Interesting, this glow tape could be good to use to cover the star plate under Aspherical lenses & TIR optics to add some glow to these lights when turned off. Thanks for the link.
Nice find!
What about the alternative from the other seller?
Any more infos?
I once bought a large piece of gitd adhesive film from hobbyking which glows very good better than usual gitd tailcaps. http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=20965
I used some small circles made with a puncher to mark the eswitch on some of my lights.
Ah, interesting! Good to know Iām not the only one thatās a bit weird. =)
What I do is put reflective tape on my flashlights. I figure, if I ever need/drop a flashlight, then what actual light I have (left) would need all the help it could get to find that flashlight again.
Reflective ādotsā (or @Wernerās ideas of punched out circles) also fit well on the tailcap when there isnāt a tailcap switch, and most flashlights have room somewhere for a quick turn of reflective tape.
Above: Streamlight Ultrastinger beater light for around the house (with black gaffers tape to add back some grip after years of use) and Fenix UC30 EDC.
Red tape is 3/8ā reflective tape from REI that I later realized was expensive compared to 1/4ā yellow 3M tape available 50 feet at a time from Amazon. Obviously, I was generous with the yellow stuff after that.
3M also has black reflective tape (and Amazon sells it too), but I opted for less tacti-cool, and a bit more practical visibility.
As a watch lume junkie, Iām going to express my serious doubt that any of these tapes have ten hours of useful or significant glow. Likely, its not even close. That said, its a cool idea, and I will probably have to try some. Thanks for posting.
Yeah you can use it on any light really, iāve put it in a couple of sipiks too although with aspherics itās better if you make a resin concave mould and cover the whole of the MCPCB. With an aspheric it will throw out enough glow to read with for a little while after turning the light off. As you can see from DrafterDanās cool first post it works well with the TIR.
