By reading to your reply post no #204,probably ur asking with referernce to the linked video of mine,even I don't have the clue,it was just that I found the 3T6 video on Youtube & for query pupose I posted,but I noticed some thing in the video actually the total corona section is not falling in the sensor so the actual lumen measure can get increased if "Less than 1m distance to the meter" is set.
no to mention the 3T6 light you mention is not the same light we have been talking about on here, its a drop in not the TR-3T6 screw in module to diffrent brands with two diffrent styles of drop in.
the TR-3T6 made by trustfire with the screw in module will throw 150 + meters depending of your conditions and what you call usible throw, mine to me will throw good usable light to 250 meters while lighting up the whole feild.
my opion is the 3T6 light you linked if your video will not handle long runs or transfer heat to well or as good as the TR-3T6 due to less contact erea of the drop in and not directly contacting the head.
Actually I had 2 primary questions & its not related to run times or heat management though they are very important
1>Was confused thatsy asked,if with the help of optics better throw can be attained with Tr3T6
which I chose from Deal Extreme for the best match\fit
ie;SKU 13569
SKU 13618
SKU 43044
plz suggest
2>I meant whether TR-3t6 has same luminous output as Tr-X6 ,actually the linked video showed that the luminous values for X6 & the one with 3t6 emitter which are same as same as in TR3t6 have relatively same light output.
None of them! Aspheric lenses are designed to focus a single, centered beam. With a triple LED light such as this none of the three beams will be focused and you would severely screw up the output and only make it worse.
The only way would be to use a single aspheric lens for each LED and figure out how to mount all three in the head at the proper focus distance. Even if a single lens like the ones linked could work the focal length would be all wrong as the reflectors on this light are too shallow.
Can't say for sure for this light, but I've seen 10-15% using the cheap KD voted lenses for P60 lights. If they have one in your size it'll be hugely cheaper than the UCL ones.
Actually I've seen way more than 15% but that was comparing a dirty glass lens of some age with a brand new coated one. I'd reckon you can expect the difference between one Cree bin and the next - 7-10%.
Whether that is worth it to you is another matter.
Has anybody tried this with 4xCR123A? The voltage shouldn't be too high once you get some load on the batteries (but don't blame me if it the driver burns)... CR123As would provide a nice backup and be always usable even if you take the flashlight out of the glovebox after two years of no use and in -30C temperature. And you would have a wall of light available to scare away the wolves ;)
Previously I wanted to fit a single aspheric optics but I was wrong as correctly explained by JohnnyMac now I am thinking that to fit 3 aspheric lens glued on a single 52mm normal lens for better throw mode,thatsy I required the measurement,I don't know what would happen with this Idea.
No problem, my measurements might be out 0.2 mm but close. As for aspherical lens or lens’s I might not understand what you are doing but I feel it would take away what the torch is for.
With out any aspherical lens it will give out a white wall of light and put out good usable throw for a couple hundred meters (well to me any way).
One or more aspherical lens might kill the performance of the spill with not to much more throw it just might turn it into a fire starter lol.
The UCL lense upgrade might be the best bet and cheap I think I’ll do some measurements tomorow and post up the best matching UCL lens if you like as I’m going to buy a couple any way.
i belive the 52.1 mm will not be a problem as there is a little side to side movement in lens with the trustfire host,s and i belive the 1.9mm will not be a problem in the TR-1200 at all but in the TR-3T6 you might have to screw down the alloy bezel spacer down a bit tighter.
i will buy one and try it in both lights and report my finds on fit, i dont have a light meter (will get one) so i go only go one how i feel for out put, but i feel it should be an improvement over the stock glass len's, i will give them a long run time test to see how they hold up.
I have a few of the UCL lens laying around from other various Maglight projects. I did a side by side eyeballing of the lens that's stock on the TR-3T6 and the UCL 52.1mm lens. They were so close in transmittance that I didn't bother replacing it (mostly because I couldn't figure out how to get the lens retaining ring out safely). If I had to guess, I'd say that the transmittance on the stock lens is probably around 95% (the UCL claims 99%).
Let me know if you get drastically different readings on the UCL lens and I'll swap mine out :)
Also, if you're looking for a GOOD/cheap lux meter, this is the one I use from DX...
I don't use it to get "lux" numbers, I use it for a general comparison of all my lights. I mostly do ceiling bounce tests so the exact lux numbers don't matter, just how they compare to each other.
