This Advanced editor also prevents viewing the missing tags in the offending post, and fixing it by manually inserting 'rogue' unmatched closing tags into the HTML.
So I switched my prefs to test the 'Simple editor' and what do you know... It shows the tags and lets me add them manually.
Also lets me see the opening 'strong' tag and missing tag in the original offending post, which the Advanced editor does not - even in HTML view!
Problem solved and found out why some can fix and some can't. Many thanks.
