Ah, I forgot about the 3.3V / 5V jumper. Mine came configured for 5V and it has never been an issue.
BTW, the avrdude connection check will still pass even with VCC not connected. I flashed drivers for several weeks (with verify errors each time) before I figured out there was a physical connection issue on my VCC, but after fixing that things have been much better.
Not sure if this is the right place but I know TK had seen problems with the OTF cap timing when using a 22K resistor. Would there be the same problem, or worse, with a 36K resistor? I'm seeing awful results - when cold, quick clicks don't change modes, then after a few clicks it starts working, but as a long click (in the BLF A6 driver, moon to hidden turbo, etc.), then after a while the quick clicks work the way they should, but long clicks seem impossibly long... Ugh it's pretty useless in this setup - guess could be a bad part, but again, first time I'm trying a zener mod with the 36K resistor on a 22mm wight FET+1 board (https://budgetlightforum.com/t/-/31559).
I would like to change the turbo on blf-a6 firmware to a smaller value.Is this possible? I changed ā#define MODESNx2 0,0,79,255ā to 0,0,79,175 ,the max output was reduced but the turbo timer didnāt work anymore .Should I also change the āline 117 #define TURBO 255 // Convenience code for turbo modeā?
Yes, it changes the OTC values significantly. Youāll need to recalibrate the OTC values and voltage values completely. The tools for this are under ToyKeeper/battcheck/offtime-cap.hex and battcheck.hex.
Voltage is relatively straightforward; connect it to a power source with the voltage you want to measure, read the blinks, put that value into your target firmware. Repeat for each voltage level you need to measure.
Offtime is a bit harder, unless you have a robot to press connect/disconnect power with very precise timing. Basically, connect power, disconnect it, wait for the time you want to measure, connect power again. Repeat a bunch of times to get an average, and use that.
If you keep getting 255, it means the time is out of the MCUās measurement range (too short), or a 0 means itās too long. The problem I get is that it stays at 255 for a while before the OTC voltage drops into the usable range (especially when the light is cold).
Ideally, you want both voltage and OTC values to be near the middle of the measurement range for the best accuracy and consistency. The values should ideally center around 128 or so, though really anything between 64 and 192 is good. Probably anything between 32 and 224, really. Outside of that though, itās getting into the range where itās hard to measure reliably. The only way I know to adjust this is by choosing different resistors.
But I don't see any consistency, so don't see how calibration could work. Right now when it's cold, long press's are the only thing that work. After playing with the modes a few time, short press's are all that work. It seems temperature related, so how could I calibrate to anything?
Yes, you should also set TURBO to 175 if you want step-down to work.
Also, if you want the modes to remain evenly-spaced, I suggest running the bin/level_calc.py tool to calculate a whole new set of PWM levels. If you donāt use 255 though, you may need to edit level_calc.py to either set the value there or uncomment the line which asks you for that. Hereās what it does after I uncomment that line and re-run it with a max of PWM=175 for a 960-lm turbo:
I got 960 by estimating an actual maximum of 1400 lm, then multiplying that by 175/255.
If turbo isnāt 255 you could also try making turbo a little more efficient by putting some of the load on the 7135 chip. On a XP-L or XM-L2 itāll generally get about 140 lm on the 7135 alone or 1400 lm on the FET aloneā¦ so subtract 140 lm from the FET value and set the 7135 at full. In this case, it would mean the brightest mode is 150 on the FET and 255 on the 7135. But thatās totally optional; itāll make turbo more efficient, make the PWM harder to see, and make its tint slightly warmer.
Temperature is probably an issue, but the two calibration firmwares can at least quantify the issue for you. If it gives you crazy numbers, the hardware isnāt going to work. If it gives you okay numbers, you can be sure the hardware is okay and everything else is a firmware problem.
I'm not sure what good quantifying the problem would be? It's still a problem. Do you know if anyone has ever used OTC with a zener mod with the higher resistor values recommended? I haven't seen much in ways of posted details. Dale mentioned something about adding a cap or resistor on his zener, but with no explanation - never heard of that, or seen anything posted about it - dunno, if it was to address this issue or not.
For now I'll try a NOINIT firmware version, though it doesn't have the FET/7135 support in there now - not enough time to merge it in myself.
Yes, you lose hidden modes, but tbh I didnāt really want them anyways. I prefer very simple UIās (all of my lights are either 3 or 4.mode), but I still love Blf-A6 for access to 2 mode groups and memory soft-toggle.
I think i used a 38k in my last one and the value was around 180-190
Quantifying can tell you if itās a little off or if itās totally out of the ballpark. Besides, if you want LVP to work youāll need to calibrate the voltage anyway.
I think RMM has made zener+OTC lights, but I donāt know the details. Iāve mostly avoided serial-config lights and higher-voltage emitters.
BTW, if you canāt get the 3-level offtime to work, you could still use it without blinkies, or you could move the blinkies to the second mode group, or whatever. I could even make the basics work with mem decay instead of the OTC if needed, but note that the OTC interferes with mem-decay timing so itās a good idea to remove it or ground it or make sure it never gets charged.
Played with it more (the Roche LS01 - XHP-70), amazing how the timing just progress's - 1st time just blinks current mode, then quick clicks do prev mode, then quick clicks go next mode, and holds go prev mode -- works perfect ! Then prev mode takes longer and longer holds til they are no longer accessible...
Of course I got the big flicker every time going from turbo to moon - though turbo is PHASE (not FAST) -- forgot to add a resistor on the FET gate, but I can still do that because I only used 20 AWG LED wires, and left extra length so I can get access to program the driver - nice having a light with a screw down retainer ring on the driver...
Hi, itās me again having trouble getting things done by myselfā¦
I gave the āS7ā-firmware a try, because I wanted off-time memory an a nanjg driver without adding an otc.
Basically I wanted a very simple UI. Three modes, high to low, off-time-no-memory. I know I could have gone with āstar_noinitā for this, but I like the battery indication mode thatās in the S7 firmware. So I tried to change the S7 firmware to high, med, low, battcheck mode.
I really have no coding skills at all. Just getting started with this. I managed to get the modes like I wanted them.
changed modes array to
In the main, I commented out all āelse ifās after SOLID_MODES except the last one for the BATT_CHECK_MODE.
But now I have no clue how I have to change the part after #ifdef VOLTAGE_MON to make the lvp work as it should. I suppose I have to change something there, right? Because I changed the mode order to high, med, low, battcheck, the lvp would step into high when triggered if I leave it that way, right?
Please let me know how stupid my approach is, but donāt be too harsh, I am really new to this stuffā¦
By the way, I managed to build a FET+7135-driver with BLF-A6-firmware. Really nice firmware! But I strongly recommend using it with a reverse clicky, because until now Iām using it with a forward clicky and I feel it was much more intuitive with a reverse clicky.
To fix LVP, I think youāll need to make it change the PWM level directly instead of changing the mode index. It kind of assumes that the modes go low to high, but that wonāt matter if you cut the PWM in half each time it needs to step down.
I got some DD+7135 boards from OSH Park. So I ditched the old DD boards I modded but was having troubles with. The new boards are working, but I need to fine tune the OTC a little more. Boy TK, I totally see why you recommend tuning the OTC because it totally makes a difference in the UI's performance. Once I got it close, the program was a joy to use. Before that, it was frustrating. I probably would not have had to tune at all if I had known the my supposed 1uF caps were not actually 1uF. They are around .7uF. So I used 2 parallel caps and things got much better. I would not have discovered my caps were underrated were it not for this FW.
I'm curious. This may have already been discussed and I apologize if it has. 1uF seems a tad too big a cap. The stock FW threshold is pretty high at 190. I'm hoping to try like a cap that is about 2/3rds the capacitance and change the FW threshold down to around 140 (just throwing out a guess). Maybe will even try .5uF and then change the FW threshold down to around 95 (another guess). Has anyone done any work in that regard yet? If yes, what did they find out?
The cap isnāt the only thing which affects that. The voltage divider resistors seem to have a pretty big effect too. Ideally, you should try to tune the hardware so that the OTC decays to under 100 within 3 seconds or so, but thatās easier said than done.
In any case, I have to calibrate the OTC for every driver I use, because Iāve gotten them from a variety of sources and each one is a little different. The method I ended up using for best results is to use a metronome at 120bpm and take the average of several samples.
To save time and avoid shipping delays, I also had to teach Manker how to run these testsā¦ which was interesting since we donāt speak any of the same languages. So, I ended up making a wordless video to demonstrate the process.
^ That sounds like quite and effort and challenge.
Tonight, I used just one cap that is measuring about .688uf on a DMM. Set the FW to 140 (from 190). It works so good and reliable that I am going to pass on running the off-time FW. I have 2 more to tune. I may not be as lucky and will run the off-time FW on them if needed. I just don't trust my sense of timing. I will measure and match the capacitors to help ensure success.
Maybe someone can make a spread sheet to see if a pattern develops. Something like this:
